  3. How to use Tcl command to get expression value from a AMS...
  • Subscribers 132
  • Views 20825
How to use Tcl command to get expression value from a AMS simulation?
greatqs
greatqs over 14 years ago
I'm using IRUN for AMS simulation and I'd like to use Tcl commands (i.e. which is used as -input arguments of irun executive) to get expression value a certain waveform (i.e. get ymax value for signal: tb.neta)
Could anyone tell me how to do it? Thanks!
    You can't do it directly. You could use an OCEAN script at the end to get the maximum, or you could write a Verilog-AMS module which followed a waveform and output the maximum, say.
  • greatqs
    Thanks Andrew, is it possible to use simvision Tcl command interface?
    Good point. You could use:
    set expression {range_max(top.dacOut, 0 ns, 40000 ns)}
    condition set -using myymax -expr $expression
    window new WaveWindow
    waveform add -signals {myymax}
    The range_max function in the simvision calculator can be used to find the ymax.
  • greatqs
    Thanks Andrew for the help. It looks like the second command doesn't work. Simvision pops "Error: bad condition name "myymax""
    Besides, do you now how to get the number for post-processing intead of plotting to a simvision waveform?
    QS
    Sorry, that should have been:
    condition new -name myymax -expr $expression
    Rather than condition set. I copied the wrong line from somewhere. You might want to preceed it with:
    catch {condition delete myymax}
    in case the condition is already created.
    Not really sure (not that familiar with simvision scripting).
    You can send to a register window, using:
    set regid [window new RegisterWindow]
    register add -using $regid myymax
    But that's probably not what you want either. You may need to contact customer support to get an answer from somebody more knowledgeable than me in simvision - I was just reading the manual :-) . Or it may not be possible...
