  3. Help needed changing the pin properties in layout !!
  • Subscribers 133
  • Views 15841
SivaChaitanya
SivaChaitanya over 14 years ago
Hi there ,
 I was working on a tri-state inverter design using cadence 5 version. Initially i declared the output pin to be output and designed the layout using gen from source option and completed it. But later i recognised that the output pin should be declared as inputandouput pin, i was successful changing the pin property in schematic but when i ran the LVS after this change i got a error message that pin properties does not match..
my question is how to change the output pin property without effecting my already done layout design, i tried different options but couldnt find one which cold change the pin properties in layout ? Please help me in sorting out this problem
Siva
  • Quek
    Quek over 14 years ago
    Hi Siva
    Would you please let us know if there are any issues in changing the layout pin direction? It seems to be quite an easy change so I am not sure why it cannot be done.
    Quek
  • SivaChaitanya
    Thanks for replying Quek, you are right that the change can be done by the conncectivity tab in properties of the pin but for me i dont know why the tab is not getting highlightened so i want to know if there is any other way i can change the direction in the layout
    Siva
    Siva,
    This would normally happen if the shape you're trying to edit is not actually a pin. If it's a pin, it will have connectivity information.
  • SivaChaitanya
    Thanks andrew the information was helpful, accidently i was clicking on the wrong object properties than output pin properties.
    Siva
