  3. "cannot be found in the switched master of the instance...
  • Subscribers 133
  • Views 7721
"cannot be found in the switched master of the instance" error during netlist
yayla
yayla over 14 years ago
I have a routing in layout and I have extracted it and generated lumped model. For the lump model, I have created a spectre view by copying symbol to spectre and modifying CDF file through CIW>Tools>Edit>CDF. When I try to run simulation with schematic, there is no problem with netlisting but when I swithced to spectre view from config, I am starting to get
"Error: Netlister:terminal 'sub' of instance I151, in cell 'xxx', view 'schematic': cannot be found in he switched master of the instance."
message. I have another lump models like this but I don't have problem for those. I have checked termorder in CDF and it seems correct. I think I started to get this problem after adding manually sub pin to schematic&symbol for gnd connection in lump model(btw, lumb model was generated by ADS Spice Model Generator). Settings in CDF for model arel
Component Parameters:
paramType: string
parseAsNumber:no
parseAsCEL:no
storeDefault:no
prompt: Model Name
 defValue:xxxx
Simulation information:
Choose Simulator:spectre
termOrder: pin's names in my circuit.
Also, I have modified symbol from schematic by Design>Create Cell View to update prop.xx file to get correct termorder. I have also searched in the internet but couldn't find a solution. Hence, could you help me to fix this?
 My environment info:
o IC 5.10.41.500.6.143.
o Cadence Virtuoso Spectre Circuit Simulator Version 10.1.1.200
yayla
    Yayla,
    Hard to be sure without seeing the data, but the message suggests to me that whatever is instantiaed in xxx/schematic as "I151" (probably a symbol) has a pin called "sub", but the view it is switching into (by virtue of the config) does not have that pin. The CDF shouldn't have anything to do with that message. The pins on the switched view (i.e. the "view to use" in the config for I151) must match (or at least include) all the pins on the instantiated view (typically the symbol).
    If that's not it, I would suggest you contact customer support.
    Kind Regards,
  • yayla
    Thanks Andrew. As you said, the view for spectre doesn't have that pin which is "sub" pin. I noticed that I forgot to update the spectre view after modifying symbol and schematic. Sometimes problems can be very simple :)
    Just a quick question about your previous message. In that, you said that CDF is not important. I am wondering when Netlister looks CDF info during simulation&netlisting and which infomartion from CDF it uses(like port order ?) . I was thinking that we are using CDF to make an interface between top level netlist which includes some spectre view for example and submodule spectre view especially for port matching and port order. Finally, is there way to change port order other than CDF which sorts alphabetically I think. There is an option in Virtuoso Symbol Editing Window under Edit>Properties>Pin Order but the order there and CDF are different from each other. I am asking this because when I update my symbol sometimes, I need to change pin order either in CDF or from lump model(.scs) to match each other.
     Yayla
