  3. Why spectre generated-netlist always show the wrong subckt...
  • Subscribers 132
  • Views 3378
Why spectre generated-netlist always show the wrong subckt name "unmos4_schematic" but not "unmos4" ?
Paulux
Paulux over 14 years ago
I want to build a cell called unmos4 and hope the spectre-generated netlist showing as follows
.subckt unmos4 D G S B
parameters nw=1 nl=1
M1(D G S B) ne2 w=nw l=nl as=0.49*(nw) ad=0.49*(nw) pd=0.98+2*(nw) ps=0.98+2*(nw)
ends unmos4
MN0 (out net043 gnd gnd) unmos4 nw=3 nl=0.35
HOWEVER, the result shows that there is extra "_schematic" after unmos4
.subckt unmos4_schematic D G S B
ends unmos4_schematic
MN0 (out net043 gnd gnd) unmos4_schematic nw=3 nl=0.35
May I know how to remove "_schematic" after unmos4?
The CDF is as follows
Component Parameters
model paramType=string, parseANumber=no, parseAsCEL=yes, storeDefault=no, name=model, prompt=unmos4
Simulation Information
Choose Simulator=spectre, otherParameters=model, instParameters= nw nl, componentName=unmos4, termOrder=d g s b
Same problem of extra "_schematic"  is also found when hspiceD netlisting for simulation.
 Choose Simulator=hspiceD, instParameters= nw nl, componentName=unmos4, namePrefix=X, termOrder=D G S B, termMapping= nil D \,D G\, G S \,S B \,B
Thank you very much in advance for any help, feedback and comments
  • Paulux
    From Cadence Analog Design Environment User Guide (Product Version 5.0) p.135 (About Subcircuits and Macros), it mentioned
    "Whenever possible during hierarchical netlisting, subcircuit names are generated in the form _libName_cktName_schematic
    For example: .SUBCKT _mylib_bicomp_schematic n0 n1 hsbias out
    This name generation is not possible when a subcircuit is parameterized (that is, when it has parameter values passed in through macroArguments in the stopping cellview CDF). In this situation, subcircuits are named subX, where X is a unique number. For example:
    .SUBCKT sub3 D G S
    If you want to have nonparameterized subcircuits named in the subX style, add a dummy parameter to the macroArgument field of the CDF for the stopping cellview."
    My questions are
    (1)Based on the above description, may I know how to change the instance name from  unmos4_schematic to unmos4?
    Or is this impossible? Or any other method that I can stop generating "_schematic" after the instance name unmos4?
    (2)Where can I set stopping cellview CDF?
    Thank you very much for your feedback/comments
     The macroArguments stuff is primarily for stopping views - it's if you want to reference an external subckt model - and it's for hspice - not spectre. Even then I think it's for hspiceS, not hspiceD.
    I believe that the _viewName will only get added if you have used a config and more than one view has been selected - In general it should just use the cellName as the subckt name.
    I'm not sure why it necessarily matters, if everything is consistent - but maybe the best thing is to provide your data (to customer support if you can't provide it here) so that somebody can take a look?
  • Paulux
    Thanks Andrew very much for explanation.
    From your reply, _viewName exists due to (1)used a config and (2) more than one view has been selected.
    The libraries included in Library Manager are
    US_8ths, ahdlLib, analogLib, basic, cdsDefTechLib, functional, rfExamples, rfLib, my_chrt035
    I only build unmos4 in my_chrt035 library.
    If any more details are required, please kindly leave reply here.
    May I know where & how I can know what config I used? Or where/how can I know that more than one view has been selected? And how to fix this selection in order to remove _viewName?
     My Virtuoso Design Environment 5.10.41.500.5.96.
    Thank you very much in advance for any comments/feedbacks.
  • Paulux
    Thanks so much Andrew about "_viewName".
    May I know how I can view my config of my library my_chrt035 that generates "_viewName"?
    Or where I can see "more than one view has been selected"?
    May I know what data I should provide here to give further details for these questions?
    Thank you very much in advance for your kindness and feedback.
    If you don't know what a config view is, the chances are you didn't create one (you use the hierarchy editor for this).
    As I said, the best thing is to contact customer support on this, because then they can talk you through in a way that volunteers on this forum don't have time to do...
    Kind Regards,
    Andrew,
