  3. Translating IC5 libaries to IC6
  • Views 18635
DineshBabu
DineshBabu over 14 years ago
 How do I translate IC5 libraries to IC6?
Is there any manual available for reference?
 Thanks in advance!
    This can be done with the "cdb2oa" command line tool, or using Tools->Conversion Toolbox->CDB to OpenAccess Translator.
    As for documentation, you should read:
    • DFII->Virtuoso Design Environment Adoption Guide
    • DFII->CDB to OpenAccess Translator User Guide
    • DFII->Virtuoso Design Environment Migration Guide
    These can be found in cdnshelp (or Help from the CIW), or looking at doc/dfoaAdopt/dfoaAdopt.pdf , doc/cdboa/cdboa.pdf and doc/cicMigGuide/cicMigGuide,pdf under the IC61X installation directory.
  • DineshBabu
    Thanks, Andrew.
     I will go through the documents.
