  3. EldoD simulator can't be set in ADE virtuoso 6.1.5
  • Subscribers 132
  • Views 1441
djeto38
djeto38 over 13 years ago
Hello ,
How can I set directly my simulator with ADE ?
 Even if .cdsenv variable setted to # asimenv.startup simulator       string  "eldoD"   #
I don't see "eldoD" in  ADE~>setup~>Simulation/directory/host~>Simulator .
Is there another way to define default simulator in ADE ?
Thanks for your help !
    If it's not shown in the list of choices, you can't set it as the default. If it's in the choices, then you can set it as the default.
    If it's not shown in the list of choices, the most likely explanation is that you're not loading Mentor's customization to add the Eldo interface from your .cdsinit - so this is more of a question for Mentor Graphics as to how you should do that (it's covered in their documentation). I know how it was done in the past but haven't seen the interface for a couple of releases, so best to look at their documentation or ask Mentor Graphics themselves.
    Best Regards,
  • djeto38
    You’re right Andrew
    I avoid Mentor declaration tools in my .cdsinit
    Thanks a lot for your reactivity
    Best regards,
    Jérôme THOMAS
    Design Center
    Backend & CAD Engineer
