  3. Virtuoso: "save a copy" from read-only cell in 6.1.4 but...
  • Subscribers 132
  • Views 1694
Virtuoso: "save a copy" from read-only cell in 6.1.4 but not in 6.1.5
StefanSL
StefanSL over 14 years ago
Dear all,
the subject already contains most of my question:
If i open a cell in read-only mode, i can save it to a new name when i'm on 6.1.4;
If i'm on 6.1.5 (6.1.5-64b.500.7 as well as 6.1.5-64b.500.10), the menu item "save a copy" is greyed out.
When i switch to "editable", it's available again, and back to "read-only" it's blocked.
Is this a bug or a feature??
The manual to 6.1.5 states ("Saving a Design"):
"Note: You can access the Save a Copy command if a design is opened in read mode.
The command checks out..."
What's wrong, virtuoso, the manual or is it me??
Thanks for your help
Stefan
    Stefan,
    It works for me. I can't see (from looking at the menu definition) why it should behave like this for you.
    Do you have a menus directory somewhere (type "cdswhich menus" in the terminal from which you started virtuoso) - maybe you have an old menus/schView.menus or menus/schematic.menus file which is overwriting the behaviour?
  • StefanSL
    many thanks, your hints were very helpful:
    indeed, there is a menus-file for layEdit; if i move it to another place, "save as" is available like in 6.1.4,
    but of course our customization is lost;
    just replaced layEdit.menus by the template from the 6.1.5 installation, it's running fine, now i have to add again
    our customized entries, step by step, as long as it behaves as desired...
    kind regards
    Stefan
