  3. Problems importing a CDL with resistors and diodes
  • Subscribers 132
  • Views 16446
TAnderson
TAnderson over 14 years ago
I  am trying to import a CDL with mos transistors, resistors and diodes. I have no problems with the mos transistors but both resistors and diodes are not imported. I cannot find the mistake. I see somethig different for the RD resistors in the netlist (there are no W,L) but none of the passive components are imported and others seem to be "normal".
 I have added the following lines to the netlist in order to import the passive components.
PARAM
*.BIPOLAR
*.RESVAL
*.CAPVAL
*.DIOAREA
*.SCALE METER
The section of the netlist containing the passive componets is:
D51     VSS     I       DN  250.0000F 2.0000U
D59     VSS     OEN     DN  250.0000F 2.0000U
R21     U29_r1 PAD     302.2790 $[RE]  W=4U L=2.5U
R22     U29_pa U29_U72_r1 302.2790 $[RE]  W=4U L=2.5U
R37     U29_r1 VSSO    4.89148K $[RW]  W=2.1U L=8.65U
RM19   net_m19   VDDO   1180.0000 $[RD]
RM20   net_m20   VSSO   1180.0000 $[RD]
RM38   net_m38   VDDO   1180.0000 $[RD]
RM39   net_m39   VSSO   1180.0000 $[RD]
RM66   net_m66   VDDO   1180.0000 $[RD]
RM67   net_m67   VSSO   1180.0000 $[RD]
The mapfile is:
 devMap := diode ndio
propMatch := subtype DN
devMap := resistor rpoly2
propMatch := subtype RE
devMap := resistor rnwell
propMatch := subtype RW
devMap := resistor rpoly1
propMatch := subtype RD
  • TAnderson
     Finally I think I managed to import the netlist but now I have aproblem with the size of the transistors.
    In the netlist the witdh and legth is given in meters (i.e. w=5.2u) while in the schematic I have to put them in um (w=5.2).
    I have tried removing the 'u' from the netlist. It works but it seems to be a limitation in the cdlin and I can only import transistors with the width lower than 2.1. Over that value the importe width is 0.
    Is there a way to remove this limitation? or do you now a better way to do the importing process? A method to multiply the dimensions of all the transistors by 1e6 in the schematic could be a solution (only transistors and resistors but not fot the diodes).
     Thanks.
    Which version of the IC tools are you using? This is quite important information to provide (which is why the forum guidelines suggest you provide it)...
  • TAnderson
    Sorry Andrew, I forgot giving that info.
    The version is   ic5.10.41.500.6.151
