  3. Virtuoso installation questions
  • Subscribers 136
  • Views 18580
19877891
19877891 over 14 years ago
Hi All,
I am beginner of using Cadence tools and currently I have some difficulties when installing Virtuoso. I am trying to install Virtuoso 6.1.0_Base on Linux machine Red-Hat Enterprise 5.
Configuration script (/share/license/configure) runs normally. When I am starting Virtuoso I get following errors:
/tools/cadence/IC/6.1.0/tools/dfII/bin/32bit/virtuoso.exe: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /tools/cadence/IC/6.1.0/share/oa/lib/linux_rhel40_gcc44x_32/opt/liboaPlugIn.so)
/tools/cadence/IC/6.1.0/tools/dfII/bin/32bit/virtuoso.exe: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /tools/cadence/IC/6.1.0/share/oa/lib/linux_rhel40_gcc44x_32/opt/liboaCommon.so)
/tools/cadence/IC/6.1.0/tools/dfII/bin/32bit/virtuoso.exe: /tools/cadence/IC/6.1.0/tools/lib/libgcc_s.so.1: version `GCC_4.2.0' not found (required by /usr/lib/libstdc++.so.6)
I assume that something wrong with LD_LIBRARY_PATH env variable, although I set it to installed package’s /tools/lib folder.
Can someone help me, what I am doing wrong with virtuoso installation?
Arsen
  • Quek
    Quek over 14 years ago
    Hi Arsen
    IC610Base is already too-outdated and is not supported on RHEL5. Please install hotfix version IC615-500-9. There is no need to set LD_LIBRARY_PATH as it is set in the tool's wrapper.
    Best regards
    Quek
  • Vigna
    Vigna over 11 years ago
    Hi Mr Quek, This is Vinod, i have installed cadence Virtuoso in my ubuntu 14.10 64 bit, my problem is when i execute the command " virtuoso &'' in the respective directory virtuoso is not invoking rather my terminal window exits, help me to sort out this problem. Thanks
  • Quek
    Quek over 11 years ago
    Hi Vinod
    As per the forum rules, please kindly avoid using an old thread. Would you please start a new thread for your issue? This will also help us to focus only on your problem. Please kindly include the version of Virtuoso, error messages, etc.
    Best regards
    Quek
