  3. Strange numbers in Virtuoso 6.1.5
  • Replies 14
  • Views 20994
JulianJ
JulianJ over 14 years ago
I am seeing some strange number errors in Virtuoso 6.1.5.
In the ADE, I type  "1p" as the value for a variable and when set it appears as "1e122", "100f" becomes "1e155", "1f" becomes "1e155".
A similar error is also appearing on the drain diffusion area calculated on the FETs I am placing in my schematics, with the calculated area being displayed and netlisted as "480e155", when I think it should be "480f".
 I tried upgrading my instalation from  IC6.1.5-64b.500.1 to IC6.1.5-64b.500.9, but still have the same problem.
 Any help appreciated.
Julian
    Julian,
    We had one customer report this to us a while ago, and they were using RHEL6 and they moved back to RHEL5 and the problem went away. I don't see the problem in RHEL6 myself though - so it's probably not as simple as that.  A couple of things that would be useful to know:
    1. What OS distribution and version are you using?
    2. What is the value of the $LANG variable (type "printenv LANG" in the terminal window)?
  • JulianJ
    G'day Andrew,
     The OS is OpenSuse 11.4.
    > printenv LANG
    en_US.UTF-8
    > uname -a
    Linux nanosrv 2.6.37.1-1.2-desktop #1 SMP PREEMPT 2011-02-21 10:34:10 +0100 x86_64 x86_64 x86_64 GNU/Linux
    Julian
    Julian,
    I did a bit more searching, and the majority of reported cases (there have only been a handful) have been on unsupported OS distributions (e.g Ubuntu and CentOS).
    Your kernel version is a fair way ahead of even RHEL6.1 (which is supported for IC615).
    We've been unable to reproduce the problem with any supported OS. Not sure why it would fail in this way though.
    Can you try using a supported OS distribution and version (supported versions are shown on the Support & Training->Computing Platform Support at the top of the web page)?
  • JulianJ
    Andrew,
    Your list indicates that SLES 11 is supported for IC 6.1.5. I am surprised that there are any significant differences between this and OpenSUSE 11.
    I have no access to another machine to try alternate installations and several other users of this machine that are not affected by this problem.
    Julian
    Julian,
    I wouldn't expect there to be massive differences either - but in the absence of other information and empirical evidence that moving to a supported OS fixed it, that's why I was making the suggestion.
    However, your point that other users on the same machine are unaffected is interesting. Maybe there's something in your environment which gives a clue.
    Can you post the output of "env" and also what "locale" shows?
  • JulianJ
     G'day Andrew,
     The other users on the machine are affected by the same bug, they just are not using transistors that are small enough to cause problems. Calculated numbers above 1.2ps appear to be fine.
     Others are still using IC5141 with no problems.
    More playing with the problem has me even more confused.
    If I set an ADE varable to "1f" it displays as "1e155", but when I click on it to edit the value in the edit box is 1f again. Fortunalty this also netlists correctly.
    If I choose to override the drain diffusion area it allows me to replace "480e155" with "480f", which I beleive to be correct. This also netlists correclty - just means that I must update the drain diffusion every time I adjust the width. This is 500.9 - 500.1 keeps the "480e155" even if I type "480f".
    Julian
     > env
    LESSKEY=/etc/lesskey.bin
    NNTPSERVER=news
    MANPATH=/usr/local/man:/usr/share/man
    HOSTNAME=nanosrv
    XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB
    HOST=nanosrv
    TERM=xterm
    SHELL=/bin/bash
    PROFILEREAD=true
    HISTSIZE=1000
    SSH_CLIENT=10.1.3.101 51325 22
    MORE=-sl
    OLDPWD=/data/SIL180/julian
    SSH_TTY=/dev/pts/47
    CDK_DIR=/data/ON06/PDK/NCSU_PDK/
    JRE_HOME=/usr/lib64/jvm/jre
    USER=julian
    LS_COLORS=no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=41;33;01:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.tbz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.lzma=00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*.xz=00;31:*.avi=01;35:*.bmp=01;35:*.fli=01;35:*.gif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;35:*.mpg=01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;35:*.tga=01;35:*.tif=01;35:*.xbm=01;35:*.xpm=01;35:*.dl=01;35:*.gl=01;35:*.wmv=01;35:*.aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.ogg=00;32:*.voc=00;32:*.wav=00;32:
    XNLSPATH=/usr/share/X11/nls
    HOSTTYPE=x86_64
    FROM_HEADER=
    PAGER=less
    CSHEDIT=emacs
    XDG_CONFIG_DIRS=/etc/xdg
    MINICOM=-c on
    MAIL=/var/mail/julian
    PATH=/home/julian/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:.:/usr/local/mentor/ixl_cal_2011.1_24.16/bin:/usr/local/cadence/MMSIM101/tools/bin/:/usr/local/cadence/INCISIV102/bin:/usr/local/cadence/INCISIV102/tools/bin:/usr/local/cadence/AUSSURA6/tools/bin/:/usr/local/cadence/AUSSURA6/tools/assura/bin:/usr/local/cadence/IC615/tools/bin/:/usr/local/cadence/IC615/bin/
    CPU=x86_64
    JAVA_BINDIR=/usr/lib64/jvm/jre/bin
    SSH_SENDS_LOCALE=yes
    INPUTRC=/home/julian/.inputrc
    PWD=/data/SIL180/PDK/m6_mim4f_builtin
    JAVA_HOME=/usr/lib64/jvm/jre
    EDITOR=xterm -e /usr/bin/joe
    LANG=en_US.UTF-8
    PYTHONSTARTUP=/etc/pythonstart
    CDS_Netlisting_Mode=Analog
    LM_LICENSE_FILE=5280@cad4.ee.unsw.edu.au:1717@cad4.ee.unsw.edu.au
    PRE_PATH=/home/julian/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:.
    GPG_TTY=/dev/pts/47
    TECHDIR=/data/GF65/PDK/chrt65lpe/Calibre/
    QT_SYSTEM_DIR=/usr/share/desktop-data
    SHLVL=1
    HOME=/home/julian
    SDL_AUDIODRIVER=pulse
    ALSA_CONFIG_PATH=/etc/alsa-pulse.conf
    LESS_ADVANCED_PREPROCESSOR=no
    OSTYPE=linux
    MGC_HOME=/usr/local/mentor/ixl_cal_2011.1_24.16
    LS_OPTIONS=-N --color=tty -T 0
    WINDOWMANAGER=/usr/bin/startkde
    G_FILENAME_ENCODING=@locale,UTF-8,ISO-8859-15,CP1252
    LESS=-M -I -R
    MACHTYPE=x86_64-suse-linux
    LOGNAME=julian
    XDG_DATA_DIRS=/usr/share
    SSH_CONNECTION=10.1.3.101 51325 10.10.1.10 22
    SOCV_KIT_HOME=/usr/local/cadence/INCISIV102
    LESSOPEN=lessopen.sh %s
    DISPLAY=localhost:11.0
    XAUTHLOCALHOSTNAME=nanosrv
    LESSCLOSE=lessclose.sh %s %s
    ASSURAHOME=/usr/local/cadence/AUSSURA6
    INCISIVE=/usr/local/cadence/INCISIV102
    G_BROKEN_FILENAMES=1
    JAVA_ROOT=/usr/lib64/jvm/jre
    COLORTERM=1
    mc=() {  . /usr/share/mc/mc-wrapper.sh
    _=/usr/bin/env
    > locale
    LANG=en_US.UTF-8
    LC_CTYPE="en_US.UTF-8"
    LC_NUMERIC="en_US.UTF-8"
    LC_TIME="en_US.UTF-8"
    LC_COLLATE="en_US.UTF-8"
    LC_MONETARY="en_US.UTF-8"
    LC_MESSAGES="en_US.UTF-8"
    LC_PAPER="en_US.UTF-8"
    LC_NAME="en_US.UTF-8"
    LC_ADDRESS="en_US.UTF-8"
    LC_TELEPHONE="en_US.UTF-8"
    LC_MEASUREMENT="en_US.UTF-8"
    LC_IDENTIFICATION="en_US.UTF-8"
    LC_ALL=
    The problem appears to be in the function aelSuffixNotation - and I think what happens is that it displays various values after passing through that function. However, the value is probably being stored exactly as you entered it.
    Looking at your environment, and based on what you say, it almost certainly is an OS problem (maybe a problem with one of the shared libraries - it's hard to tell).
    Can you try using:
    export LANG=C
    before starting virtuoso (I think you're using bash not csh) - does that help?
    Can you also try in the CIW:
    aelSuffixNotation(1e-12)
    aelEngNotation(1e-12)
    sprintf(nil "%1.4e" 1e-12)
    and post what these output?
  • JulianJ
    No change in behaviour after "export LANG=C"
    "1e122"
    "1e122"
    "1.0000e-12"
    sprintf(nil "%1.4e" 1p)
    "1.0000e-12"
    aelSuffixNotation(1.2e-15)
    "1.2f"
    aelSuffixNotation(1.2e-12)
    "1.2p"
    aelSuffixNotation(480f)
    "480e155"
    aelSuffixNotation(480.1f)
    "480.1e515"
    aelSuffixNotation(480.1e-15)
    "480.1e515"
    Julian
    Julian,
    After writing some C code (replicating what's going on in the tools) and some experimentation, I now see the same problem when I'm running on my RHEL6.1 machine, and running virtuoso in 64 bit mode. It doesn't happen for me in 32 bit mode. Perhaps you can try running "virtuoso -32" to see if that helps? The same behaviour is true for my little C program; compiled in 32 bit mode, it works fine, but compiled in 64 bit mode I see the problem.
    I believe I understand the root cause in the code as to why this is happening (and I have an alternative implementation which seems to fix it), so I will file a CCR to get this fixed. I'll post the CCR number once I've done that.
    Julian,
    The CCR number is 995099. You might want to contact customer support and get a duplicate filed so that you can track when the fix is available on Cadence Online Support.
