  3. Beginner questions: Verilog-a - Custom Models
  • Subscribers 132
  • Views 1297
soathana
soathana over 14 years ago
Hi everybody, I am creating a custom transtistor model with verilog-a and using it at a symbol with ADE and I have some questions:
1)Is there a dedicated way to parse verilog code? so far the thing I have been doing is editing the code inside its cell and then when I close it after a while verilog parser fires up and gives me the errors / warnings. It there a way to do this in a better way, sinse I cannot see the warnings but just the errors?
2) The above I believe causes me some errors since for a weird reason sometimes updating verilog code does not affect the symbol I created, and each time I update the code I have to create a new symbol. Is there a way to update the symbol?
3)Is there an official verilog-a manual for the features cadence supports?
cheers,
Sotiris
  • Ashish Patni
    Ashish Patni over 14 years ago
    Hi Sotiris,
    Please see for the reply to your queries -
    Ans 1) You can follow the steps as mentioned in the following COS solution to parse the veriloga code from the unix prompt -
     http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=1815796
    Ans 2) Not aure what could be causing this. Needs to be investigated. You may contact Cadence Customer Support for this.
    Ans 3) You can look at the VerilogA Manual here -
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=veriaref/veriaref11.1/veriarefTOC.html
    With Regards,
    Ashish
  • soathana
    Thanks Ashish.
    cheers,
    Sotiris
