  3. Error during ASSURA parasitic extraction.
  • Views 15081
RAO VINAY
RAO VINAY over 14 years ago
 Hello all,
I am using assura 3.1.6 USR 1 with IC 5141 hotfix and also with UMC 90nm technology. DRC (by setting some switches) and LVS ran successfully for my simple inverter layout but RCX gave the following error.
capgen Capgen results will be written to directory: /home/vinay_rao/work/test2
*ERROR* at "capgen": -blocking mask layer 'NCAPGATE_25' not defined in LVS filequitting.
Forking:/cad/cadence/ASSURA316/tools/assura/bin/32bit/capgen-techdir /home/vinay_rao/work/foundry/umc90/RuleDecks/Assura/LVS/../LPE/Option13 -lvs /home/vinay_rao/work/test2.xcn -p2lvs /home/vinay_rao/work/foundry/umc90/RuleDecks/Assura/LVS/../LPE/Option13/p2lvsfile -sw3d -add_via_effect me1,dif -blocking RFSYMBOL,sub,dif,ply,me1,me2,me3,me4,me5,me6,me7,me8,me9,alrdl -res_blocking RFSYMBOL,PLY,M1,M2,M3,M4,M5,M6,M7,M8,M9,AL_RDL -blocking NCAPGATE_10,ply,dif,sub -blocking NCAPGATE_12,ply,dif,sub -blocking NCAPGATE_25,ply,dif,sub -blocking NCAPGATE_HVT_10,ply,dif,sub -blocking NCAPGATE_HVT_12,ply,dif,sub -blocking NCAPGATE_N_25,ply,dif,sub -length_units meters -p ply,Allgates,dif -cap_unit 1 /home/vinay_rao/work/test2
*WARNING* Bad return status from RCX script generator. 0x100
I also went through the post http://www.cadence.com/forums/p/13908/22563.aspx which has got the same error but I didn’t find ‘resimulate_extracted’ switch set (as it is foundry dependent). And I didn’t understand clearly about Quek reply.
Can anyone suggest me how to resolve this for UMC files?
Vinay Rao.
  • Quek
    Quek over 14 years ago
    Hi Vinay Rao
    To put it simply, the Assura LVS extract.rul file which you are using is out-of-sync with the contents of the QRC tech directory. There might have been some layer changes which are not reflected in the QRC setup files. You can download the latest version of the pdk and retry. If it still results in error, you will need to report this to the foundry. : )
    Best regards
    Quek
