  3. How to get rid of 4 connection junction warning, IC6.14
  • Subscribers 133
  • Views 15486
Kabal
Kabal over 14 years ago
 It gives me warning if i have 4 connections to junction in schematic, how to get rid of that? cant find anything regarding that in manuals
  • skillUser
    skillUser over 14 years ago
     Hi Kabal,
    In the Schematic window use the menu Check -> Rules Setup and on the form look at the Physical checks tab, on there is an item named "Solder On CrossOver"  - change this to "ignored" and you will not receive the warning about this type of connection any more.
    Hope this helps,
    Lawrence.
  • Kabal
     Thanks Lawrence, it did help.
