  3. 2011 Models for TSMC RF90NM
  • Replies 8
  • Subscribers 132
  • Views 17322
JustinTaylor86
JustinTaylor86 over 14 years ago
Anyone know why I would be getting these errors when changing from 2006 Models to 2011 Models?
ERROR (SFE-2): "input.scs" 83: `I2.M9': Attempt to override value of inherited parameter `rgflag' when instantiating a subcircuit.
Warning from spectre in `x:`I2', during hierarchy flattening.
 ERROR .......value of inherited parameter `wpeflag' when instantiating a subcircuit
Justin
    Justin,
    Which version of MMSIM are you using? Maybe it's relying on a feature not available in the version you're using?
  • JustinTaylor86
     How can I find this out?
     At the top of the simulator output, what version number does it say? For example:
    Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
    Version 11.1.0.366.isr7 32bit -- 20 Mar 2012
  • JustinTaylor86
     Simulator Version 11.1.0.228.isr1 32bit --
  • JustinTaylor86
    Hi I was using 2006 models with no problems and now I have changed to 2011 models and errors listed before.
    Version 11.1.0.425.isr10 32bit -- 24 May 2012
    Error found by spectre in `AND2X2_25_DFM':`I4.I1.I3', in `pmgt_bg_start':`I4.I1', in `pmgt_reference':`I4', during hierarchy flattening.    ERROR (SFE-2): "input.scs" 77: `I4.I1.I3.M9': Attempt to override value of inherited parameter `wpeflag' when instantiating a subcircuit.
    ERROR (SFE-2): "input.scs" 77: `I4.I1.I3.M9': Attempt to override value of inherited parameter `rgflag' when instantiating a subcircuit.
    Error found by spectre during hierarchy flattening.
    ERROR (SFE-1996): "/home/leica/velaro_review.sbp/resources/t-n90-cm-sp-013_1_2_20111130/crn90g_2d5_lk_v1d2.scs" 7995: parameter `noicn_25': Unknown parameter name `par1fn_mc' found in expression.
    ERROR (SFE-1996): "/home/leica/velaro_review.sbp/resources/t-n90-cm-sp-013_1_2_20111130/crn90g_2d5_lk_v1d2.scs" 7991: parameter `noian_25': Unknown parameter name `par1fn_mc' found in expression.
    ERROR (SFE-1996): "/home/leica/velaro_review.sbp/resources/t-n90-cm-sp-013_1_2_20111130/crn90g_2d5_lk_v1d2.scs" 7993: parameter `noibn_25': Unknown parameter name `par1fn_mc' found in expression.
    Previous suggestions didn't resolve the issue.
    I merged this thread with your previous one, since it's the same issue.
    I would suggest you contact TSMC. My guess is that you're not including the correct sections of the model file, but it's hard to know without seeing your setup.
  • JustinTaylor86
     TSMC were very helpful, after waiting for a week for a reply they said it was a tool problem so I am no further along.
    Justin
    Can you log this as a service request? Unless we can see precisely how you're including the models, and precisely which version of the model files you're using, there's very little we can do to help. That's not really something you can give in an open forum, because you're probably revealing TSMC's IP, which they are not likely to be very happy about...
