  3. setenv LBS_CLUSTER_MANAGER
  • Replies 13
  • Subscribers 133
  • Views 20145
JustinTaylor86
JustinTaylor86 over 14 years ago
Does anyone know how to set LBS_CLUSTER_MANAGER environment varaible?
Justin
    Hi Justin,
    I assume you mean LBS_CLUSTER_MASTER? The env var LBS_CLUSTER_MANAGER doesn't mean anything to the Cadence Tools.
    Did you try reading the Virtuoso Analog Distributed Processing Option User Guide ? (<ICinstDir>/doc/distproc/distproc.pdf )
    What is the problem you're trying to solve?
  • JustinTaylor86
    Yes I am looking at that pdf but it's not very clear for me how I can set this LBS_CLUSTER_MANAGER to look at my host.
    I also can't find where the .cshrc file is.
    I am trying to set up distributed processing.
    Maybe you're using a different shell - e.g. ksh or bash? If using bash, you'd put:
    export LBS_CLUSTER_MANAGER=hostName
    in the .bashrc (say). This is basic UNIX knowledge - so you should find out which shell you're using, and set the environment variables the appropriate way for the shell you're using.
  • JustinTaylor86
     Thanks, that worked.
     Next issue is
     ERROR (219): The script failed to detect the OS type of "hostname"
     .....make sure the following command is running without problem
     ../../../tools/dfII/bin/cdsDPrsh.
     How can I make sure it is running?
     Justin
    Justin,
    You didn't say what you were doing at the time, but my guess is that you might have been using the "check setup" option, and it's unable to rsh onto the remote machine.
    You might need to configure cdsRemsh to use ssh instead of rsh - maybe rsh is not allowed in your environment? That can be done by following the instructions in <ICinstDir>/share/cdssetup/cdsRemsh/cdsRemote.scr assuming you're using IC61X.
    Otherwise, please log a service request
  • amwygah
    amwygah over 13 years ago
    Could you tell me where can i modify rsh to ssh in my ic5141 ?
    For distributed processing, you can set this via the .cdsenv setting:
     asimenv.distributed remoteShell         string          "rsh"
    (that's the default), or the equivalent SKILL:
    envSetVal("asimenv.distributed" "remoteShell"   'string   "ssh")
  • amwygah
     Thans for reply
    and now my check setup result is like this:
    Checking Distributed Processing (DP) setup..........
    Current User is:  eda5141
    Submission host name is: amwygah-desktop
    Checking for DP environment variables.....
    Environment variable LBS_CLUSTER_MASTER is set to 202.115.29.26
    Checking for LBS mode setup
    Checking if cdsqmgr is running properly on "202.115.29.26" .........Ok
    Checking if cdsNameServer is running properly on "202.115.29.26" .........Ok
    Checking for queue config file...
    Using variable CDS_QUEUE_CONF_FILE as this is set to /home/eda5141/queue_config
     The queue config file identified is /home/eda5141/queue_config
     This may not be correct due to the OS command's (ps) limitations.
     You can set the env variable CDS_QUEUE_CONF_FILE to specify the queue config
     file used by the cdsqmgr daemon running on 202.115.29.26
    Checking if the hosts are up......
    Checking for password related requirements(from Submission to Cluster Hosts)
    Checking for password requirements in reverse direction (from Clusters to Submission Hosts)
    Checking for hierarchy compatibility with login shell: none
                  1. Check for the hier locations
                  2. Check for the presence of spectre binary.
                     <<< Local spectre version : 7.2.0 >>>
                  3. Check for the presence of cdsserv binary.
                     <<< Local cdsserv version : 06.00 >>>
    Checking for space in /tmp area.......
    Checking for Network Mode......
    Checking if artmonitor works...FAILED.
    WARNING (220): Although the setup appears to be fine, artmonitor
    is not responding. Therefore, DP may not run. It might be a network
    or the DP daemon related issue.
    Setup check completes with 0 errors and 1 warnings.
  • amwygah
     and the content of CDS_QUEUE_CONF_FILE just like this
    queque 1
    eda5141@ubuntu-eda 20
    And in the /etc/hosts, i resolve  ubuntu-eda to 202.115.29.166
    does it should be right?
     I suggest you log a service request - I don't really have the time to debug this myself right now (have you tried just running a simulation?)
    I probably wouldn't put an "@" in the hostname - it's supposed to just  be a hostname (I'm guessing that's a username for the ssh before the @ ?).
