  3. Does Cadence 6.1.5 support SpectreVerilog simulator?
  • Subscribers 133
  • Views 15674
ericliu
ericliu over 14 years ago
 I recently switched from Cadence 5 to Cadence6.1.5. Someone told me that mixed-signal simulation using SpectreVerilog is not supported in Cadence 6. Is that true? So what are the supported simulators in Cadence 6.1.5. What is the best (fastest) simulator to simulate a design which contains both schematic and verilog blocks. Many thanks.
  • Quek
    Quek over 14 years ago
    Hi Eric
    You can still use spectreVerilog in IC615 but it is not recommended as it is a very out-dated simulator. Please use AMS Designer to do mixed signal simulation.
    Best regards
    Quek
  • Awais107
    Awais107 over 12 years ago
    Hi Quek, Can I use spectre Verilog in IC615? Is there any tutorial available.? I want to test a simple 8bit adder (RTL) using ideal_adc and ideal_dac to verify its working in virtuoso. I am having following error at simulation phase. ************************************************ Transient Analysis `tran': time = (0 s -> 10 ms) ************************************************ Error found by spectre during initialization. ERROR (SPECTRE-16325): Error while starting the attached simulator. The verilog code I am using is pretty much simple (I am doing some basic mistake at simulation level) Awais
  • Quek
    Quek over 12 years ago
    Hi Awais
    Just a gentle reminder not to reply to old threads. The discussion in this thread has already ended in 2012. Would you please post your question in a new thread so that we can have a better focus on your issue?
    Best regards
    Quek
