  3. ncverilog simulation overflow
  • Subscribers 133
  • Views 17248
dzkxybx
dzkxybx over 14 years ago
hi,
  i am new here. I have a problem as below when i do my design simulation:
 4038444601 Overflow
Simulation stopped via $stop(1) at time 40384446008 PS + 2
how could this happens? thanks!
and my timescale is 1ns/10ps
  • Quek
    Quek over 14 years ago
    Hi dzkxybx
    From the limited info which you had provided, it is very hard to guess the cause of the problem. If you are not using the latest version of ncverilog, would you please re-try using the latest version and see if the same problem occurs?
    Best regards
    Quek
    The limit for some considerable time has been about 9223 seconds - and you're hitting a limit much less than that.
    Are you using some prehistoric version of ncverilog? What does "ncverilog -version" say?
    e.g. simulating "ncverilog testmax.v" where testmax.v is:
     `timescale 1ps/1fs
    module top;
    reg a;
    initial a=1;
    always #100000000000 begin
      a=~a;
      $strobe($time,,"a=%b",a);
    end
    endmodule
    Gives:
         9223368439474176 a=0
        9223369655226368 a=1
    ncsim: *E,TRTOVF: simulated time overflow.
              File: ./testmax.v, line = 9, pos = 7
             Scope: top
              Time: 9223370870978560 PS + 0
    ./testmax.v:9 always #100000000000 begin
