  3. Using runams instead of ocean
  • Subscribers 133
  • Views 15780
ptorru14
ptorru14 over 14 years ago
Hello everyone,
I'm trying to get started in the use of the "runams" command. My aim is to run several simulations from a PERL command but without invoking an ocean console. I found the help of the command and I tried to follow it. However when it finally runs I get the following error:
/opt/cad5/tools/dfII/bin/runams: environment variable CDS_TEST_LIBPATH is set for Cadence testing
/opt/cad5/tools/dfII/bin/runams: LD_LIBRARY_PATH for testing is:  /usr/lib:/lib:/opt/cad5/tools/lib:/usr/lib
/opt/cad5/tools/dfII/bin/runams: SHLIB_PATH for testing is:  /usr/lib:/lib:/opt/cad5/tools/lib:/usr/lib
/opt/cad5/tools/dfII/bin/runams: LIBPATH for testing is:  /usr/lib:/lib:/opt/cad5/tools/lib:/usr/lpp/X11/lib/R6:/usr/lib
COPYRIGHT    1992-2009  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
             1992-2009  UNIX SYSTEMS Laboratories INC.,
                          Reproduced with permission.
This Cadence Design Systems program and online documentation are
proprietary/confidential information and may be disclosed/used only
as authorized in a license agreement controlling such use and disclosure.
          RESTRICTED RIGHTS NOTICE (SHORT FORM)
Use/reproduction/disclosure is subject to restriction
set forth at FAR 1252.227-19 or its equivalent.
ERROR (RUNAMS-13): Cannot get Virtuoso MMSIM Incubation license.
Exiting runams.
I already contacted the system admin and he told me that we have a lot of free licences and that everything looks fine in my config script. Does anybody has any idea? Does anybody knows where can I find further docummentation for the "runams" command?
 Also... I want to extract some info from the output waveforms, but I would like to do this using commands. Do you have any idea how can I acces the output waves from the sim? Am I still attached to run an ocean console and access them from there?
 Thanks a lot for your time. Best regards!
     My guess is that you're using an old version. "runams" is relatively recent, and in the early days it was restricted to only those with an "incubator" license.
    Try a more recent hotfix of whichever version you're using.
  • ptorru14
     Hello Andrew, thanks for the fast response. I'll try what you said. I'll post back with the results
