  3. Mark net feature in layout
  • Replies 8
  • Subscribers 133
  • Views 21489
mailavj
mailavj over 14 years ago
Hello
 I am an Analog IC design student. In my university we are using cadence IC614. At the moment I am using it to design an amplifier (Schematics and Layout). We are using libraries from AMS foundry for this purpose. I have laid down an NMOS transistor and attached wires to its source, drain and gate. When i do Connectivity -- Nets -- Mark in layout editor and select drain net, it shows short with source net. However there is only on transistor in the layout editor at the moment and its not connected with anything else. I am not sure why this is happening. Please advise.
 Thank you
Aravind
  • Quek
    Quek over 14 years ago
    Hi Aravind
    I think you can resolve the problem as follows:
    a. Invoke marknet cmd
    b. Press F3 to display marknet options form
    c. Choose "Select via"
    d. Unselect the via connecting your metal1 and diffusion
    In your case, marknet is using all the vias and hence connects everything through the substrate.
    Best regards
    Quek
  • mailavj
     Hello Quek
    Thank you very much for the reply.This solved the problem with mark net option.I am also getting similar errors in LVS. Do we have some similar options for LVS also. I am unable to attach my schematics, layout , but pasted below my LVS log
    LVS log.
                Assura (tm) Physical Verification Version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.485
                Release 4.1_USR1_HF10
    Copyright (c) Cadence Design Systems. All rights reserved.
    @(#)$CDS: assura_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.485 07/07/2010 03:49 (sjfql241) $
    sub-version 4.1_USR1_HF10, integ signature 2010-07-07-0307
    run on connel.see.ed.ac.uk from /home/cdseng/tools/cds_201011/ASSURAOA41/tools.lnx86/assura/bin/64bit/assura on Sun Apr 15 09:30:13 2012
    Loading all available p-cell functions
    AMS_DB set to cds
    No mx check
    ROD pcell code loaded
    Starting /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/aveng /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.rsf -exec1 -LVS -cdslib /home/s1147823/cad_temp/cds.lib
    @(#)$CDS: aveng_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.485 07/07/2010 03:49 (sjfql241) $
    run on connel.see.ed.ac.uk from /home/cdseng/tools/cds_201011/ASSURAOA41/tools.lnx86/assura/bin/64bit/aveng on Sun Apr 15 09:30:13 2012
    AMS_DB set to cds
    No mx check
    Loading tech rule set file : /home/cdseng/dkits/ams_400/assura/c35b4/c35b4c3/techRuleSets
     Summary Report: trial.sum
     RSF           : /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.rsf
     Library Name  : trial
     CDSLIB Path   : "/home/s1147823/cad_temp/cds.lib"
     Cell Name     : trial
     View Name     : layout
     Rules File    : /home/cdseng/dkits/ams_400/assura/c35b4/c35b4c3/extract.rul
     Options       : -exec1 -LVS -cdslib /home/s1147823/cad_temp/cds.lib
     Work Directory: /home/s1147823/cad_temp/ASSURA_LVS/trial
     Operating Mode: Legacy Mode is Off
    Starting dfIIToVdb...
    Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.07s.
    @(#)$CDS: dfIIToVdb_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.485 07/07/2010 03:50 (sjfql241) $
    run on connel.see.ed.ac.uk from /home/cdseng/tools/cds_201011/ASSURAOA41/tools.lnx86/assura/bin/64bit/dfIIToVdb on Sun Apr 15 09:30:14 2012
    AMS_DB set to cds
    No mx check
    Compiling rules...
    WARNING Undefined layer in dfII.
        Layer name 'VIA3' doesn't exist, treating as an empty layer.
        VIA3 = layer("VIA3" type("drawing"))
        Layer name 'MET4' doesn't exist, treating as an empty layer.
        MET4 = layer("MET4" type("drawing"))
        Layer name 'CHIPEDGE' doesn't exist, treating as an empty layer.
        CHIPEDGE = layer("CHIPEDGE" type("drawing"))
        M4HOLE = layer("MET4" type("hol"))
    WARNING Undefined purpose in dfII.
        Purpose name 'metal4' doesn't exist, ignoring this purpose.
        MET4_pintext = textToPin("PIN" type("metal4"))
        MET4_sympin = pinLayer("MET4" type("pin"))
        VIA3_netPurpose = layer("VIA3" type("net"))
        MET4_netPurpose = layer("MET4" type("net"))
        MET4_pinPurpose = layer("MET4" type("pin"))
        MET4RES = layer("METRES" type("metal4"))
    WARNING LVS Run detected.
    Non-legacy mode has been disabled for this LVS run
    Checking out license for Assura_LVS 4.10
    Checking out license for Assura_DRC 4.10
    Reading the design data...
    Finished dfIIToVdb.
    Building the VDB part 2 in background mode.
    Building tables for LVS Preprocessing in background mode.
    Starting /home/cdseng/tools/cds_201011/ASSURAOA41/tools/assura/bin/vdbToCells /home/s1147823/cad_temp/ASSURA_LVS/trial trial
    Finished /home/cdseng/tools/cds_201011/ASSURAOA41/tools/assura/bin/vdbToCells
    Starting Nvn PreExtraction...
    Starting /home/cdseng/tools/cds_201011/ASSURAOA41/tools/assura/bin/nvn /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.rsf -preExtract -exec1 -cdslib /home/s1147823/cad_temp/cds.lib
    @(#)$CDS: nvn_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.485 07/07/2010 03:51 (sjfql241) $
    run on connel.see.ed.ac.uk at Sun Apr 15 09:30:16 2012
    AMS_DB set to cds
    No mx check
    Reading schematic network
     running dfIIToVldb -cdslib /home/s1147823/cad_temp/cds.lib /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.vlr /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.rsf
    Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.06s.
    @(#)$CDS: dfIIToVldb_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.485 07/07/2010 03:50 (sjfql241) $
    run on connel.see.ed.ac.uk from /home/cdseng/tools/cds_201011/ASSURAOA41/tools.lnx86/assura/bin/64bit/dfIIToVldb on Sun Apr 15 09:30:17 2012
    AMS_DB set to cds
    No mx check
    function modelName redefined
    function namePrefix redefined
    function termMapping redefined
    function termOrder redefined
    function instParams redefined
    Library Name: "trial"
    Cell Name: "trial"
    Cell View: "schematic"
    Output Data Base Name: "/home/s1147823/cad_temp/ASSURA_LVS/trial/trial.sdb"
    Simulator Name: "auCdl"
    View List: "auCdl schematic cmos_sch symbol"
    Stop List: "auCdl"
    Net Listing Mode is Analog
    writing /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.sdb
     inputting /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.sdb
    Reading layout network
     inputting network ASSURA_LVS/trial/trial.ldb
    Preprocessing schematic network phase 1
    *WARNING* genericDevice("CVAR") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("PNPLAT3") - cell does not exist. This command will be ignored.
    *WARNING* genericDevice("LAT2") - cell does not exist. This command will be ignored.
    Preprocessing layout network phase 1
     WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'NMOSM4' is not found and
     will be considered a dummy cell. The default binding for layout cell 'NMOSM4(MOS)' will be broken.
     will be considered a dummy cell. The default binding for layout cell 'NMOSM_WAFFLE(Generic)' will be broken.
     WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'PMOS4' is not found and
     will be considered a dummy cell. The default binding for layout cell 'PMOS4(MOS)' will be broken.
     will be considered a dummy cell. The default binding for layout cell 'PMOS_WAFFLE(Generic)' will be broken.
     WARNING (AVLVSNN-10034) : bindingFile/bind rule - schematic cell 'PMOSM4' is not found and
     will be considered a dummy cell. The default binding for layout cell 'PMOSM4(MOS)' will be broken.
     will be considered a dummy cell. The default binding for layout cell 'PMOSM_WAFFLE(Generic)' will be broken.
    Preprocessing schematic network phase 2
    Preprocessing layout network phase 2
    cpu=0.00m  wall=0.02m  mem=42.41mb
    Finished /home/cdseng/tools/cds_201011/ASSURAOA41/tools/assura/bin/nvn
    Executing: substrate_all = cellBoundary(root)
    Building the VDB part 3 in background mode.
    Finished building the VDB. VDB build times for main process:
    cpu: 0.17  elap: 5  pf: 0  in: 0  out: 10752  virt: 101M  phys: 554M
    Running the Task Processor, 1 cells, 3344 steps...
    Top Cell is 'trial layout trial'
    Executing: LVTDEF = geomEmpty()
    Executing: POLY1_pinshape = geomOr(POLY1_sympin geomTextShape(POLY1_pintext))
    Executing: MET1_pinshape = geomOr(MET1_sympin geomTextShape(MET1_pintext))
    Executing: MET2_pinshape = geomOr(MET2_sympin geomTextShape(MET2_pintext))
    Executing: MET3_pinshape = geomOr(MET3_sympin geomTextShape(MET3_pintext))
    Executing: MET4_pinshape = geomOr(MET4_sympin geomTextShape(MET4_pintext))
    Executing: PAD_pinshape = geomTextShape(PAD_pintext)
    Executing: OPTDEF_pinshape = geomTextShape(OPTDEF_pintext)
    Executing: subdef_ring = geomAndNot(SUBDEF geomSize(SUBDEF -0.05))
    Executing: ntub_subdefcut = geomAndNot(NTUB subdef_ring)
    Executing: net_psub = geomOr(geomAndNot(substrate_all subdef_ring) geomAnd(subdef_ring N...
    Executing: diff_cut = geomAndNot(DIFF DIFCUT)
    Executing: poly1_cut = geomAndNot(POLY1 PO1CUT)
    Executing: poly2_cut = geomAndNot(POLY2 PO2CUT)
    Executing: poly1_n_poly2 = geomAndNot(poly1_cut poly2_cut)
    Executing: net_poly1con = geomAnd(CONT poly1_n_poly2)
    Executing: net_poly2con = geomAnd(CONT poly2_cut)
    Executing: diffcon = geomAnd(CONT diff_cut)
    Executing: net_via2_metcap = geomAnd(VIA2 METCAP)
    Executing: via2_met2 = geomAndNot(VIA2 net_via2_metcap)
    Executing: via_cont_pin = geomOr(VIA1 CONT MET1_pinshape)
    Executing: ndiff_1 = geomAnd(diff_cut NPLUS)
    Executing: pdiff_1 = geomAnd(diff_cut PPLUS)
    Executing: poly1_poly2 = geomAnd(POLY1 POLY2)
    Executing: pres1_1 = geomAndNot(geomAnd(poly1_cut RESDEF) HRES)
    Executing: pres1_2 = geomAndNot(pres1_1 poly1_poly2)
    Executing: pres1 = geomAndNot(pres1_2 RESTRM)
    Executing: resdef_2p = geomGetTexted(RESDEF RESDEF_text "RPOLY2P")
    Executing: presp_1 = geomAndNot(geomAnd(poly2_cut resdef_2p) HRES)
    Executing: presp_2 = geomAndNot(presp_1 poly1_poly2)
    Executing: presp = geomAndNot(presp_2 RESTRM)
    Executing: resdef_2ph = geomGetTexted(RESDEF RESDEF_text "RPOLY2PH")
    Executing: presph_1 = geomAndNot(geomAnd(poly2_cut resdef_2ph) HRES)
    Executing: presph_2 = geomAndNot(presph_1 poly1_poly2)
    Executing: presph = geomAndNot(presph_2 RESTRM)
    Executing: resdef = geomAndNot(geomAndNot(RESDEF resdef_2p) resdef_2ph)
    Executing: pres_1 = geomAndNot(geomAnd(poly2_cut resdef) HRES)
    Executing: pres_2 = geomAndNot(pres_1 poly1_poly2)
    Executing: pres = geomAndNot(pres_2 RESTRM)
    Executing: RPOLY2RF_device = geomEnclose(RFDEF geomInside(pres ntub_subdefcut))
    Executing: zero_tc = geomGetTexted(HRES HRES_text "RPOLYZ")
    Executing: presz_1 = geomAnd(poly2_cut zero_tc)
    Executing: presz = geomAndNot(presz_1 PPLUS)
    Executing: hres = geomAndNot(HRES zero_tc)
    Executing: presh_1 = geomAnd(poly2_cut hres)
    Executing: presh = geomAndNot(presh_1 PPLUS)
    Executing: preshterm = geomAnd(presh_1 PPLUS)
    Executing: RPOLYHRF_device = geomEnclose(RFDEF geomInside(presh ntub_subdefcut))
    Executing: pdres_1 = geomAnd(pdiff_1 RESDEF)
    Executing: pdres_2 = geomAvoiding(pdres_1 pres)
    Executing: RDIFFP_device = geomAndNot(pdres_2 RESTRM)
    Executing: ndres_1 = geomAnd(ndiff_1 RESDEF)
    Executing: ndres_2 = geomAvoiding(ndres_1 pres)
    Executing: RDIFFN_device = geomAndNot(ndres_2 RESTRM)
    Executing: nwres_1 = geomAnd(NTUB TUBDEF)
    Executing: nwres_3 = geomAvoiding(nwres_1 RDIFFP_device)
    Executing: nwres_4 = geomAvoiding(nwres_3 RDIFFN_device)
    Executing: RNWELL_device = geomAndNot(nwres_4 RESTRM)
    Executing: nwres_trm = geomButting(RESTRM RNWELL_device)
    Executing: pdres_trm = geomButting(RESTRM RDIFFP_device)
    Executing: pres_trm = geomButting(RESTRM pres)
    Executing: presph_trm = geomButting(RESTRM presph)
    Executing: pres1_trm = geomButting(RESTRM pres1)
    Executing: presh_trm = geomButting(preshterm presh)
    Executing: net_poly1 = geomAndNot(poly1_cut pres1)
    Executing: poly2_1 = geomAndNot(poly2_cut pres)
    Executing: poly2_2 = geomAndNot(poly2_1 presp)
    Executing: poly2_3 = geomAndNot(poly2_2 presph)
    Executing: poly2_4 = geomAndNot(poly2_3 presh)
    Executing: net_poly2 = geomAndNot(poly2_4 presz)
    Executing: nmos30_ntub_clos = geomSize(geomSize(geomButtOrOver(NTUB HVDEF) 0.9) -0.9)
    Executing: net_nwell = geomOr(geomAndNot(ntub_subdefcut RNWELL_device) nmos30_ntub_clos)
    Executing: ndiff_2 = geomAndNot(ndiff_1 net_poly1)
    Executing: net_ndiff = geomAndNot(ndiff_2 RDIFFN_device)
    Executing: pdiff_2 = geomAndNot(pdiff_1 net_poly1)
    Executing: net_pdiff = geomAndNot(pdiff_2 RDIFFP_device)
    Executing: trans = geomAnd(diff_cut net_poly1)
    Executing: ngate = geomAndNot(trans NTUB)
    Executing: pgate = geomAnd(trans NTUB)
    Executing: gate = geomOr(ngate pgate)
    Executing: ndevx = geomAnd(ngate NPLUS)
    Executing: ndev = geomAndNot(geomAnd(ngate NPLUS) HVDEF)
    Executing: pdev = geomAnd(pgate PPLUS)
    Executing: pnpvert_0 = geomAnd(net_pdiff geomSize(NTUB 1.1))
    Executing: pnpvert_1 = drc(geomHoles(pnpvert_0) (area < 1000.0))
    Executing: pnpvert_2 = geomInside(NTUB pnpvert_1)
    Executing: pnpvert_3 = geomAnd(net_ndiff pnpvert_2)
    Executing: geomHoles(pnpvert_3)
    Executing: pnpvert_5 = geomInside(net_pdiff pnpvert_4)
    Executing: pnpvert_6 = geomGetLength(pnpvert_5 ((39.9 < keep) < 40.1) contiguous fig)
    Executing: pnpvert10_e = drc(pnpvert_6 ((99.9 < area) < 100.1))
    Executing: VERT10_device = geomSize(pnpvert10_e 2.0)
    Executing: pnplat = drc(geomHoles(pdev) (area < 10.0))
    Executing: pnplat2_e = geomGetLength(pnplat ((7.5 < keep) < 8.05) contiguous fig)
    Executing: LAT2_device = geomButtOnly(pdev pnplat2_e)
    Executing: pnplat2_c = geomAndNot(geomButtOnly(net_pdiff LAT2_device) pnplat2_e)
    Executing: nwell_ill = geomButtOnly(NTUB trans)
    Executing: nwell_hv_trans = geomStraddle(NTUB trans)
    Executing: nwell_ovlp_good = drc(nwell_hv_trans trans ((1.6 <= ovlp) <= 1.6) opposite pa...
    Executing: nwell_ovlp_bad = drc(nwell_hv_trans trans (ovlp < 2.0) opposite parallel)
    Executing: ill_hvmos_nwell = geomOr(nwell_ill geomEnclose(NTUB geomAvoiding(nwell_ovlp_b...
    Executing: errorLayer(geomAvoiding(geomButtOrOver(ndev ill_hvmos_nwell) nwell_ovlp_good) "DEVICE Error: Illegal nmosh device")
    Executing: routp_n_trans = geomAndNot(net_poly1 trans)
    Executing: waffle_poly1_1 = geomGetHoled(net_poly1)
    Executing: waffle_holes = geomAnd(geomHoles(waffle_poly1_1 innermostEmpty) diff_cut)
    Executing: waffle_poly1 = geomAndNot(waffle_poly1_1 geomGetHoled(geomOr(waffle_poly1_1 w...
    Executing: waffle_gate = geomButtOrOver(geomAnd(geomSize(waffle_holes 0.6 edges) waffle_...
    Executing: pmos_waffle = geomButtOnly(waffle_gate net_pdiff (keep == 2))
    Executing: nmos_waffle = geomButtOnly(waffle_gate net_ndiff (keep == 2))
    Executing: pmos_1 = geomAndNot(pdev LAT2_device)
    Executing: pmos_2 = geomButtOnly(pmos_1 routp_n_trans)
    Executing: pmos_3 = geomButtOnly(pmos_2 net_pdiff (keep == 2))
    Executing: pmos_4 = geomAndNot(pmos_3 waffle_poly1)
    Executing: pmos_5 = geomAnd(pmos_3 pmos_waffle)
    Executing: PMOS_device = geomAndNot(geomAndNot(geomAndNot(pmos_4 MIDOX) LVTDEF) RFDEF)
    Executing: PMOSM_device = geomAndNot(geomAndNot(geomAnd(pmos_4 MIDOX) LVTDEF) RFDEF)
    Executing: PMOSL_device = geomAndNot(geomAnd(geomAndNot(pmos_4 MIDOX) LVTDEF) RFDEF)
    Executing: PMOSML_device = geomAndNot(geomAnd(geomAnd(pmos_4 MIDOX) LVTDEF) RFDEF)
    Executing: pmosrf_trans = geomAnd(geomAndNot(geomAndNot(pmos_4 MIDOX) LVTDEF) RFDEF)
    Executing: PMOSRF_device = geomEnclose(RFDEF pmosrf_trans)
    Executing: PMOS_WAFFLE_device = geomAndNot(geomAndNot(geomAndNot(pmos_5 MIDOX) LVTDEF) R...
    Executing: PMOSM_WAFFLE_device = geomAndNot(geomAndNot(geomAnd(pmos_5 MIDOX) LVTDEF) RFDEF)
    Executing: PMOSL_WAFFLE_device = geomAndNot(geomAnd(geomAndNot(pmos_5 MIDOX) LVTDEF) RFDEF)
    Executing: PMOSML_WAFFLE_device = geomAndNot(geomAnd(geomAnd(pmos_5 MIDOX) LVTDEF) RFDEF)
    Executing: nmosh_1 = geomAndNot(geomOr(geomButtOnly(trans NTUB) geomStraddle(trans NTUB)...
    Executing: nmosh = geomButtOrOver(nmosh_1 ndev)
    Executing: nmoshall = geomAnd(nmosh_1 geomAnd(trans NPLUS))
    Executing: nmosh_d = geomAnd(net_ndiff geomButtOrOver(NTUB nmoshall))
    Executing: nmosh_d_fill = drc(nmosh_d nmosh (sep < 6.0) opposite parallel)
    Executing: nmosh_d_term_1 = geomOr(nmosh_d nmosh_d_fill)
    Executing: nmosh_d_term_2 = geomButtOnly(nmosh_d_term_1 nmosh)
    Executing: nmosh_d_term = geomOverlap(net_nwell nmosh_d_term_2)
    Executing: NMOSH_device = geomAvoiding(geomAvoiding(nmosh MIDOX) LVTDEF)
    Executing: NMOSMH_device = geomAvoiding(geomButtOrOver(nmosh MIDOX) LVTDEF)
    Executing: NMOSHL_device = geomButtOrOver(geomAvoiding(nmosh MIDOX) LVTDEF)
    Executing: NMOSMHL_device = geomButtOrOver(geomButtOrOver(nmosh MIDOX) LVTDEF)
    Executing: nmos_1 = geomAndNot(ndev nmosh)
    Executing: nmos_2 = geomAvoiding(nmos_1 ill_hvmos_nwell)
    Executing: nmos_3 = geomButtOnly(nmos_2 routp_n_trans)
    Executing: nmos_4 = geomButtOnly(nmos_3 net_ndiff (keep == 2))
    Executing: nmos_5 = geomAndNot(nmos_4 waffle_poly1)
    Executing: nmos_6 = geomAnd(nmos_4 nmos_waffle)
    Executing: NMOS_device = geomAndNot(geomAndNot(geomAndNot(nmos_5 MIDOX) LVTDEF) RFDEF)
    Executing: NMOSM_device = geomAndNot(geomAndNot(geomAnd(nmos_5 MIDOX) LVTDEF) RFDEF)
    Executing: NMOSL_device = geomAndNot(geomAnd(geomAndNot(nmos_5 MIDOX) LVTDEF) RFDEF)
    Executing: NMOSML_device = geomAndNot(geomAnd(geomAnd(nmos_5 MIDOX) LVTDEF) RFDEF)
    Executing: nmosrf_trans = geomAnd(geomAndNot(geomAndNot(nmos_5 MIDOX) LVTDEF) RFDEF)
    Executing: NMOSRF_device = geomEnclose(RFDEF nmosrf_trans)
    Executing: NMOS_WAFFLE_device = geomAndNot(geomAndNot(geomAndNot(nmos_6 MIDOX) LVTDEF) R...
    Executing: NMOSM_WAFFLE_device = geomAndNot(geomAndNot(geomAnd(nmos_6 MIDOX) LVTDEF) RFDEF)
    Executing: NMOSL_WAFFLE_device = geomAndNot(geomAnd(geomAndNot(nmos_6 MIDOX) LVTDEF) RFDEF)
    Executing: NMOSML_WAFFLE_device = geomAndNot(geomAnd(geomAnd(nmos_6 MIDOX) LVTDEF) RFDEF)
    Executing: cpoly = geomAnd(geomAndNot(net_poly1 HRES) poly2_cut)
    Executing: CPOLYRF_device = geomEnclose(RFDEF geomAnd(cpoly ntub_subdefcut))
    Executing: cvar = geomAvoiding(geomAnd(pgate NPLUS) geomOr(nmosh HVDEF))
    Executing: cvar_no_rfdef = geomAndNot(cvar RFDEF)
           errorLayer(cvar_no_rfdef "DEVICE Error: CVAR_device missing RFDEF")
    Executing: ndiode_1 = geomAvoiding(geomAndNot(net_ndiff NTUB) trans)
    Executing: ND_device = geomAnd(ndiode_1 DIODE)
    Executing: pdiode_1 = geomAvoiding(geomAnd(net_pdiff NTUB) trans)
    Executing: PD_device = geomAnd(pdiode_1 DIODE)
    Executing: sbd_diode_definition = geomGetTexted(DIODE DIODE_text "SBD5*")
    Executing: NWD_device = geomAnd(NTUB geomAndNot(DIODE sbd_diode_definition))
    Executing: zdiode_1 = geomGetEdge(net_pdiff butting net_ndiff)
    Executing: zdiode_2 = geomSize(zdiode_1 0.1 unmergedOut edges)
    Executing: zdiode_3 = geomAnd(net_pdiff net_ndiff)
    Executing: zdiode_4 = geomOr(zdiode_2 zdiode_3)
    Executing: zdiode_5 = geomButtOrOver(net_pdiff zdiode_4)
    Executing: zdiode_6 = geomButtOrOver(net_ndiff zdiode_4)
    Executing: zdiode_7 = geomOr(zdiode_5 zdiode_6)
    Executing: zdiode_8 = geomAnd(zdiode_7 ZENER)
    Executing: zdiode_9 = geomEnclose(zdiode_8 zdiode_7)
    Executing: zdiode_all = geomAnd(zdiode_4 zdiode_9)
    Executing: zdiode_02_1 = drc(zdiode_all ((0.2 <= width) <= 0.2) parallel opposite)
    Executing: zdiode_02 = geomButtOrOver(zdiode_all zdiode_02_1)
    Executing: ZD2SM24_device = geomOr(zdiode_02)
    Executing: net_ndiffcon = geomAndNot(geomAnd(ndiff_1 CONT) net_poly1con)
    Executing: net_pdiffcon = geomAndNot(geomAnd(pdiff_1 CONT) net_poly1con)
    Executing: te_pro_pad = drc(PAD (area < 3481))
    Executing: net_bondpad = geomAndNot(PAD te_pro_pad)
    Executing: met1_withslots = geomAndNot(MET1 M1HOLE)
    Executing: met2_withslots = geomAndNot(MET2 M2HOLE)
    Executing: met3_withslots = geomAndNot(MET3 M3HOLE)
    Executing: met4_withslots = geomAndNot(MET4 M4HOLE)
    Executing: implant = geomOr(NPLUS PPLUS)
    Executing: net_welltap = geomAnd(net_ndiff net_nwell)
    Executing: net_subtap = geomAndNot(net_pdiff net_nwell)
    Executing: net_nsd = geomOverlap(net_ndiff geomAndNot(net_ndiff net_welltap))
    Executing: net_psd = geomAndNot(net_pdiff net_subtap)
    Executing: metcap_bottom_plate = geomEnclose(MET2 METCAP)
    Executing: cmim = geomAnd(METCAP metcap_bottom_plate)
    Executing: CMIM_device = geomAndNot(cmim RFDEF)
    Executing: PHDNWA850_device = geomAnd(geomAnd(NTUB net_ndiff) OPTDEF)
    Executing: PHDNWA850_device_x = geomCat(PHDNWA850_device)
           errorLayer(PHDNWA850_device_x "Process Modules : PHDNWA850 not available for this process module")
    Executing: sbd_diode_def_ok = geomGetTexted(DIODE DIODE_text "SBD5_REV_1.0")
    Executing: sbd5_err = geomAndNot(sbd_diode_definition sbd_diode_def_ok)
           errorLayer(sbd5_err "Version od SBD5 obsolte or missing")
    Executing: sbd5_ndiff_1 = geomHoles(geomAnd(ndiff_1 sbd_diode_definition) innermost)
    Executing: sbdcon = geomAnd(geomAndNot(diffcon implant) sbd_diode_definition)
    Executing: net_sbd_anode_diff = geomEnclose(geomAndNot(DIFF implant) sbdcon)
    Executing: SBD5_device = geomCat(sbd5_ndiff_1)
    Executing: SBD5_device_x = geomCat(SBD5_device)
           errorLayer(SBD5_device_x "Process Modules : SBD5 not available for this process module")
    Executing: esdpd18_hvdef_def = geomAndNot(geomGetTexted(HVDEF HVDEF_text "ESDPD18_*") ge...
    Executing: esdpd18_cath_ndiff_c_ntub = geomAnd(geomAnd(net_ndiff NTUB) esdpd18_hvdef_def)
    Executing: esdpd18_ntub = geomEnclose(NTUB esdpd18_cath_ndiff_c_ntub)
    Executing: ESDPD18_device = geomCat(esdpd18_ntub)
    Executing: esdpd26_hvdef_def = geomAndNot(geomGetTexted(HVDEF HVDEF_text "ESDPD26_*") ge...
    Executing: esdpd26_cath_ndiff_c_ntub = geomAnd(geomAnd(net_ndiff NTUB) esdpd26_hvdef_def)
    Executing: esdpd26_ntub = geomEnclose(NTUB esdpd26_cath_ndiff_c_ntub)
    Executing: ESDPD26_device = geomCat(esdpd26_ntub)
    Executing: esdpd30_hvdef_def = geomAndNot(geomGetTexted(HVDEF HVDEF_text "ESDPD30_*") ge...
    Executing: esdpd30_cath_ndiff_c_ntub = geomAnd(geomAnd(net_ndiff NTUB) esdpd30_hvdef_def)
    Executing: esdpd30_ntub = geomEnclose(NTUB esdpd30_cath_ndiff_c_ntub)
    Executing: ESDPD30_device = geomCat(esdpd30_ntub)
    Executing: esdfdp5_hvdef_def = geomAndNot(geomGetTexted(HVDEF HVDEF_text "ESDFDP5_*") ge...
    Executing: esdfdp5_anod_pdiff_d_ntub = geomAnd(geomAnd(net_pdiff NTUB) esdfdp5_hvdef_def)
    Executing: ESDFDP5_device = geomCat(esdfdp5_anod_pdiff_d_ntub)
    Executing: esdgcp5_hvdef_def = geomAndNot(geomGetTexted(HVDEF HVDEF_text "ESDGCP5_*") ge...
    Executing: esdgcp5_anod_pdiff_d_ntub = geomAnd(geomAnd(net_pdiff NTUB) esdgcp5_hvdef_def)
    Executing: ESDGCP5_device = geomCat(esdgcp5_anod_pdiff_d_ntub)
    Executing: esdfdn5_hvdef_def = geomAndNot(geomGetTexted(HVDEF HVDEF_text "ESDFDN5_*") ge...
    Executing: esdfdn5_cath_ndiff_d_sub = geomAnd(geomAndNot(net_ndiff NTUB) esdfdn5_hvdef_def)
    Executing: ESDFDN5_device = geomCat(esdfdn5_cath_ndiff_d_sub)
    Executing: esdgcn5_hvdef_def = geomAndNot(geomGetTexted(HVDEF HVDEF_text "ESDGCN5_*") ge...
    Executing: esdgcn5_cath_ndiff_d_sub = geomAnd(geomAndNot(net_ndiff NTUB) esdgcn5_hvdef_def)
    Executing: ESDGCN5_device = geomCat(esdgcn5_cath_ndiff_d_sub)
    Executing: ndiff_nldd = geomCat(net_ndiff)
    Executing: nmos30_1 = geomEnclose(geomHoles(net_poly1 innermost) ndiff_nldd)
    Executing: nmos30_2 = geomButting(net_poly1 nmos30_1)
    Executing: nmos30_3 = geomStraddle(geomButtOrOver(ndevx nmos30_2) FIDEF)
    Executing: nmos30_ndiff = geomInside(ndiff_nldd nmos30_1)
    Executing: nmos30_d_fill = drc(nmos30_ndiff nmos30_3 (sep < 2.5) parallel opposite)
    Executing: nmos30_4 = geomOr(geomButting(nmos30_3 nmos30_d_fill) nmos30_d_fill)
    Executing: nmos30_4g = geomAnd(nmos30_4 DIFF)
    Executing: nmos30m = geomButtOrOver(nmos30_4 geomInside(nmos30_4g MIDOX))
    Executing: nmos18t = geomAndNot(nmos30_4 nmos30m)
    Executing: nmos30_drain = geomButtOnly(nmos30_ndiff nmos30_4)
    Executing: nmos30m_double = geomOr(nmos30m geomButtOnly(nmos30_drain nmos30m))
    Executing: nmos18t_double = geomOr(nmos18t geomButtOnly(nmos30_drain nmos18t))
    Executing: NMOS30M_device = geomCat(nmos30m_double)
    Executing: NMOS18T_device = geomCat(nmos18t_double)
    Executing: NMOS30M_device_x = geomCat(NMOS30M_device)
           errorLayer(NMOS30M_device_x "Process Modules : NMOS30M not available for this process module")
    Executing: NMOS18T_device_x = geomCat(NMOS18T_device)
           errorLayer(NMOS18T_device_x "Process Modules : NMOS18T not available for this process module")
    Executing: ESDPD18_modeled = geomSize(esdpd18_hvdef_def 0.7)
    Executing: ESDPD26_modeled = geomSize(esdpd26_hvdef_def 0.7)
    Executing: ESDPD30_modeled = geomSize(esdpd30_hvdef_def 0.7)
    Executing: ESDFDP5_modeled = geomSize(esdfdp5_hvdef_def 0.7)
    Executing: ESDGCP5_modeled = geomSize(esdgcp5_hvdef_def 0.7)
    Executing: ESDFDN5_modeled = geomSize(esdfdn5_hvdef_def 0.7)
    Executing: ESDGCN5_modeled = geomSize(esdgcn5_hvdef_def 0.7)
    Executing: NMOS30M_modeled = geomOverlap(HVDEF NMOS30M_device)
    Executing: NMOS18T_modeled = geomOverlap(HVDEF NMOS18T_device)
    Executing: diodes_modeled = geomCat(ESDPD18_modeled ESDPD26_modeled ESDPD30_modeled ESDF...
    Executing: p_nwd_1 = geomAndNot(net_nwell geomOr(DIODE geomButtOrOver(net_nwell geomOr(O...
    Executing: p_nwd_2 = geomAndNot(p_nwd_1 geomOverlap(p_nwd_1 pnpvert10_e))
    Executing: p_nwd_3 = geomAndNot(p_nwd_2 geomOverlap(p_nwd_1 pnplat2_e))
    Executing: p_nwd_4 = geomAndNot(p_nwd_3 diodes_modeled)
    Executing: P_NWD_device = geomAndNot(p_nwd_4 geomStraddle(p_nwd_2 ZD2SM24_device))
    Executing: p_pd_1 = geomAndNot(pdiode_1 DIODE)
    Executing: p_pd_2 = geomAndNot(geomOutside(p_pd_1 ZD2SM24_device) pnpvert10_e)
    Executing: p_pd_3 = geomAndNot(p_pd_2 diodes_modeled)
    Executing: P_PD_device = geomAndNot(geomAndNot(p_pd_3 pnplat2_e) pnplat2_c)
    Executing: spiral_term11_1 = geomGetTexted(geomButtOrOver(RESTRM INDDEF) MET3_pintext "P1")
    Executing: spiral_term22_1 = geomGetTexted(geomButtOrOver(RESTRM INDDEF) MET3_pintext "P2")
    Executing: spiral_term11_2 = geomGetTexted(geomButtOrOver(RESTRM INDDEF) MET4_pintext "P1")
    Executing: spiral_term22_2 = geomGetTexted(geomButtOrOver(RESTRM INDDEF) MET4_pintext "P2")
    Executing: spiral_term11 = geomOr(spiral_term11_1 spiral_term11_2)
    Executing: spiral_term22 = geomOr(spiral_term22_1 spiral_term22_2)
    Executing: spiral_met_all_1 = geomOr(geomAnd(MET2 INDDEF) geomAnd(MET3 INDDEF))
    Executing: spiral_met_all = geomOr(spiral_met_all_1 geomAnd(MET4 INDDEF))
    Executing: spiral_term = geomButtOrOver(geomAnd(geomOr(spiral_term11 spiral_term22) INDD...
    Executing: spiral_inddef = geomButtOrOver(INDDEF spiral_term (keep == 2))
    Executing: spiral_body = geomAnd(spiral_inddef spiral_met_all)
    Executing: SP133S300T_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP100S250T_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP073S250T_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP060S300T_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP049S300T_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP047S250T_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP037S250T_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP033S150T_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP031S250T_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP024S250T_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP021S200T_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP020S250T_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP015S250T_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP011S200T_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: spiral_body_named_typet = geomCat(SP133S300T_device SP100S250T_device SP073S2...
    Executing: SP014S300D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP018S300D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP020S180D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP023S200D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP025C200D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP026S200D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP028S300D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP028C200D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP030C200D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP037S180D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP038S300D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP040C200D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP040C300D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP045C200D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP047S180D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP050S155D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP051C300D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP068C300D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP090C200D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP090S155D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP112C300D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP140C200D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP200C200D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SY014C165D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SY015C200D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SY016C180D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SY017C165D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SY019C180D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SY028C160D_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: spiral_body_named_typed = geomCat(SY014C165D_device SP014S300D_device SY015C2...
    Executing: SP014S300C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP018S300C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP020S180C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP023S200C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP025C200C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP026S200C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP028S300C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP028C200C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP030C200C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP037S180C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP038S300C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP040C200C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP040C300C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP045C200C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP047S180C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP050S155C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP051C300C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP068C300C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP090C200C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP090S155C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP112C300C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP140C200C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SP200C200C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SY014C165C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SY015C200C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SY016C180C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SY017C165C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SY019C180C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: SY028C160C_device = geomAnd(spiral_body geomGetTexted(spiral_inddef INDDEF_te...
    Executing: spiral_body_named_typec = geomCat(SY014C165C_device SP014S300C_device SY015C2...
    Executing: spiral_body_named = geomCat(spiral_body_named_typet spiral_body_named_typed s...
    Executing: spiral_body_unknown = geomAndNot(spiral_body spiral_body_named)
    Executing: inddef_bad = geomButtOrOver(INDDEF spiral_body_unknown)
           errorLayer(inddef_bad "ERC Warning : Name of Spiral not identified")
    Executing: inddef_bad_all = geomAvoiding(INDDEF spiral_body_named)
           errorLayer(inddef_bad_all "ERC Warning : INDDEF does not define a correct spiral or is not valid for this process")
    Executing: bad_spirlay_1 = geomAnd(INDDEF DIFF)
    Executing: bad_spirlay_2 = geomAnd(INDDEF implant)
    Executing: bad_spirlay_3 = geomAnd(INDDEF POLY1)
    Executing: bad_spirlay_4 = geomAnd(INDDEF POLY2)
    Executing: bad_spirlay_5 = geomAnd(INDDEF via_cont_pin)
    Executing: bad_spirlay_6_1 = geomOr(geomAnd(INDDEF MET1) geomAnd(INDDEF MET2))
    Executing: bad_spirlay_6 = geomOr(bad_spirlay_6_1 geomAnd(INDDEF VIA2))
    Executing: bad_spirlay_all = geomOr(bad_spirlay_1 geomOr(bad_spirlay_2 geomOr(bad_spirla...
           errorLayer(bad_spirlay_all "ERC Warning : illegal layer under spiral")
    Executing: rmet1_1 = geomAnd(met1_withslots geomOr(METRES MET1RES))
    Executing: rmet1_trm = geomAnd(geomAndNot(geomSize(rmet1_1 0.1) rmet1_1) met1_withslots)
    Executing: rmet1_2 = geomGetRectangle(rmet1_1)
    Executing: errorLayer(geomAndNot(rmet1_1 rmet1_2) "Error: MET1 resistors (shorts) must be rectangular")
    Executing: RMET1_device = geomButtOrOver(rmet1_2 rmet1_trm (keep == 2))
    Executing: errorLayer(geomAndNot(rmet1_2 RMET1_device) "Error: Number of MET1 resistor terminals != 2")
    Executing: rmet2_1 = geomAnd(met2_withslots geomOr(METRES MET2RES))
    Executing: rmet2_trm = geomAnd(geomAndNot(geomSize(rmet2_1 0.1) rmet2_1) met2_withslots)
    Executing: rmet2_2 = geomGetRectangle(rmet2_1)
    Executing: errorLayer(geomAndNot(rmet2_1 rmet2_2) "Error: MET2 resistors (shorts) must be rectangular")
    Executing: RMET2_device = geomButtOrOver(rmet2_2 rmet2_trm (keep == 2))
    Executing: errorLayer(geomAndNot(rmet2_2 RMET2_device) "Error: Number of MET2 resistor terminals != 2")
    Executing: rmet3_1 = geomAnd(met3_withslots geomOr(METRES MET3RES))
    Executing: rmet3_trm = geomAnd(geomAndNot(geomSize(rmet3_1 0.1) rmet3_1) met3_withslots)
    Executing: rmet3_2 = geomGetRectangle(rmet3_1)
    Executing: errorLayer(geomAndNot(rmet3_1 rmet3_2) "Error: MET3 resistors (shorts) must be rectangular")
    Executing: RMET3_device = geomButtOrOver(rmet3_2 rmet3_trm (keep == 2))
    Executing: errorLayer(geomAndNot(rmet3_2 RMET3_device) "Error: Number of MET3 resistor terminals != 2")
    Executing: rmet4_1 = geomAnd(met4_withslots geomOr(METRES MET4RES))
    Executing: rmet4_trm = geomAnd(geomAndNot(geomSize(rmet4_1 0.1) rmet4_1) met4_withslots)
    Executing: rmet4_2 = geomGetRectangle(rmet4_1)
    Executing: errorLayer(geomAndNot(rmet4_1 rmet4_2) "Error: MET4 resistors (shorts) must be rectangular")
    Executing: RMET4_device = geomButtOrOver(rmet4_2 rmet4_trm (keep == 2))
    Executing: errorLayer(geomAndNot(rmet4_2 RMET4_device) "Error: Number of MET4 resistor terminals != 2")
    Executing: net_met1 = geomAndNot(met1_withslots geomCat(spiral_body RMET1_device))
    Executing: net_met2 = geomAndNot(met2_withslots geomCat(spiral_body RMET2_device))
    Executing: net_met3 = geomAndNot(met3_withslots geomCat(spiral_body RMET3_device))
    Executing: net_via1 = geomAndNot(VIA1 spiral_body)
    Executing: net_via2_met2 = geomAndNot(via2_met2 spiral_body)
    Executing: net_metcap = geomCat(METCAP)
    Executing: net_met4 = geomAndNot(met4_withslots geomCat(spiral_body RMET4_device))
    Executing: net_via3 = geomAndNot(VIA3 spiral_body)
    Executing: cblock_met2cap_met2 = geomSize(cmim 0.9)
    Executing: rcxLayer(cblock_met2cap_met2)
    Executing: cblock_met1_fox = geomCat(CPOLYRF_device RPOLY2RF_device NMOSRF_device PMOSRF...
    Executing: rcxLayer(cblock_met1_fox)
    Executing: cblock_poly2_poly1 = geomSize(cpoly 0.9)
    Executing: rcxLayer(cblock_poly2_poly1)
    Executing: cblock_poly1_psub = geomCat(gate HVDEF)
    Executing: rcxLayer(cblock_poly1_psub)
    Executing: MET1_pinshape_bad = geomAndNot(MET1_pinshape net_met1)
           errorLayer(MET1_pinshape_bad "ERROR : MET1 pin outside met1")
    Executing: MET2_pinshape_bad = geomAndNot(MET2_pinshape net_met2)
           errorLayer(MET2_pinshape_bad "ERROR : MET2 pin outside met2")
    Executing: MET3_pinshape_bad = geomAvoiding(geomAndNot(MET3_pinshape net_met3) INDDEF)
           errorLayer(MET3_pinshape_bad "ERROR : MET3 pin outside met3")
    Executing: MET4_pinshape_bad = geomAvoiding(geomAndNot(MET4_pinshape net_met4) INDDEF)
           errorLayer(MET4_pinshape_bad "ERROR : MET4 pin outside met4")
    Executing: net_poly1 = geomOr(net_poly1 POLY1_pinshape)
    Executing: net_met1 = geomOr(net_met1 MET1_pinshape)
    Executing: net_met2 = geomOr(net_met2 MET2_pinshape)
    Executing: net_met3 = geomOr(net_met3 MET3_pinshape)
    Executing: net_met4 = geomOr(net_met4 MET4_pinshape)
    Executing: net_optdef = geomOr(OPTDEF)
    Executing: geomConnect((label POLY1_pintext net_poly1 POLY1_pinshape) (label MET1_pintex...
     See the label report in "trial.erc" file for details.
    Executing: extractMOS("NMOS4" NMOS_device (net_poly1 "G") (net_nsd "S" "D") (net_psub "B...
             2 'NMOS4' created in cell 'trial layout trial'.
    Executing: saveRecognition(NMOS_device "device")
    Executing: w = measureParameter(length (NMOS_device butting net_nsd) 5e-07)
    Executing: l = measureParameter(length (NMOS_device outside net_nsd) 5e-07)
    Executing: w_bends90 = measureParameter(bends_full (NMOS_device butting net_nsd))
    Executing: w_bends45 = measureParameter(bends_part (NMOS_device butting net_nsd))
    Executing: l_bends90 = measureParameter(bends_full (NMOS_device outside net_nsd))
    Executing: l_bends45 = measureParameter(bends_part (NMOS_device outside net_nsd))
    Executing: weff = calculateParameter((w - (l * ((w_bends90 * 0.5) + (w_bends45 * 0.25)))))
    Executing: leff = calculateParameter((l - (w * ((l_bends90 * 0.5) + (l_bends45 * 0.25)))))
    Executing: nameParameter(leff "l")
    Executing: nameParameter(weff "w")
    Executing: nameParameter(weff "wtot")
    Executing: extractDevice("NMOS_WAFFLE" NMOS_WAFFLE_device (net_poly1 "G") (net_nsd "S" "...
    Executing: saveRecognition(NMOS_WAFFLE_device "device")
    Executing: w = measureParameter(length (NMOS_WAFFLE_device butting net_nsd) 5e-07)
    Executing: l = measureParameter(length (NMOS_WAFFLE_device outside net_nsd) 5e-07)
    Executing: nameParameter(l "l")
    Executing: nameParameter(w "w")
    Executing: nameParameter(w "wtot")
    Executing: extractMOS("NMOSM4" NMOSM_device (net_poly1 "G") (net_nsd "S" "D") (net_psub ...
    Executing: saveRecognition(NMOSM_device "device")
    Executing: w = measureParameter(length (NMOSM_device butting net_nsd) 5e-07)
    Executing: l = measureParameter(length (NMOSM_device outside net_nsd) 5e-07)
    Executing: w_bends90 = measureParameter(bends_full (NMOSM_device butting net_nsd))
    Executing: w_bends45 = measureParameter(bends_part (NMOSM_device butting net_nsd))
    Executing: l_bends90 = measureParameter(bends_full (NMOSM_device outside net_nsd))
    Executing: l_bends45 = measureParameter(bends_part (NMOSM_device outside net_nsd))
    Executing: extractDevice("NMOSM_WAFFLE" NMOSM_WAFFLE_device (net_poly1 "G") (net_nsd "S"...
    Executing: saveRecognition(NMOSM_WAFFLE_device "device")
    Executing: w = measureParameter(length (NMOSM_WAFFLE_device butting net_nsd) 5e-07)
    Executing: l = measureParameter(length (NMOSM_WAFFLE_device outside net_nsd) 5e-07)
    Executing: extractMOS("PMOS4" PMOS_device (net_poly1 "G") (net_psd "S" "D") (net_nwell "...
    Executing: saveRecognition(PMOS_device "device")
    Executing: w = measureParameter(length (PMOS_device butting net_psd) 5e-07)
    Executing: l = measureParameter(length (PMOS_device outside net_psd) 5e-07)
    Executing: w_bends90 = measureParameter(bends_full (PMOS_device butting net_psd))
    Executing: w_bends45 = measureParameter(bends_part (PMOS_device butting net_psd))
    Executing: l_bends90 = measureParameter(bends_full (PMOS_device outside net_psd))
    Executing: l_bends45 = measureParameter(bends_part (PMOS_device outside net_psd))
    Executing: extractDevice("PMOS_WAFFLE" PMOS_WAFFLE_device (net_poly1 "G") (net_psd "S" "...
    Executing: saveRecognition(PMOS_WAFFLE_device "device")
    Executing: w = measureParameter(length (PMOS_WAFFLE_device butting net_psd) 5e-07)
    Executing: l = measureParameter(length (PMOS_WAFFLE_device outside net_psd) 5e-07)
    Executing: extractMOS("PMOSM4" PMOSM_device (net_poly1 "G") (net_psd "S" "D") (net_nwell...
    Executing: saveRecognition(PMOSM_device "device")
    Executing: w = measureParameter(length (PMOSM_device butting net_psd) 5e-07)
    Executing: l = measureParameter(length (PMOSM_device outside net_psd) 5e-07)
    Executing: w_bends90 = measureParameter(bends_full (PMOSM_device butting net_psd))
    Executing: w_bends45 = measureParameter(bends_part (PMOSM_device butting net_psd))
    Executing: l_bends90 = measureParameter(bends_full (PMOSM_device outside net_psd))
    Executing: l_bends45 = measureParameter(bends_part (PMOSM_device outside net_psd))
    Executing: extractDevice("PMOSM_WAFFLE" PMOSM_WAFFLE_device (net_poly1 "G") (net_psd "S"...
    Executing: saveRecognition(PMOSM_WAFFLE_device "device")
    Executing: w = measureParameter(length (PMOSM_WAFFLE_device butting net_psd) 5e-07)
    Executing: l = measureParameter(length (PMOSM_WAFFLE_device outside net_psd) 5e-07)
    Executing: extractDevice("RCX_DUMMY" NMOSL_device (net_poly1 "PLUS" "MINUS") (cellView "...
    Executing: extractDevice("RCX_DUMMY" NMOSL_WAFFLE_device (net_poly1 "PLUS" "MINUS") (cel...
    Executing: extractDevice("RCX_DUMMY" NMOSML_device (net_poly1 "PLUS" "MINUS") (cellView ...
    Executing: extractDevice("RCX_DUMMY" NMOSML_WAFFLE_device (net_poly1 "PLUS" "MINUS") (ce...
    Executing: extractDevice("RCX_DUMMY" PMOSL_device (net_poly1 "PLUS" "MINUS") (cellView "...
    Executing: extractDevice("RCX_DUMMY" PMOSL_WAFFLE_device (net_poly1 "PLUS" "MINUS") (cel...
    Executing: extractDevice("RCX_DUMMY" PMOSML_device (net_poly1 "PLUS" "MINUS") (cellView ...
    Executing: extractDevice("RCX_DUMMY" PMOSML_WAFFLE_device (net_poly1 "PLUS" "MINUS") (ce...
    Executing: nmosh_dummy = geomAnd(NMOSH_device net_nwell)
    Executing: extractDevice("NMOSH" NMOSH_device (net_poly1 "G") (net_nsd "S") (nmosh_d_ter...
    Executing: saveRecognition(NMOSH_device "device")
    Executing: attachParameter(l1 "l" NMOSH_device)
    Executing: attachParameter(w1 "w" NMOSH_device)
    Executing: nmosmh_dummy = geomAnd(NMOSMH_device net_nwell)
    Executing: extractDevice("NMOSMH" NMOSMH_device (net_poly1 "G") (net_nsd "S") (nmosh_d_t...
    Executing: saveRecognition(NMOSMH_device "device")
    Executing: attachParameter(l1 "l" NMOSMH_device)
    Executing: attachParameter(w1 "w" NMOSMH_device)
    Executing: extractDevice("RCX_DUMMY" NMOSHL_device (net_poly1 "PLUS" "MINUS") (cellView ...
    Executing: extractDevice("RCX_DUMMY" NMOSMHL_device (net_poly1 "PLUS" "MINUS") (cellView...
    Executing: extractDevice("RCX_DUMMY" NMOS30M_device (net_poly1 "PLUS" "MINUS") (cellView...
    Executing: extractDevice("RCX_DUMMY" NMOS18T_device (net_poly1 "PLUS" "MINUS") (cellView...
    Executing: extractDIODE("ND" ND_device (net_psub "PLUS") (net_nsd "MINUS") (targetLayer ...
    Executing: saveRecognition(ND_device "device")
    Executing: area = measureParameter(area (ND_device) 1e-12)
    Executing: perimeter = measureParameter(length (ND_device over net_psub) 1e-06)
    Executing: nameParameter(area "area")
    Executing: nameParameter(perimeter "perimeter")
    Executing: nameParameter(perimeter "pj")
    Executing: P_ND_device = geomAndNot(geomAndNot(geomAndNot(ndiode_1 DIODE) nmosh_d) HVDEF)
    Executing: extractDevice("RCX_DUMMY" P_ND_device (net_nsd "PLUS" "MINUS") (cellView "pca...
    Executing: extractDIODE("PD" PD_device (net_psd "PLUS") (net_nwell "MINUS") (targetLayer...
    Executing: saveRecognition(PD_device "device")
    Executing: area = measureParameter(area (PD_device) 1e-12)
    Executing: perimeter = measureParameter(length (PD_device over net_psub) 1e-06)
    Executing: extractDevice("RCX_DUMMY" P_PD_device (net_psd "PLUS" "MINUS") (cellView "pca...
    Executing: extractDIODE("NWD" NWD_device (net_psub "PLUS") (net_nwell "MINUS") (targetLa...
    Executing: saveRecognition(NWD_device "device")
    Executing: area = measureParameter(area (NWD_device) 1e-12)
    Executing: perimeter = measureParameter(length (NWD_device over net_psub) 1e-06)
    Executing: extractDevice("RCX_DUMMY" P_NWD_device (net_nwell "PLUS" "MINUS") (cellView "...
    Executing: extractDIODE("ZD2SM24" ZD2SM24_device (net_psd "A") (net_welltap "C") (net_ps...
    Executing: saveRecognition(ZD2SM24_device "device")
    Executing: saveProperty(ZD2SM24_device "m" "1.0")
    Executing: saveProperty(ZD2SM24_device "area" 1.0)
    Executing: saveProperty(ZD2SM24_device "perimeter" 1.0)
    Executing: saveProperty(ZD2SM24_device "pj" 1.0)
    Executing: PHDNWA850_device_ntub = geomButtOrOver(net_nwell PHDNWA850_device)
    Executing: extractDevice("RCX_DUMMY" PHDNWA850_device_ntub (net_nwell "PLUS" "MINUS") (c...
    Executing: SBD5_device_sbdcon = geomButtOrOver(sbdcon SBD5_device)
    Executing: extractDevice("RCX_DUMMY" SBD5_device_sbdcon (net_nwell "PLUS" "MINUS") (cell...
    Executing: geomStamp(net_ndiff_d_sub net_ndiff)
    Executing: geomStamp(net_pdiff_d_ntub net_pdiff)
    Executing: extractDevice("ESDPD18" ESDPD18_device (net_psub "A") (net_nwell "C") (termOr...
    Executing: saveRecognition(ESDPD18_device "device")
    Executing: attachParameter(w "w" ESDPD18_device)
    Executing: attachParameter(l "l" ESDPD18_device)
    Executing: extractDevice("ESDPD26" ESDPD26_device (net_psub "A") (net_nwell "C") (termOr...
    Executing: saveRecognition(ESDPD26_device "device")
    Executing: attachParameter(w "w" ESDPD26_device)
    Executing: attachParameter(l "l" ESDPD26_device)
    Executing: extractDevice("ESDPD30" ESDPD30_device (net_psub "A") (net_nwell "C") (termOr...
    Executing: saveRecognition(ESDPD30_device "device")
    Executing: attachParameter(w "w" ESDPD30_device)
    Executing: attachParameter(l "l" ESDPD30_device)
    Executing: extractDevice("ESDFDN5" ESDFDN5_device (net_psub "A") (net_ndiff_d_sub "C") (...
    Executing: saveRecognition(ESDFDN5_device "device")
    Executing: attachParameter(w "w" ESDFDN5_device)
    Executing: attachParameter(l "l" ESDFDN5_device)
    Executing: extractDevice("ESDGCN5" ESDGCN5_device (net_psub "A") (net_ndiff_d_sub "C") (...
    Executing: saveRecognition(ESDGCN5_device "device")
    Executing: attachParameter(w "w" ESDGCN5_device)
    Executing: attachParameter(l "l" ESDGCN5_device)
    Executing: extractDevice("ESDFDP5" ESDFDP5_device (net_nwell "C") (net_pdiff_d_ntub "A")...
    Executing: saveRecognition(ESDFDP5_device "device")
    Executing: attachParameter(w "w" ESDFDP5_device)
    Executing: attachParameter(l "l" ESDFDP5_device)
    Executing: extractDevice("ESDGCP5" ESDGCP5_device (net_nwell "C") (net_pdiff_d_ntub "A")...
    Executing: saveRecognition(ESDGCP5_device "device")
    Executing: attachParameter(w "w" ESDGCP5_device)
    Executing: attachParameter(l "l" ESDGCP5_device)
    Executing: extractRES("RNWELL" RNWELL_device (net_nwell "PLUS" "MINUS") (net_psub "B") (...
    Executing: saveRecognition(RNWELL_device "device")
    Executing: w = measureParameter(length (RNWELL_device butting nwres_trm) 5e-07)
    Executing: bends90 = measureParameter(bends_full (RNWELL_device over net_psub outside nw...
    Executing: bends45 = measureParameter(bends_part (RNWELL_device over net_psub))
    Executing: l = measureParameter(length (RNWELL_device outside nwres_trm) 5e-07)
    Executing: leff = calculateParameter((l - (w * ((bends90 * 0.5) + (bends45 * 0.084)))))
    Executing: r = calculateParameter(((leff / (w - (1.15 * 1e-06))) * 1000))
    Executing: nameParameter(r "r")
    Executing: extractRES("RDIFFP3" RDIFFP_device (net_psd "PLUS" "MINUS") (net_nwell "B") (...
    Executing: saveRecognition(RDIFFP_device "device")
    Executing: w = measureParameter(length (RDIFFP_device butting pdres_trm) 5e-07)
    Executing: bends90 = measureParameter(bends_full (RDIFFP_device over net_psub outside pd...
    Executing: bends45 = measureParameter(bends_part (RDIFFP_device over net_psub))
    Executing: l = measureParameter(length (RDIFFP_device outside pdres_trm) 5e-07)
    Executing: r = calculateParameter(((leff / (w - (-0.1 * 1e-06))) * 140))
    Executing: ndres_trm = geomButting(RESTRM RDIFFN_device)
    Executing: extractRES("RDIFFN3" RDIFFN_device (net_nsd "PLUS" "MINUS") (net_psub "B") (t...
    Executing: saveRecognition(RDIFFN_device "device")
    Executing: w = measureParameter(length (RDIFFN_device butting ndres_trm) 5e-07)
    Executing: bends90 = measureParameter(bends_full (RDIFFN_device over net_psub outside nd...
    Executing: bends45 = measureParameter(bends_part (RDIFFN_device over net_psub))
    Executing: l = measureParameter(length (RDIFFN_device outside ndres_trm) 5e-07)
    Executing: r = calculateParameter(((leff / (w - (-0.1 * 1e-06))) * 75))
    Executing: RPOLY2_NTUB_device = geomAndNot(geomInside(pres net_nwell) RFDEF)
    Executing: RPOLY2_PSUB_device = geomAndNot(geomAndNot(pres RPOLY2_NTUB_device) RFDEF)
    Executing: pres_ntub_trm = geomButting(pres_trm RPOLY2_NTUB_device)
    Executing: pres_psub_trm = geomButting(pres_trm RPOLY2_PSUB_device)
    Executing: extractRES("RPOLY2" RPOLY2_PSUB_device (net_poly2 "PLUS" "MINUS") (net_psub "...
    Executing: saveRecognition(RPOLY2_PSUB_device "device")
    Executing: w = measureParameter(length (RPOLY2_PSUB_device butting pres_psub_trm) 5e-07)
    Executing: bends90 = measureParameter(bends_full (RPOLY2_PSUB_device over net_psub outsi...
    Executing: bends45 = measureParameter(bends_part (RPOLY2_PSUB_device over net_psub))
    Executing: l = measureParameter(length (RPOLY2_PSUB_device outside pres_psub_trm) 5e-07)
    Executing: r = calculateParameter(((leff / (w - (0.25 * 1e-06))) * 50))
    Executing: ca = measureParameter(area (RPOLY2_PSUB_device) 1.19e-16)
    Executing: cp = measureParameter(length (RPOLY2_PSUB_device outside pres_psub_trm) 5.3e-17)
    Executing: c = calculateParameter((ca + cp))
    Executing: nameParameter(c "cap")
    Executing: saveProperty(RPOLY2_PSUB_device "gwell" "Substrate")
    Executing: extractRES("RPOLY2" RPOLY2_NTUB_device (net_poly2 "PLUS" "MINUS") (net_nwell ...
    Executing: saveRecognition(RPOLY2_NTUB_device "device")
    Executing: w = measureParameter(length (RPOLY2_NTUB_device butting pres_ntub_trm) 5e-07)
    Executing: bends90 = measureParameter(bends_full (RPOLY2_NTUB_device over net_psub outsi...
    Executing: bends45 = measureParameter(bends_part (RPOLY2_NTUB_device over net_psub))
    Executing: l = measureParameter(length (RPOLY2_NTUB_device outside pres_ntub_trm) 5e-07)
    Executing: ca = measureParameter(area (RPOLY2_NTUB_device) 1.19e-16)
    Executing: cp = measureParameter(length (RPOLY2_NTUB_device outside pres_ntub_trm) 5.3e-17)
    Executing: saveProperty(RPOLY2_NTUB_device "gwell" "N-Well")
    Executing: RPOLY2P_NTUB_device = geomAndNot(geomInside(presp net_nwell) RFDEF)
    Executing: RPOLY2P_PSUB_device = geomAndNot(geomAndNot(presp RPOLY2P_NTUB_device) RFDEF)
    Executing: extractDevice("RCX_DUMMY" RPOLY2P_PSUB_device (net_poly2 "PLUS" "MINUS") (cel...
    Executing: extractDevice("RCX_DUMMY" RPOLY2P_NTUB_device (net_poly2 "PLUS" "MINUS") (cel...
    Executing: RPOLY2PH_NTUB_device = geomAndNot(geomInside(presph net_nwell) RFDEF)
    Executing: RPOLY2PH_PSUB_device = geomAndNot(geomAndNot(presph RPOLY2PH_NTUB_device) RFDEF)
    Executing: presph_ntub_trm = geomButting(presph_trm RPOLY2PH_NTUB_device)
    Executing: presph_psub_trm = geomButting(presph_trm RPOLY2PH_PSUB_device)
    Executing: extractRES("RPOLY2PH" RPOLY2PH_PSUB_device (net_poly2 "PLUS" "MINUS") (net_ps...
    Executing: saveRecognition(RPOLY2PH_PSUB_device "device")
    Executing: w = measureParameter(length (RPOLY2PH_PSUB_device butting presph_psub_trm) 5e...
    Executing: bends90 = measureParameter(bends_full (RPOLY2PH_PSUB_device over net_psub out...
    Executing: bends45 = measureParameter(bends_part (RPOLY2PH_PSUB_device over net_psub))
    Executing: l = measureParameter(length (RPOLY2PH_PSUB_device outside presph_psub_trm) 5e...
    Executing: ca = measureParameter(area (RPOLY2PH_PSUB_device) 1.19e-16)
    Executing: cp = measureParameter(length (RPOLY2PH_PSUB_device outside presph_psub_trm) 5...
    Executing: saveProperty(RPOLY2PH_PSUB_device "gwell" "Substrate")
    Executing: extractRES("RPOLY2PH" RPOLY2PH_NTUB_device (net_poly2 "PLUS" "MINUS") (net_nw...
    Executing: saveRecognition(RPOLY2PH_NTUB_device "device")
    Executing: w = measureParameter(length (RPOLY2PH_NTUB_device butting presph_ntub_trm) 5e...
    Executing: bends90 = measureParameter(bends_full (RPOLY2PH_NTUB_device over net_psub out...
    Executing: bends45 = measureParameter(bends_part (RPOLY2PH_NTUB_device over net_psub))
    Executing: l = measureParameter(length (RPOLY2PH_NTUB_device outside presph_ntub_trm) 5e...
    Executing: ca = measureParameter(area (RPOLY2PH_NTUB_device) 1.19e-16)
    Executing: cp = measureParameter(length (RPOLY2PH_NTUB_device outside presph_ntub_trm) 5...
    Executing: saveProperty(RPOLY2PH_NTUB_device "gwell" "N-Well")
    Executing: RPOLYH_NTUB_device = geomAndNot(geomInside(presh net_nwell) RFDEF)
    Executing: RPOLYH_PSUB_device = geomAndNot(geomAndNot(presh RPOLYH_NTUB_device) RFDEF)
    Executing: presh_ntub_trm = geomButting(presh_trm RPOLYH_NTUB_device)
    Executing: presh_psub_trm = geomButting(presh_trm RPOLYH_PSUB_device)
    Executing: extractRES("RPOLYH" RPOLYH_PSUB_device (net_poly2 "PLUS" "MINUS") (net_psub "...
    Executing: saveRecognition(RPOLYH_PSUB_device "device")
    Executing: w = measureParameter(length (RPOLYH_PSUB_device butting presh_psub_trm) 5e-07)
    Executing: bends90 = measureParameter(bends_full (RPOLYH_PSUB_device over net_psub outsi...
    Executing: bends45 = measureParameter(bends_part (RPOLYH_PSUB_device over net_psub))
    Executing: l = measureParameter(length (RPOLYH_PSUB_device outside presh_psub_trm) 5e-07)
    Executing: r = calculateParameter(((leff / (w - (0.2 * 1e-06))) * 1200))
    Executing: ca = measureParameter(area (RPOLYH_PSUB_device) 1.19e-16)
    Executing: cp = measureParameter(length (RPOLYH_PSUB_device outside presh_psub_trm) 5.3e...
    Executing: saveProperty(RPOLYH_PSUB_device "gwell" "Substrate")
    Executing: extractRES("RPOLYH" RPOLYH_NTUB_device (net_poly2 "PLUS" "MINUS") (net_nwell ...
    Executing: saveRecognition(RPOLYH_NTUB_device "device")
    Executing: w = measureParameter(length (RPOLYH_NTUB_device butting presh_ntub_trm) 5e-07)
    Executing: bends90 = measureParameter(bends_full (RPOLYH_NTUB_device over net_psub outsi...
    Executing: bends45 = measureParameter(bends_part (RPOLYH_NTUB_device over net_psub))
    Executing: l = measureParameter(length (RPOLYH_NTUB_device outside presh_ntub_trm) 5e-07)
    Executing: ca = measureParameter(area (RPOLYH_NTUB_device) 1.19e-16)
    Executing: cp = measureParameter(length (RPOLYH_NTUB_device outside presh_ntub_trm) 5.3e...
    Executing: saveProperty(RPOLYH_NTUB_device "gwell" "N-Well")
    Executing: RPOLYZ_NTUB_device = geomAndNot(geomInside(presz net_nwell) RFDEF)
    Executing: RPOLYZ_PSUB_device = geomAndNot(geomAndNot(presz RPOLYZ_NTUB_device) RFDEF)
    Executing: extractDevice("RCX_DUMMY" RPOLYZ_PSUB_device (net_poly2 "PLUS" "MINUS") (cell...
    Executing: extractDevice("RCX_DUMMY" RPOLYZ_NTUB_device (net_poly2 "PLUS" "MINUS") (cell...
    Executing: RPOLY1_NTUB_device = geomAndNot(geomInside(pres1 net_nwell) RFDEF)
    Executing: RPOLY1_PSUB_device = geomAndNot(geomAndNot(pres1 RPOLY1_NTUB_device) RFDEF)
    Executing: pres1_ntub_trm = geomButting(pres1_trm RPOLY1_NTUB_device)
    Executing: pres1_psub_trm = geomButting(pres1_trm RPOLY1_PSUB_device)
    Executing: extractRES("RPOLY1" RPOLY1_PSUB_device (net_poly1 "PLUS" "MINUS") (net_psub "...
    Executing: saveRecognition(RPOLY1_PSUB_device "device")
    Executing: w = measureParameter(length (RPOLY1_PSUB_device butting pres1_psub_trm) 5e-07)
    Executing: bends90 = measureParameter(bends_full (RPOLY1_PSUB_device over net_psub outsi...
    Executing: bends45 = measureParameter(bends_part (RPOLY1_PSUB_device over net_psub))
    Executing: l = measureParameter(length (RPOLY1_PSUB_device outside pres1_psub_trm) 5e-07)
    Executing: r = calculateParameter(((leff / (w - (0.05 * 1e-06))) * 8))
    Executing: ca = measureParameter(area (RPOLY1_PSUB_device) 1.19e-16)
    Executing: cp = measureParameter(length (RPOLY1_PSUB_device outside pres1_psub_trm) 5.3e...
    Executing: saveProperty(RPOLY1_PSUB_device "gwell" "Substrate")
    Executing: extractRES("RPOLY1" RPOLY1_NTUB_device (net_poly1 "PLUS" "MINUS") (net_nwell ...
    Executing: saveRecognition(RPOLY1_NTUB_device "device")
    Executing: w = measureParameter(length (RPOLY1_NTUB_device butting pres1_ntub_trm) 5e-07)
    Executing: bends90 = measureParameter(bends_full (RPOLY1_NTUB_device over net_psub outsi...
    Executing: bends45 = measureParameter(bends_part (RPOLY1_NTUB_device over net_psub))
    Executing: l = measureParameter(length (RPOLY1_NTUB_device outside pres1_ntub_trm) 5e-07)
    Executing: ca = measureParameter(area (RPOLY1_NTUB_device) 1.19e-16)
    Executing: cp = measureParameter(length (RPOLY1_NTUB_device outside pres1_ntub_trm) 5.3e...
    Executing: saveProperty(RPOLY1_NTUB_device "gwell" "N-Well")
    Executing: geomStamp(rmet1_trm net_met1)
    Executing: extractRES("SHORT" RMET1_device (rmet1_trm "PLUS" "MINUS") (cellView "short a...
    Executing: w = measureParameter(length (RMET1_device butting rmet1_trm) 5e-07)
    Executing: l = measureParameter(length (RMET1_device outside rmet1_trm) 5e-07)
    Executing: r = calculateParameter(((l / (w - (0 * 1e-06))) * 0.07))
    Executing: geomStamp(rmet2_trm net_met2)
    Executing: extractRES("SHORT" RMET2_device (rmet2_trm "PLUS" "MINUS") (cellView "short a...
    Executing: w = measureParameter(length (RMET2_device butting rmet2_trm) 5e-07)
    Executing: l = measureParameter(length (RMET2_device outside rmet2_trm) 5e-07)
    Executing: r = calculateParameter(((l / (w - (0.1 * 1e-06))) * 0.07))
    Executing: geomStamp(rmet3_trm net_met3)
    Executing: extractRES("SHORT" RMET3_device (rmet3_trm "PLUS" "MINUS") (cellView "short a...
    Executing: w = measureParameter(length (RMET3_device butting rmet3_trm) 5e-07)
    Executing: l = measureParameter(length (RMET3_device outside rmet3_trm) 5e-07)
    Executing: geomStamp(rmet4_trm net_met4)
    Executing: extractRES("SHORT" RMET4_device (rmet4_trm "PLUS" "MINUS") (cellView "short a...
    Executing: w = measureParameter(length (RMET4_device butting rmet4_trm) 5e-07)
    Executing: l = measureParameter(length (RMET4_device outside rmet4_trm) 5e-07)
    Executing: r = calculateParameter(((l / (w - (0 * 1e-06))) * 0.04))
    Executing: geomStamp(pnplat2_c net_psd)
    Executing: geomStamp(pnplat2_e net_psd)
    Executing: extractDevice("LAT2" LAT2_device (net_poly1 "G") (pnplat2_e "E") (pnplat2_c "...
    Executing: saveRecognition(LAT2_device "device")
    Executing: saveProperty(LAT2_device "m" "1.0")
    Executing: saveProperty(LAT2_device "area" 1)
    Executing: geomStamp(pnpvert10_e net_psd)
    Executing: pnpvert10_c = geomCat(net_psub)
    Executing: geomStamp(pnpvert10_c net_psub)
    Executing: extractBJT("PNPVERT10" VERT10_device (pnpvert10_c "C") (net_welltap "B") (pnp...
    Executing: saveRecognition(VERT10_device "device")
    Executing: saveProperty(VERT10_device "m" "1.0")
    Executing: saveProperty(VERT10_device "area" 1.0)
    Executing: saveProperty(VERT10_device "ea" 1.0)
    Executing: CPOLY_NTUB_device = geomAndNot(geomAnd(cpoly net_nwell) RFDEF)
    Executing: CPOLY_PSUB_device = geomAndNot(geomAndNot(cpoly net_nwell) RFDEF)
    Executing: extractCAP("CPOLYA" CPOLY_PSUB_device (net_poly2 "PLUS") (net_poly1 "MINUS") ...
    Executing: saveRecognition(CPOLY_PSUB_device "device")
    Executing: a = measureParameter(area (CPOLY_PSUB_device) 1e-12)
    Executing: p = measureParameter(perimeter (CPOLY_PSUB_device) 1e-06)
    Executing: c = calculateParameter(((a * 8.6e-16 * 1e+12) + (p * 8.6e-17 * 1000000.0)))
    Executing: nameParameter(c "c")
    Executing: nameParameter(a "area")
    Executing: nameParameter(p "perimeter")
    Executing: nameParameter(a "a")
    Executing: nameParameter(p "p")
    Executing: saveProperty(CPOLY_PSUB_device "gwell" "Substrate")
    Executing: extractCAP("CPOLYA" CPOLY_NTUB_device (net_poly2 "PLUS") (net_poly1 "MINUS") ...
    Executing: saveRecognition(CPOLY_NTUB_device "device")
    Executing: a = measureParameter(area (CPOLY_NTUB_device) 1e-12)
    Executing: p = measureParameter(perimeter (CPOLY_NTUB_device) 1e-06)
    Executing: saveProperty(CPOLY_NTUB_device "gwell" "N-Well")
    Executing: cvar_ele = geomOr(cvar)
    Executing: cvar_ndiff = geomEnclose(ndiff_1 cvar_ele)
    Executing: cvar_ndiff_gap = drc(cvar_ndiff (sep < 1.8) opposite parallel)
    Executing: cvar_ndiff_closed = geomOr(cvar_ndiff cvar_ndiff_gap)
    Executing: net1_cvar = geomButtOrOver(net_poly1 cvar_ele)
    Executing: cvar_ndiff_cross1 = geomGetEdge(cvar_ndiff_closed inside net1_cvar)
    Executing: cvar_ndiff_cross = geomSize(cvar_ndiff_cross1 -0.1 edges)
    Executing: CVAR_device = geomOr(cvar_ndiff_closed)
    Executing: extractDevice("CVAR" CVAR_device (net_poly1 "G") (net_welltap "B") (net_psub ...
    Executing: saveRecognition(CVAR_device "device")
    Executing: attachParameter(lc "l" CVAR_device)
    Executing: attachParameter(wc "w" CVAR_device)
    Executing: count_elements = measureParameter(figCount (CVAR_device enclosing cvar_ele))
    Executing: cols = measureParameter(figCount (CVAR_device enclosing cvar_ndiff_cross) 0.5)
    Executing: rows = calculateParameter((count_elements / cols))
    Executing: nameParameter(rows "row")
    Executing: nameParameter(cols "col")
    Executing: extractDevice("RCX_DUMMY" CMIM_device (net_metcap "PLUS" "MINUS") (cellView "...
    Executing: PROBE_device = geomCat(PROBE)
    Executing: extractDevice("probepad" PROBE_device (net_met4 "PAD") (cellView "probepad au...
    Executing: saveRecognition(PROBE_device "device")
    Executing: nmosrf_nsd = geomButtOrOver(net_nsd NMOSRF_device)
    Executing: extractDevice("NMOSRF" NMOSRF_device (net_poly1 "G") (net_nsd "S" "D") (net_p...
    Executing: saveRecognition(NMOSRF_device "device")
    Executing: attachParameter(lc "l" NMOSRF_device)
    Executing: attachParameter(wc "w" NMOSRF_device)
    Executing: attachParameter(count_elements "ng" NMOSRF_device)
    Executing: attachParameter(as "as" NMOSRF_device)
    Executing: attachParameter(as "ad" NMOSRF_device)
    Executing: attachParameter(ps "ps" NMOSRF_device)
    Executing: attachParameter(ps "pd" NMOSRF_device)
    Executing: pmosrf_psd = geomButtOrOver(net_psd PMOSRF_device)
    Executing: extractDevice("PMOSRF" PMOSRF_device (net_poly1 "G") (net_psd "S" "D") (net_n...
    Executing: saveRecognition(PMOSRF_device "device")
    Executing: attachParameter(lc "l" PMOSRF_device)
    Executing: attachParameter(wc "w" PMOSRF_device)
    Executing: attachParameter(count_elements "ng" PMOSRF_device)
    Executing: attachParameter(as "as" PMOSRF_device)
    Executing: attachParameter(as "ad" PMOSRF_device)
    Executing: attachParameter(ps "ps" PMOSRF_device)
    Executing: attachParameter(ps "pd" PMOSRF_device)
    Executing: cpolyrf_capbod = geomInside(cpoly CPOLYRF_device)
    Executing: extractCAP("CPOLYRF" CPOLYRF_device (net_poly2 "PLUS") (net_poly1 "MINUS") (n...
    Executing: saveRecognition(CPOLYRF_device "device")
    Executing: attachParameter(w "w" CPOLYRF_device)
    Executing: attachParameter(l "l" CPOLYRF_device)
    Executing: attachParameter(c "c" CPOLYRF_device)
    Executing: attachParameter(a "area" CPOLYRF_device)
    Executing: attachParameter(p "perimeter" CPOLYRF_device)
    Executing: attachParameter(a "a" CPOLYRF_device)
    Executing: attachParameter(p "p" CPOLYRF_device)
    Executing: saveProperty(CPOLYRF_device "gwell" "N-Well")
    Executing: rpoly2rf_resbod = geomInside(pres RPOLY2RF_device)
    Executing: pres_ntub_trm = geomButting(pres_trm rpoly2rf_resbod)
    Executing: extractRES("RPOLY2RF" RPOLY2RF_device (net_poly2 "PLUS" "MINUS") (net_nwell "...
    Executing: saveRecognition(RPOLY2RF_device "device")
    Executing: attachParameter(c "cap" RPOLY2RF_device)
    Executing: attachParameter(leff "l" RPOLY2RF_device)
    Executing: attachParameter(w "w" RPOLY2RF_device)
    Executing: attachParameter(r "r" RPOLY2RF_device)
    Executing: attachParameter(bends "Bends" RPOLY2RF_device)
    Executing: saveProperty(RPOLY2RF_device "gwell" "N-Well")
    Executing: rpolyhrf_resbod = geomInside(presh RPOLYHRF_device)
    Executing: preshrf_ntub_trm = geomButting(presh_trm rpolyhrf_resbod)
    Executing: extractRES("RPOLYHRF" RPOLYHRF_device (net_poly2 "PLUS" "MINUS") (net_nwell "...
    Executing: saveRecognition(RPOLYHRF_device "device")
    Executing: attachParameter(c "cap" RPOLYHRF_device)
    Executing: attachParameter(leff "l" RPOLYHRF_device)
    Executing: attachParameter(w "w" RPOLYHRF_device)
    Executing: attachParameter(r "r" RPOLYHRF_device)
    Executing: saveProperty(RPOLYHRF_device "gwell" "N-Well")
    Executing: extractDevice("SP014S300D" SP014S300D_device (spiral_term11 "P1") (spiral_ter...
    Executing: saveRecognition(SP014S300D_device "device")
    Executing: extractDevice("SP020S180D" SP020S180D_device (spiral_term11 "P1") (spiral_ter...
    Executing: saveRecognition(SP020S180D_device "device")
    Executing: extractDevice("SP026S200D" SP026S200D_device (spiral_term11 "P1") (spiral_ter...
    Executing: saveRecognition(SP026S200D_device "device")
    Executing: extractDevice("SP037S180D" SP037S180D_device (spiral_term11 "P1") (spiral_ter...
    Executing: saveRecognition(SP037S180D_device "device")
    Executing: extractDevice("SP047S180D" SP047S180D_device (spiral_term11 "P1") (spiral_ter...
    Executing: saveRecognition(SP047S180D_device "device")
    Executing: extractDevice("SP050S155D" SP050S155D_device (spiral_term11 "P1") (spiral_ter...
    Executing: saveRecognition(SP050S155D_device "device")
    Executing: extractDevice("SP090S155D" SP090S155D_device (spiral_term11 "P1") (spiral_ter...
    Executing: saveRecognition(SP090S155D_device "device")
    Finished running rules. Task processor time in main process:
    cpu: 0.39  elap: 0  pf: 0  in: 0  out: 800  virt: 145M  phys: 683M
    No output post-processing: This is not a DRC run
    Finished building the persistent database.
    cpu: 0.01  elap: 0  pf: 0  in: 0  out: 6448  virt: 145M  phys: 691M
    *****  aveng terminated normally  *****
    Finished /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/aveng
    Starting /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/avrpt /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.rsf
    Loading all available p-cell functions
    AMS_DB set to cds
    No mx check
    ROD pcell code loaded
    Loading tech rule set file : /home/cdseng/dkits/ams_400/assura/c35b4/c35b4c3/techRuleSets
    @(#)$CDS: avrpt_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.485 07/07/2010 03:49 (sjfql241) $
    sub-version 4.1_USR1_HF10, integ signature 2010-07-07-0307
    run on connel.see.ed.ac.uk from /home/cdseng/tools/cds_201011/ASSURAOA41/tools.lnx86/assura/bin/64bit/avrpt on Sun Apr 15 09:30:19 2012
       Creating Error Database 'trial'...
       Reading VDB ...
    Rule      Message                                    FlatCount     RealCount
    (    1)  dataAuditErrors                                     0            0
    (    2)  DEVICE Error: Illegal nmosh device                  0            0
    (    3)  DEVICE Error: CVAR_device missing RFDEF             0            0
    (    4)  Process Modules : PHDNWA850 not availabl            0            0
    (    5)  Version od SBD5 obsolte or missing                  0            0
    (    6)  Process Modules : SBD5 not available for            0            0
    (    7)  Process Modules : NMOS30M not available             0            0
    (    8)  Process Modules : NMOS18T not available             0            0
    (    9)  ERC Warning : Name of Spiral not identif            0            0
    (   10)  ERC Warning : INDDEF does not define a c            0            0
    (   11)  ERC Warning : illegal layer under spiral            0            0
    (   12)  Error: MET1 resistors (shorts) must be r            0            0
    (   13)  Error: Number of MET1 resistor terminals            0            0
    (   14)  Error: MET2 resistors (shorts) must be r            0            0
    (   15)  Error: Number of MET2 resistor terminals            0            0
    (   16)  Error: MET3 resistors (shorts) must be r            0            0
    (   17)  Error: Number of MET3 resistor terminals            0            0
    (   18)  Error: MET4 resistors (shorts) must be r            0            0
    (   19)  Error: Number of MET4 resistor terminals            0            0
    (   20)  ERROR : MET1 pin outside met1                       0            0
    (   21)  ERROR : MET2 pin outside met2                       0            0
    (   22)  ERROR : MET3 pin outside met3                       0            0
    (   23)  ERROR : MET4 pin outside met4                       0            0
    (   24)  malformed device NMOSH_device                       0            0
    (   25)  malformed device NMOSMH_device                      0            0
    (   26)  malformed device ESDPD18_device                     0            0
    (   27)  malformed device ESDPD26_device                     0            0
    (   28)  malformed device ESDPD30_device                     0            0
    (   29)  malformed device ESDFDN5_device                     0            0
    (   30)  malformed device ESDGCN5_device                     0            0
    (   31)  malformed device ESDFDP5_device                     0            0
    (   32)  malformed device ESDGCP5_device                     0            0
    (   33)  malformed device RNWELL_device                      0            0
    (   34)  malformed device RDIFFP_device                      0            0
    (   35)  malformed device RPOLY2_PSUB_device                 0            0
    (   36)  malformed device RPOLY2_NTUB_device                 0            0
    (   37)  malformed device RPOLY2PH_PSUB_device               0            0
    (   38)  malformed device RPOLY2PH_NTUB_device               0            0
    (   39)  malformed device RPOLYH_PSUB_device                 0            0
    (   40)  malformed device RPOLYH_NTUB_device                 0            0
    (   41)  malformed device RPOLY1_PSUB_device                 0            0
    (   42)  malformed device RPOLY1_NTUB_device                 0            0
    (   43)  malformed device LAT2_device                        0            0
    (   44)  malformed device VERT10_device                      0            0
    (   45)  malformed device CPOLY_PSUB_device                  0            0
    (   46)  malformed device CPOLY_NTUB_device                  0            0
    (   47)  malformed device CVAR_device                        0            0
    (   48)  malformed device PROBE_device                       0            0
    (   49)  malformed device NMOSRF_device                      0            0
    (   50)  malformed device PMOSRF_device                      0            0
    (   51)  malformed device CPOLYRF_device                     0            0
    (   52)  malformed device RPOLY2RF_device                    0            0
    (   53)  malformed device RPOLYHRF_device                    0            0
    (   54)  malformed device SP014S300D_device                  0            0
    (   55)  malformed device SP020S180D_device                  0            0
    (   56)  malformed device SP026S200D_device                  0            0
    (   57)  malformed device SP037S180D_device                  0            0
    (   58)  malformed device SP047S180D_device                  0            0
    (   59)  malformed device SP050S155D_device                  0            0
    (   60)  malformed device SP090S155D_device                  0            0
    (   61)  unstable device for SP090S155D_device_De            0            0
    (   62)  unstable device for SP050S155D_device_De            0            0
    (   63)  unstable device for SP047S180D_device_De            0            0
    (   64)  unstable device for SP037S180D_device_De            0            0
    (   65)  unstable device for SP026S200D_device_De            0            0
    (   66)  unstable device for SP020S180D_device_De            0            0
    (   67)  unstable device for SP014S300D_device_De            0            0
    (   68)  unstable device for RPOLYHRF_device_RES_            0            0
    (   69)  unstable device for RPOLY2RF_device_RES_            0            0
    (   70)  unstable device for CPOLYRF_device_CAP_6            0            0
    (   71)  unstable device for PMOSRF_device_Device            0            0
    (   72)  unstable device for NMOSRF_device_Device            0            0
    (   73)  unstable device for PROBE_device_Device_            0            0
    (   74)  unstable device for CMIM_device_Device_6            0            0
    (   75)  unstable device for CVAR_device_Device_6            0            0
    (   76)  unstable device for CPOLY_NTUB_device_CA            0            0
    (   77)  unstable device for CPOLY_PSUB_device_CA            0            0
    (   78)  unstable device for VERT10_device_BJT_59            0            0
    (   79)  unstable device for LAT2_device_Device_5            0            0
    (   80)  unstable device for RMET4_device_RES_57             0            0
    (   81)  unstable device for RMET3_device_RES_56             0            0
    (   82)  unstable device for RMET2_device_RES_55             0            0
    (   83)  unstable device for RMET1_device_RES_54             0            0
    (   84)  unstable device for RPOLY1_NTUB_device_R            0            0
    (   85)  unstable device for RPOLY1_PSUB_device_R            0            0
    (   86)  unstable device for RPOLYZ_NTUB_device_D            0            0
    (   87)  unstable device for RPOLYZ_PSUB_device_D            0            0
    (   88)  unstable device for RPOLYH_NTUB_device_R            0            0
    (   89)  unstable device for RPOLYH_PSUB_device_R            0            0
    (   90)  unstable device for RPOLY2PH_NTUB_device            0            0
    (   91)  unstable device for RPOLY2PH_PSUB_device            0            0
    (   92)  unstable device for RPOLY2P_NTUB_device_            0            0
    (   93)  unstable device for RPOLY2P_PSUB_device_            0            0
    (   94)  unstable device for RPOLY2_NTUB_device_R            0            0
    (   95)  unstable device for RPOLY2_PSUB_device_R            0            0
    (   96)  unstable device for RDIFFN_device_RES_41            0            0
    (   97)  unstable device for RDIFFP_device_RES_40            0            0
    (   98)  unstable device for RNWELL_device_RES_39            0            0
    (   99)  unstable device for ESDGCP5_device_Devic            0            0
    (  100)  unstable device for ESDFDP5_device_Devic            0            0
    (  101)  unstable device for ESDGCN5_device_Devic            0            0
    (  102)  unstable device for ESDFDN5_device_Devic            0            0
    (  103)  unstable device for ESDPD30_device_Devic            0            0
    (  104)  unstable device for ESDPD26_device_Devic            0            0
    (  105)  unstable device for ESDPD18_device_Devic            0            0
    (  106)  unstable device for SBD5_device_sbdcon_D            0            0
    (  107)  unstable device for PHDNWA850_device_ntu            0            0
    (  108)  unstable device for ZD2SM24_device_DIODE            0            0
    (  109)  unstable device for P_NWD_device_Device_            0            0
    (  110)  unstable device for NWD_device_DIODE_27             0            0
    (  111)  unstable device for P_PD_device_Device_2            0            0
    (  112)  unstable device for PD_device_DIODE_25              0            0
    (  113)  unstable device for P_ND_device_Device_2            0            0
    (  114)  unstable device for ND_device_DIODE_23              0            0
    (  115)  unstable device for NMOS18T_device_Devic            0            0
    (  116)  unstable device for NMOS30M_device_Devic            0            0
    (  117)  unstable device for NMOSMHL_device_Devic            0            0
    (  118)  unstable device for NMOSHL_device_Device            0            0
    (  119)  unstable device for NMOSMH_device_Device            0            0
    (  120)  unstable device for NMOSH_device_Device_            0            0
    (  121)  unstable device for PMOSML_WAFFLE_device            0            0
    (  122)  unstable device for PMOSML_device_Device            0            0
    (  123)  unstable device for PMOSL_WAFFLE_device_            0            0
    (  124)  unstable device for PMOSL_device_Device_            0            0
    (  125)  unstable device for NMOSML_WAFFLE_device            0            0
    (  126)  unstable device for NMOSML_device_Device            0            0
    (  127)  unstable device for NMOSL_WAFFLE_device_            0            0
    (  128)  unstable device for NMOSL_device_Device_            0            0
    (  129)  unstable device for PMOSM_WAFFLE_device_            0            0
    (  130)  unstable device for PMOSM_device_MOS_7              0            0
    (  131)  unstable device for PMOS_WAFFLE_device_D            0            0
    (  132)  unstable device for PMOS_device_MOS_5               0            0
    (  133)  unstable device for NMOSM_WAFFLE_device_            0            0
    (  134)  unstable device for NMOSM_device_MOS_3              0            0
    (  135)  unstable device for NMOS_WAFFLE_device_D            0            0
    (  136)  unstable device for NMOS_device_MOS_1               0            0
    Total  errors:                                               0            0
       Finished creating Error Database ...
       Writing Report into /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.err ...
    avrpt cpu sec:    0.11  elapsed:     1  virtual:    93M
    Finished /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/avrpt
    Starting /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/avcallproc /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.rsf -exec1 -LVS -cdslib /home/s1147823/cad_temp/cds.lib
    AMS_DB set to cds
    No mx check
    Finished /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/avcallproc
    Starting /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/avnx /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.rsf -exec1 -LVS -cdslib /home/s1147823/cad_temp/cds.lib
    Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.06s.
    AMS_DB set to cds
    No mx check
    Checking out license for Assura_LVS 4.10
    @(#)$CDS: avnx_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.485 07/07/2010 03:49 (sjfql241) $
    run on connel.see.ed.ac.uk from /home/cdseng/tools/cds_201011/ASSURAOA41/tools.lnx86/assura/bin/64bit/avnx on Sun Apr 15 09:30:20 2012
    avnx started...
    cpu: 0.17  elap: 0  pf: 0  in: 0  out: 16  virt: 401M  phys: 706M
    Run time =  0.00 seconds
    CPU time =  0.23 seconds
                      End of Summary Report
    cpu: 0.01  elap: 1  pf: 0  in: 0  out: 12960  virt: 330M  phys: 706M
    ***** avnx terminated normally *****
    Finished /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/avnx
    Starting /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/nvn /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.rsf -postExtract -exec1 -cdslib /home/s1147823/cad_temp/cds.lib
    @(#)$CDS: nvn_64 version av4.1:Production:dfII6.1.4-64b:IC6.1.4-64b.485 07/07/2010 03:51 (sjfql241) $
    run on connel.see.ed.ac.uk at Sun Apr 15 09:30:21 2012
    AMS_DB set to cds
    No mx check
    Reading schematic network
    Reading layout network
     inputting network ASSURA_LVS/trial/trial.ldb
    Preprocessing schematic network phase 1
    Preprocessing layout network phase 1
     WARNING (AVLVSNN-10050) : mosDevice - cell 'PMOSML_WAFFLE' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'PMOSL_WAFFLE' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'NMOSML_WAFFLE' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'NMOSL_WAFFLE' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'PMOSM_WAFFLE' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'PMOS_WAFFLE' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'NMOSM_WAFFLE' not found.
     WARNING (AVLVSNN-10050) : mosDevice - cell 'NMOS_WAFFLE' not found.
     WARNING (AVLVSNN-10050) : lddDevice - cell 'NMOSMHL' not found.
     WARNING (AVLVSNN-10050) : lddDevice - cell 'NMOSHL' not found.
     WARNING (AVLVSNN-10050) : lddDevice - cell 'NMOSMH' not found.
     WARNING (AVLVSNN-10050) : lddDevice - cell 'NMOSH' not found.
     WARNING (AVLVSNN-10050) : lddDevice - cell 'NMOS18T' not found.
     WARNING (AVLVSNN-10050) : lddDevice - cell 'NMOS30M' not found.
    *WARNING* deleteCellPin - Unable to find cell 'RPOLYZ'
    *WARNING* deleteCellPin - Unable to find cell 'RPOLYM'
    *WARNING* deleteCellPin - Unable to find cell 'RPOLYH'
    *WARNING* deleteCellPin - Unable to find cell 'RPOLY2PH'
    *WARNING* deleteCellPin - Unable to find cell 'RPOLY2P'
    *WARNING* deleteCellPin - Unable to find cell 'RPOLY2'
    *WARNING* deleteCellPin - Unable to find cell 'RPOLY1'
    *WARNING* deleteCellPin - Unable to find cell 'PNPVERT10'
    *WARNING* deleteCellPin - Unable to find cell 'PNPVERT15'
     WARNING (AVLVSNN-10035) : bindingFile/bind rule - layout cell 'NMOS_WAFFLE' is not found and
     will be considered a dummy cell. The default binding for schematic cell 'NMOS4(MOS)' will be broken.
    Preprocessing schematic network phase 2
    Preprocessing layout network phase 2
    Top cell  trial schematic trial vs trial layout trial
    Compare errors, please see /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.csm and /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.cls files.
    cpu=0.00m  wall=0.00m  mem=42.26mb
    Finished /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/nvn
    Starting /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/vldbToRpa trial.snn trial.tre trial.cel
    Finished /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/vldbToRpa
    Starting /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/ercChk /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.rsf
    AMS_DB set to cds
    No mx check
    Finished /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/ercChk
    Starting /home/cdseng/tools/cds_201011/ASSURAOA41//tools/assura/bin/avcallproc /home/s1147823/cad_temp/ASSURA_LVS/trial/trial.rsf -trp -exec1
    AMS_DB set to cds
    No mx check
    Assura LVS terminated normally.
    Run ended: Sun Apr 15 09:30:22 2012
    *****  Assura terminated normally  *****
    Please advise
    Thanks in advance
    Best regards
    Aravind
  • Quek
    Quek over 14 years ago
    Hi Aravind
    Hope that you do not mind a gentle reminder that it is actually not good to cut and paste the entire log file into the reply because it makes the post too long and unreadable for others. : )  The log file should be simply uploaded as an attachment.
    Actually the log file does not contain any information on your lvs error. You should have uploaded the cls file instead. This means the file with the .cls extension in your run directory. It would really be a little hard to troubleshoot lvs shorts without any testcase so I think perhaps you should give it one more try yourself and if it is not possible for you to resolve the problem, you can file a service request to your local Cadence support through your supervisor.
    Best regards
    Quek
  • mailavj
    mailavj over 14 years ago
     Hello Quek
    I am really sorry for the long paste. Please find the sample schematics, layout, CLS file and LVS log files attached. (I zipped them all into one file since i was unable to attach one by one)
    Thanks and regards
    Aravind
    trial.zip
  • Quek
    Hi Aravind
    Thanks for the files. The bulk net of your nmos devices are not connected. In the schematic, you had connected the bulk net to "gnd" but you do not have any m1-psub vias on your layout gnd net. Please add an m1-psub via and it should resolve the problem. Your pdk might name it as "m1-diff" or "m1-pimp", etc. Please select the appropriate via.
    Best regards
    Quek
  • mailavj
     Hello Quek
    Thank you very much for the reply
    Solved all my problems.
    Have a great day ahead :)
    Warm regards
    Aravind
  • Quek
    Hi Aravind
    Thanks for the update. : )
    Best regards
    Quek
  • mailavj
     Thank you again
    Regards
    Aravind
