  3. Connectivity Driven Layout
  • Subscribers 133
  • Views 15701
sohaiba
sohaiba over 13 years ago
Could anyone guide me how to turn-off the Connectivity Driven Layout option in my Cadence IC 6.15 virtuoso tool? I would like to be able to turn it off and on when required.
Regards
  • Quek
    Quek over 13 years ago
    Hi Sohaiba
    I do not quite understand what you meant but if you do not wish to use layoutXL, you can simply go to "Launch->Layout L". If you would like to use layoutXL, please go to "Launch->Layout XL". : )
    Best regards
    Quek
  • sohaiba
     Sorry, what I meant was that while using Layout XL, can I switch off the connectivity driven layout options (such as the layout shows the dotted connection lines between device) after using generate devices options.I do get your advice regarding using Layout L ana Layout XL.
    Regards
  • Quek
    Hi Sohaiba
    You can turn off flight lines as follows:
    a. Go to "Windows->Assistants->Annotation Browser"
    b. Click the "eye" to enable/disable the display of flight lines
    Best regards
    Quek
