  3. how to pass parameter to the model file(the parameterized...
  • Views 4752
how to pass parameter to the model file(the parameterized model)
zwang
zwang over 14 years ago
I have a model file that I intentionally place a few parameters. Those parameters will be set with a symbol associated with that model file. My quesiton is how to pass the parameters from symbol to the model files?
  • zwang
    Is this even achievable?
     Yes, this is possible. To avoid me having to list every possible solution for every possible simulator, it would be useful to know which simulator you're talking about, and which version of Virtuoso you're talking about?
  • zwang
    It is for spectre and APS. The version of Virtuoso is 5.1.141...
    To elaborate a little more, we have a device that is described by a Spectre subcircuit in an text file. We have created a symbol and a spectre view for this device (but no schematic view), we added a parameter "macro" with the CDF editor, assigned the subcircuit name to the parameter and added the subcircuit text file to the model search path. We use the ADE environment to start the simulation. The simulation of a test circuit that uses this symbol now runs correctly with the subcircuit model.
    Now we want to add a variable to the subcircuit text file that modifies its behavior for each instance of the symbol in the test circuit. How do we add the parameter to the symbol, such that it is passed on to the text file of the subcircuit model?
  • zwang
    Andrew, can you please shed some light on it? Thank you very much.
    Zhenyu
  • MrEko
    MrEko over 5 years ago in reply to Andrew Beckett
    same problem here.  I'm using sp and hb simulation, Virtuoso 6.1
    Andrew Beckett over 5 years ago in reply to MrEko
    You didn't mention which simulator (I'm assuming Spectre - if so, which version) and Virtuoso 6.1 covers 15 years of different versions. Please be more specific (oh, and by the way the forum guidelines ask you not to post on the end of an old post - that's partly why I overlooked this).
