  3. Parasitic devices/probes in the schematic --> How to fix...
  • Subscribers 132
  • Views 2702
Parasitic devices/probes in the schematic --> How to fix the layout connectivity (flightlines) in VXL?
Wim Verhaegen
Wim Verhaegen over 14 years ago
Hi all,
We are using multiple parasitic elements or simulation probes in our schematics. We are using the "lvsIgnore" and the "lxRemoveDevice" statements to filter them out when creating the cdl netlist. What happens is the netlist will ignore these devices en shorts both of their terminals.
When we generate the layout from source in VXL, we would like it to do the same...The devices aren't generated but the terminals are still seen as two different nets...
What can we do?
Best regards
Wim Verhaegen
    Which version of the tools are you using? The mechanism is different between IC5141 and IC615, for example...
  • Wim Verhaegen
    We are using IC6.1.5 (-64b.500.8)
    Wim
    Hi Wim,
    In IC61, the lxRemoveDevice information should be placed in a LAM file (Library and Attributes Mapping file). This file needs to go in
    <libName>.cadence/dfII/cph/lam/cph.lam
    and have contents like below (strictly speaking there are other locations it can be placed - see the documentation - search for "LAM"). Make sure you change the LIB NAME line below to match your library name:
    <!DOCTYPE LAM_FILE>
    <LIBRARY_DATA>
      <VERSION NUMBER="0.3" />
      <LOGICAL>
        <LIB NAME="mylib" >
          <CELL NAME="presistor" >
            <VIEW NAME="symbol" >
              <REMOVE_DEVICE>(short(PLUS MINUS))</REMOVE_DEVICE>
            </VIEW>
          </CELL>
          <CELL NAME="pinductor" >
            </VIEW>
          </CELL>
        </LIB>
      </LOGICAL>
      <PHYSICAL/>
    </LIBRARY_DATA>
    You'll see if you start Layout XL (and Gen from Source or Update Components and Nets) and then launch Configure Physical Hierarchy, that this has seeded the information that these devices should be removed.
  • Wim Verhaegen
    We have just implemented your solution and it works fine!
    Thanks for your help!
    Best regards
    Wim
