  3. How to run Spectre from Schematic Editor
  • Subscribers 132
  • Views 17072
pyohayo
pyohayo over 14 years ago
It seems, that Analog Env. interface changed in IC615 comparing to IC5141.
I tried to run simple analog simulation (please see the pict. in attachment).
I did following actions:
  1.  Launch/Simulation/Spectre
  2. Spectre/Initialize
And then what should I do to set simulation options (type of analisys, output signals, etc.) and ru simulation ?
I tried to find concerned information in the Virtuoso Schematic Editor Spectre and  Ultrasim Interface User Guide, but without success.
Thanks in advance.
Pavel.
    Pavel,
    I suspect you meant to do Launch->ADE L (which corresponds to Tools->Analog Environment in IC5141). Launch->Simulation->Spectre is the same as Tools->Simulation->Spectre (in IC5141) and is a more primitive interface to spectre (you set up the analyses via  Spectre->Stimulus->... menus).
  • pyohayo
     Thanks Andrew,
     Yes, it's exactly what I meant. But it seems, that I have no Spectre in my package. Here is  CIW output when I tried to run simulation:
    ERROR (ADE-3023): Unable to locate spectre executable in the specified path. Ensure that
    the executable is present in the path or to set the correct path, use
    the setShellEnvVar() in Command Interpreter Window (CIW)
    Before Spectre were part of IC package, but it seems it's not the case for IC615. Do I need to have mmsim in order to run simulations.
    Pavel.
    Pavel,
    Yes, you need MMSIM. Spectre moved into a separate stream in late 2004 - so even if using IC5141 you should use spectre from MMSIM because the version in IC5141 is really old and is not being maintained.
