  3. Post-simulation error
  • Subscribers 132
  • Views 17235
Campo85
Campo85 over 13 years ago
Hi all,
I have a problem with spectre in the post simulation. I've extracted the parassitic from layout with Assura QRC, then I've modified the enviroment in spectre ( Switch View List : av_extracted and Stop View List : av_extracted ), but when I ran the simulation in spectre I get the follow error :
Error found by spectre during circuit read-in.
ERROR (SFE-23): "input.scs" 67: I5 is an instance of an undefined model subcircuit.
ERROR (SFE-23): "input.scs" 68: I6 is an instance of an undefined model subcircuit.
ERROR (SFE-23): "input.scs" 69: I4 is an instance of an undefined model subcircuit.
"I4","I5" and "I6" are my design. I attach the log
  • ade_xl.txt
  • Campo85
    Ok, an update. I started from scratch my test. When I regenerated the netlist I've got a lot of warnings in CDS.log :
     INFO (OSSHNL-251): Mismatch found in the direction of terminal 'CLOCK_MASTER' in the placed master
    \o 'DICE_LIB/FF_DICE/symbol' and its corresponding terminal in the switch master 'DICE_LIB/FF_DICE/av_extracted',
    \o however, this terminal is printed in the netlist because the variable
    \o simCheckTermDirectionMismatch is either set to 'ignore' or is not set.
    \o
    \o INFO (OSSHNL-251): Mismatch found in the direction of terminal 'CLOCK_SLAVE' in the placed master
    CLOCK_MASTER,  CLOCK_SLAVE, etc... are the I/O pins of the design. How can I fix the mismatch beetwen symbol and extracted ?
    • CDS.log.txt
    The terminal direction mismatches are being reported because probably the pins on the layout view don't have directions which match the schematic - and these pins are transferred to the extracted view when the extracted view is created. It shouldn't actually cause any problem though. If you want to fix it, you'd have to edit the pins on the layout and fix the direction to match (e.g. input/output/inputOutput).
    The problem with it netlisting the components as "subcircuit" suggests that either there is something wrong with the CDF for those cells, or (quite likely) you were running without $CDS_Netlisting_Mode set to Analog (which is the default in IC615, at long last).
