  3. Assura QRC fail
  • Subscribers 133
  • Views 15803
Assura QRC fail
mailavj
mailavj over 14 years ago
Hello
I have designed a differential amplifier, coded the schematics, finished the layout, completed DRC, executed LVS successfully
But when i  try to extract the layout using Assura QRC, It fails every time. I have attached the log file
What i understand is it consumes all the disk space ( i tried with bigger disks, but no help)
Please advise
Thanks in advance
Warm regards
Aravind
  • qrc.txt
  • Quek
    Quek over 14 years ago
    Hi Aravind
    It looks like your 64bits qrc913-p003 has failed during mosfet diffusion
    resistance extraction with the following errors:
    INFO (TIDENT-143055):      258 transistors all together
      Output 414 Regions for INFO (INTER-122004): Interact
    write failed: Input/output error
    ERROR (LBMISC-215352): write error on file rcx_temp/bdcoutljc3Sp
    ERROR (REX-163152): /EXT91/tools.lnx86/extraction/bin/64bit//inter failed with status 255
    ERROR (REX-163152): /EXT91/tools.lnx86/extraction/bin/64bit//rex failed with status 255
    Would you please try the following to see if it helps?
    a. Newer version of qrc (e.g. 11.1.1)
    b. Disable diffusion resistance extraction in the "Setup" tab of QRC form
    Best regards
    Quek
  • mailavj
    Hello Quek
    Thak you very much for the reply
    It solved all my problems
    Now extracted schematics is out
    Warm regards
    Aravind
