  3. Hysteresis sweep option in DC
  • Replies 18
  • Subscribers 132
  • Views 31821
sohaiba
sohaiba over 13 years ago
I haven't been able to see a Hysteresis plot by using the DC Hysteresis sweep option. I have also enabled the 'DC operating point' option as well. I was expecting to find a negative going plot as well for the device but there is only a single Voltage transfer characteristic curve.
 Following are the settings the Cadence spectre.out shows.
Important parameter values:
    reltol = 1e-03
    abstol(V) = 1 uV
    abstol(I) = 1 pA
    temp = 120 C
    tnom = 27 C
    tempeffects = all
    gmindc = 1 pS
    hysteresis = on
Which verifies that hysteresis option is "ON".  I am using MMSIM 11.1 and Cadence 6.1.5. Could you indicate where I could be going wrong?
Regards
     No idea - this should work. Please contact customer support.
  • Rambooooo
    Rambooooo over 10 years ago
    Hi
    maybe you can check you DC sweep step size and use small linear step size (this may takes more time).
    if you chose automatic and sweep within a wide range, the step size may be too large for spectre to give you accurate result( especially your hysteresis is small ).
    hope that helps.thanks
    regards
  • BaaB
    BaaB over 9 years ago
    I am facing the same problem now. Is there a solution for this? Thank you.
    Which version are you using? I just tried it and it worked OK.
    I did find one CCR report saying that if you had DC convergence problems and it had picked "dptran" as the homotopy method, you may have to set "rampsource=no" on the Simulation->Options->Analog, Miscellaneous tab, Additional arguments field (at the bottom).
  • BaaB
    Thanks for helps.
    I am using Virtuoso 6.16. I've just tried that but it doesn't work.
    Here is some setting:
    Global user options:
    reltol = 0.001
    vabstol = 1e-06
    iabstol = 1e-12
    temp = 27
    tnom = 27
    scalem = 1
    scale = 1
    gmin = 1e-12
    rforce = 1
    maxnotes = 5
    maxwarns = 5
    digits = 5
    cols = 80
    pivrel = 0.001
    sensfile = ../psf/sens.output
    checklimitdest = psf
    rampsource = no
    save = allpub
    DC Analysis `dc': vin = (0 -> 1.8)
    reltol = 1e-03
    abstol(V) = 1 uV
    abstol(I) = 1 pA
    temp = 27 C
    tnom = 27 C
    tempeffects = all
    gmindc = 1 pS
    hysteresis = on
    More important is the MMSIM version (what does spectre show as the subversion in the spectre.out log files?)
    Are you sure your circuit definitely exhibits hysteresis? If you do a ramp up and down in transient, do you see it?
  • BaaB
    I have just checked it is MMSIM131. I also already run transient and see that there is hysteresis.
    Here is the output log:
    reltol = 0.001
    vabstol = 1e-06
    iabstol = 1e-12
    temp = 27
    tnom = 27
    scalem = 1
    scale = 1
    gmin = 1e-12
    rforce = 1
    maxnotes = 5
    maxwarns = 5
    digits = 5
    cols = 80
    pivrel = 0.001
    save = allpub
    Circuit inventory:
    nodes 9
    bsim3v3 11
    vsource 4
    Analysis and control statement inventory:
    dc 2
    info 7
    Output statements:
    .probe 0
    .measure 0
    save 0
    Notice from spectre.
    4 warnings suppressed.
    Time for parsing: CPU = 5.999 ms, elapsed = 28.0912 ms.
    Time accumulated: CPU = 643.901 ms, elapsed = 699.847 ms.
    Peak resident memory used = 59.5 Mbytes.
    Pre-Simulation Summary
    Entering remote command mode using MPSC service (spectre, ipi, v0.0, spectre0_3549_10, ).
    DC Analysis `dcOp'
    reltol = 1e-03
    abstol(V) = 1 uV
    abstol(I) = 1 pA
    temp = 27 C
    tnom = 27 C
    tempeffects = all
    gmindc = 1 pS
    Convergence achieved in 11 iterations.
    Total time required for dc analysis `dcOp': CPU = 4.999 ms, elapsed = 4.65584 ms.
    Time accumulated: CPU = 652.9 ms, elapsed = 2.15483 s.
    Peak resident memory used = 60.3 Mbytes.
    dcOpInfo: writing operating point information to rawfile.
    reltol = 1e-03
    abstol(V) = 1 uV
    abstol(I) = 1 pA
    temp = 27 C
    tnom = 27 C
    tempeffects = all
    gmindc = 1 pS
    hysteresis = on
    dc: vin = 90e-03 (2.5 %), step = 9e-03 (250 m%)
    dc: vin = 99e-03 (2.75 %), step = 9e-03 (250 m%)
    dc: vin = 108e-03 (3 %), step = 9e-03 (250 m%)
    dc: vin = 117e-03 (3.25 %), step = 9e-03 (250 m%)
    dc: vin = 126e-03 (3.5 %), step = 9e-03 (250 m%)
    dc: vin = 135e-03 (3.75 %), step = 9e-03 (250 m%)
    dc: vin = 144e-03 (4 %), step = 9e-03 (250 m%)
    dc: vin = 153e-03 (4.25 %), step = 9e-03 (250 m%)
    dc: vin = 162e-03 (4.5 %), step = 9e-03 (250 m%)
    dc: vin = 171e-03 (4.75 %), step = 9e-03 (250 m%)
    dc: vin = 180e-03 (5 %), step = 9e-03 (250 m%)
    dc: vin = 189e-03 (5.25 %), step = 9e-03 (250 m%)
    dc: vin = 198e-03 (5.5 %), step = 9e-03 (250 m%)
    dc: vin = 207e-03 (5.75 %), step = 9e-03 (250 m%)
    dc: vin = 216e-03 (6 %), step = 9e-03 (250 m%)
    dc: vin = 225e-03 (6.25 %), step = 9e-03 (250 m%)
    dc: vin = 234e-03 (6.5 %), step = 9e-03 (250 m%)
    dc: vin = 243e-03 (6.75 %), step = 9e-03 (250 m%)
    dc: vin = 252e-03 (7 %), step = 9e-03 (250 m%)
    dc: vin = 261e-03 (7.25 %), step = 9e-03 (250 m%)
    dc: vin = 270e-03 (7.5 %), step = 9e-03 (250 m%)
    dc: vin = 279e-03 (7.75 %), step = 9e-03 (250 m%)
    dc: vin = 288e-03 (8 %), step = 9e-03 (250 m%)
    dc: vin = 297e-03 (8.25 %), step = 9e-03 (250 m%)
    dc: vin = 306e-03 (8.5 %), step = 9e-03 (250 m%)
    dc: vin = 315e-03 (8.75 %), step = 9e-03 (250 m%)
    dc: vin = 324e-03 (9 %), step = 9e-03 (250 m%)
    dc: vin = 333e-03 (9.25 %), step = 9e-03 (250 m%)
    dc: vin = 342e-03 (9.5 %), step = 9e-03 (250 m%)
    dc: vin = 351e-03 (9.75 %), step = 9e-03 (250 m%)
    dc: vin = 360e-03 (10 %), step = 9e-03 (250 m%)
    dc: vin = 369e-03 (10.2 %), step = 9e-03 (250 m%)
    dc: vin = 378e-03 (10.5 %), step = 9e-03 (250 m%)
    dc: vin = 387e-03 (10.8 %), step = 9e-03 (250 m%)
    dc: vin = 396e-03 (11 %), step = 9e-03 (250 m%)
    dc: vin = 405e-03 (11.2 %), step = 9e-03 (250 m%)
    dc: vin = 414e-03 (11.5 %), step = 9e-03 (250 m%)
    dc: vin = 423e-03 (11.8 %), step = 9e-03 (250 m%)
    dc: vin = 432e-03 (12 %), step = 9e-03 (250 m%)
    dc: vin = 441e-03 (12.2 %), step = 9e-03 (250 m%)
    dc: vin = 450e-03 (12.5 %), step = 9e-03 (250 m%)
    dc: vin = 459e-03 (12.8 %), step = 9e-03 (250 m%)
    dc: vin = 468e-03 (13 %), step = 9e-03 (250 m%)
    dc: vin = 477e-03 (13.2 %), step = 9e-03 (250 m%)
    dc: vin = 486e-03 (13.5 %), step = 9e-03 (250 m%)
    dc: vin = 495e-03 (13.8 %), step = 9e-03 (250 m%)
    dc: vin = 504e-03 (14 %), step = 9e-03 (250 m%)
    dc: vin = 513e-03 (14.2 %), step = 9e-03 (250 m%)
    dc: vin = 522e-03 (14.5 %), step = 9e-03 (250 m%)
    dc: vin = 531e-03 (14.8 %), step = 9e-03 (250 m%)
    dc: vin = 540e-03 (15 %), step = 9e-03 (250 m%)
    dc: vin = 549e-03 (15.2 %), step = 9e-03 (250 m%)
    dc: vin = 558e-03 (15.5 %), step = 9e-03 (250 m%)
    dc: vin = 567e-03 (15.8 %), step = 9e-03 (250 m%)
    dc: vin = 576e-03 (16 %), step = 9e-03 (250 m%)
    dc: vin = 585e-03 (16.2 %), step = 9e-03 (250 m%)
    dc: vin = 594e-03 (16.5 %), step = 9e-03 (250 m%)
    dc: vin = 603e-03 (16.8 %), step = 9e-03 (250 m%)
    dc: vin = 612e-03 (17 %), step = 9e-03 (250 m%)
    dc: vin = 621e-03 (17.2 %), step = 9e-03 (250 m%)
    dc: vin = 630e-03 (17.5 %), step = 9e-03 (250 m%)
    dc: vin = 639e-03 (17.8 %), step = 9e-03 (250 m%)
    dc: vin = 648e-03 (18 %), step = 9e-03 (250 m%)
    dc: vin = 657e-03 (18.2 %), step = 9e-03 (250 m%)
    dc: vin = 666e-03 (18.5 %), step = 9e-03 (250 m%)
    dc: vin = 675e-03 (18.8 %), step = 9e-03 (250 m%)
    dc: vin = 684e-03 (19 %), step = 9e-03 (250 m%)
    dc: vin = 693e-03 (19.2 %), step = 9e-03 (250 m%)
    dc: vin = 702e-03 (19.5 %), step = 9e-03 (250 m%)
    dc: vin = 711e-03 (19.8 %), step = 9e-03 (250 m%)
    dc: vin = 720e-03 (20 %), step = 9e-03 (250 m%)
    dc: vin = 729e-03 (20.2 %), step = 9e-03 (250 m%)
    dc: vin = 738e-03 (20.5 %), step = 9e-03 (250 m%)
    dc: vin = 747e-03 (20.8 %), step = 9e-03 (250 m%)
    dc: vin = 756e-03 (21 %), step = 9e-03 (250 m%)
    dc: vin = 765e-03 (21.2 %), step = 9e-03 (250 m%)
    dc: vin = 774e-03 (21.5 %), step = 9e-03 (250 m%)
    dc: vin = 783e-03 (21.8 %), step = 9e-03 (250 m%)
    dc: vin = 792e-03 (22 %), step = 9e-03 (250 m%)
    dc: vin = 801e-03 (22.2 %), step = 9e-03 (250 m%)
    dc: vin = 810e-03 (22.5 %), step = 9e-03 (250 m%)
    dc: vin = 819e-03 (22.8 %), step = 9e-03 (250 m%)
    dc: vin = 828e-03 (23 %), step = 9e-03 (250 m%)
    dc: vin = 837e-03 (23.2 %), step = 9e-03 (250 m%)
    dc: vin = 846e-03 (23.5 %), step = 9e-03 (250 m%)
    dc: vin = 855e-03 (23.8 %), step = 9e-03 (250 m%)
    dc: vin = 864e-03 (24 %), step = 9e-03 (250 m%)
    dc: vin = 873e-03 (24.2 %), step = 9e-03 (250 m%)
    dc: vin = 882e-03 (24.5 %), step = 9e-03 (250 m%)
    dc: vin = 891e-03 (24.8 %), step = 9e-03 (250 m%)
    dc: vin = 900e-03 (25 %), step = 9e-03 (250 m%)
    dc: vin = 909e-03 (25.2 %), step = 9e-03 (250 m%)
    dc: vin = 918e-03 (25.5 %), step = 9e-03 (250 m%)
    dc: vin = 927e-03 (25.8 %), step = 9e-03 (250 m%)
    dc: vin = 936e-03 (26 %), step = 9e-03 (250 m%)
    dc: vin = 945e-03 (26.2 %), step = 9e-03 (250 m%)
    dc: vin = 954e-03 (26.5 %), step = 9e-03 (250 m%)
    dc: vin = 963e-03 (26.8 %), step = 9e-03 (250 m%)
    dc: vin = 972e-03 (27 %), step = 9e-03 (250 m%)
    dc: vin = 981e-03 (27.3 %), step = 9e-03 (250 m%)
    dc: vin = 990e-03 (27.5 %), step = 9e-03 (250 m%)
    dc: vin = 999e-03 (27.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.008 (28 %), step = 9e-03 (250 m%)
    dc: vin = 1.017 (28.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.026 (28.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.035 (28.7 %), step = 9e-03 (250 m%)
    dc: vin = 1.044 (29 %), step = 9e-03 (250 m%)
    dc: vin = 1.053 (29.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.062 (29.5 %), step = 9e-03 (250 m%)
    Notice from spectre at vin = 1.071 during DC analysis `dc'.
    GminDC = 1 pS is large enough to noticeably affect the DC solution.
    dV(M7:int_d) = 165.222 uV
    Use the `gmin_check' option to eliminate or expand this report.
    dc: vin = 1.071 (29.8 %), step = 9e-03 (250 m%)
    Notice from spectre at vin = 1.08 during DC analysis `dc'.
    dV(M7:int_d) = 268.774 uV
    dc: vin = 1.08 (30 %), step = 9e-03 (250 m%)
    Notice from spectre at vin = 1.089 during DC analysis `dc'.
    dV(M7:int_d) = 409.042 uV
    dc: vin = 1.089 (30.2 %), step = 9e-03 (250 m%)
    Notice from spectre at vin = 1.098 during DC analysis `dc'.
    dV(M7:int_d) = 585.151 uV
    dc: vin = 1.098 (30.5 %), step = 9e-03 (250 m%)
    Notice from spectre at vin = 1.107 during DC analysis `dc'.
    Further occurrences of this notice will be suppressed.
    dV(M7:int_d) = 791.059 uV
    dc: vin = 1.107 (30.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.116 (31 %), step = 9e-03 (250 m%)
    dc: vin = 1.125 (31.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.134 (31.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.143 (31.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.152 (32 %), step = 9e-03 (250 m%)
    dc: vin = 1.161 (32.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.17 (32.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.179 (32.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.188 (33 %), step = 9e-03 (250 m%)
    dc: vin = 1.197 (33.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.206 (33.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.215 (33.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.224 (34 %), step = 9e-03 (250 m%)
    dc: vin = 1.233 (34.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.242 (34.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.251 (34.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.26 (35 %), step = 9e-03 (250 m%)
    dc: vin = 1.269 (35.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.278 (35.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.287 (35.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.296 (36 %), step = 9e-03 (250 m%)
    dc: vin = 1.305 (36.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.314 (36.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.323 (36.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.332 (37 %), step = 9e-03 (250 m%)
    dc: vin = 1.341 (37.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.35 (37.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.359 (37.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.368 (38 %), step = 9e-03 (250 m%)
    dc: vin = 1.377 (38.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.386 (38.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.395 (38.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.404 (39 %), step = 9e-03 (250 m%)
    dc: vin = 1.413 (39.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.422 (39.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.431 (39.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.44 (40 %), step = 9e-03 (250 m%)
    dc: vin = 1.449 (40.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.458 (40.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.467 (40.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.476 (41 %), step = 9e-03 (250 m%)
    dc: vin = 1.485 (41.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.494 (41.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.503 (41.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.512 (42 %), step = 9e-03 (250 m%)
    dc: vin = 1.521 (42.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.53 (42.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.539 (42.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.548 (43 %), step = 9e-03 (250 m%)
    dc: vin = 1.557 (43.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.566 (43.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.575 (43.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.584 (44 %), step = 9e-03 (250 m%)
    dc: vin = 1.593 (44.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.602 (44.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.611 (44.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.62 (45 %), step = 9e-03 (250 m%)
    dc: vin = 1.629 (45.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.638 (45.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.647 (45.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.656 (46 %), step = 9e-03 (250 m%)
    dc: vin = 1.665 (46.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.674 (46.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.683 (46.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.692 (47 %), step = 9e-03 (250 m%)
    dc: vin = 1.701 (47.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.71 (47.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.719 (47.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.728 (48 %), step = 9e-03 (250 m%)
    dc: vin = 1.737 (48.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.746 (48.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.755 (48.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.764 (49 %), step = 9e-03 (250 m%)
    dc: vin = 1.773 (49.2 %), step = 9e-03 (250 m%)
    dc: vin = 1.782 (49.5 %), step = 9e-03 (250 m%)
    dc: vin = 1.791 (49.8 %), step = 9e-03 (250 m%)
    dc: vin = 1.8 (50 %), step = 9e-03 (250 m%)
    dc: vin = 1.791 (50.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.782 (50.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.773 (50.7 %), step = -9e-03 (250 m%)
    dc: vin = 1.764 (51 %), step = -9e-03 (250 m%)
    dc: vin = 1.755 (51.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.746 (51.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.737 (51.7 %), step = -9e-03 (250 m%)
    dc: vin = 1.728 (52 %), step = -9e-03 (250 m%)
    dc: vin = 1.719 (52.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.71 (52.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.701 (52.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.692 (53 %), step = -9e-03 (250 m%)
    dc: vin = 1.683 (53.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.674 (53.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.665 (53.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.656 (54 %), step = -9e-03 (250 m%)
    dc: vin = 1.647 (54.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.638 (54.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.629 (54.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.62 (55 %), step = -9e-03 (250 m%)
    dc: vin = 1.611 (55.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.602 (55.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.593 (55.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.584 (56 %), step = -9e-03 (250 m%)
    dc: vin = 1.575 (56.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.566 (56.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.557 (56.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.548 (57 %), step = -9e-03 (250 m%)
    dc: vin = 1.539 (57.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.53 (57.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.521 (57.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.512 (58 %), step = -9e-03 (250 m%)
    dc: vin = 1.503 (58.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.494 (58.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.485 (58.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.476 (59 %), step = -9e-03 (250 m%)
    dc: vin = 1.467 (59.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.458 (59.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.449 (59.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.44 (60 %), step = -9e-03 (250 m%)
    dc: vin = 1.431 (60.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.422 (60.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.413 (60.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.404 (61 %), step = -9e-03 (250 m%)
    dc: vin = 1.395 (61.3 %), step = -9e-03 (250 m%)
    dc: vin = 1.386 (61.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.377 (61.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.368 (62 %), step = -9e-03 (250 m%)
    dc: vin = 1.359 (62.3 %), step = -9e-03 (250 m%)
    dc: vin = 1.35 (62.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.341 (62.7 %), step = -9e-03 (250 m%)
    dc: vin = 1.332 (63 %), step = -9e-03 (250 m%)
    dc: vin = 1.323 (63.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.314 (63.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.305 (63.7 %), step = -9e-03 (250 m%)
    dc: vin = 1.296 (64 %), step = -9e-03 (250 m%)
    dc: vin = 1.287 (64.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.278 (64.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.269 (64.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.26 (65 %), step = -9e-03 (250 m%)
    dc: vin = 1.251 (65.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.242 (65.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.233 (65.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.224 (66 %), step = -9e-03 (250 m%)
    dc: vin = 1.215 (66.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.206 (66.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.197 (66.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.188 (67 %), step = -9e-03 (250 m%)
    dc: vin = 1.179 (67.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.17 (67.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.161 (67.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.152 (68 %), step = -9e-03 (250 m%)
    dc: vin = 1.143 (68.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.134 (68.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.125 (68.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.116 (69 %), step = -9e-03 (250 m%)
    dc: vin = 1.107 (69.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.098 (69.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.089 (69.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.08 (70 %), step = -9e-03 (250 m%)
    dc: vin = 1.071 (70.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.062 (70.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.053 (70.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.044 (71 %), step = -9e-03 (250 m%)
    dc: vin = 1.035 (71.2 %), step = -9e-03 (250 m%)
    dc: vin = 1.026 (71.5 %), step = -9e-03 (250 m%)
    dc: vin = 1.017 (71.8 %), step = -9e-03 (250 m%)
    dc: vin = 1.008 (72 %), step = -9e-03 (250 m%)
    dc: vin = 999e-03 (72.2 %), step = -9e-03 (250 m%)
    dc: vin = 990e-03 (72.5 %), step = -9e-03 (250 m%)
    dc: vin = 981e-03 (72.8 %), step = -9e-03 (250 m%)
    dc: vin = 972e-03 (73 %), step = -9e-03 (250 m%)
    dc: vin = 963e-03 (73.2 %), step = -9e-03 (250 m%)
    dc: vin = 954e-03 (73.5 %), step = -9e-03 (250 m%)
    dc: vin = 945e-03 (73.8 %), step = -9e-03 (250 m%)
    dc: vin = 936e-03 (74 %), step = -9e-03 (250 m%)
    dc: vin = 927e-03 (74.2 %), step = -9e-03 (250 m%)
    dc: vin = 918e-03 (74.5 %), step = -9e-03 (250 m%)
    dc: vin = 909e-03 (74.8 %), step = -9e-03 (250 m%)
    dc: vin = 900e-03 (75 %), step = -9e-03 (250 m%)
    dc: vin = 891e-03 (75.2 %), step = -9e-03 (250 m%)
    dc: vin = 882e-03 (75.5 %), step = -9e-03 (250 m%)
    dc: vin = 873e-03 (75.8 %), step = -9e-03 (250 m%)
    dc: vin = 864e-03 (76 %), step = -9e-03 (250 m%)
    dc: vin = 855e-03 (76.2 %), step = -9e-03 (250 m%)
    dc: vin = 846e-03 (76.5 %), step = -9e-03 (250 m%)
    dc: vin = 837e-03 (76.8 %), step = -9e-03 (250 m%)
    dc: vin = 828e-03 (77 %), step = -9e-03 (250 m%)
    dc: vin = 819e-03 (77.2 %), step = -9e-03 (250 m%)
    dc: vin = 810e-03 (77.5 %), step = -9e-03 (250 m%)
    dc: vin = 801e-03 (77.8 %), step = -9e-03 (250 m%)
    dc: vin = 792e-03 (78 %), step = -9e-03 (250 m%)
    dc: vin = 783e-03 (78.2 %), step = -9e-03 (250 m%)
    dc: vin = 774e-03 (78.5 %), step = -9e-03 (250 m%)
    dc: vin = 765e-03 (78.8 %), step = -9e-03 (250 m%)
    dc: vin = 756e-03 (79 %), step = -9e-03 (250 m%)
    dc: vin = 747e-03 (79.2 %), step = -9e-03 (250 m%)
    dc: vin = 738e-03 (79.5 %), step = -9e-03 (250 m%)
    dc: vin = 729e-03 (79.8 %), step = -9e-03 (250 m%)
    dc: vin = 720e-03 (80 %), step = -9e-03 (250 m%)
    dc: vin = 711e-03 (80.2 %), step = -9e-03 (250 m%)
    dc: vin = 702e-03 (80.5 %), step = -9e-03 (250 m%)
    dc: vin = 693e-03 (80.8 %), step = -9e-03 (250 m%)
    dc: vin = 684e-03 (81 %), step = -9e-03 (250 m%)
    dc: vin = 675e-03 (81.2 %), step = -9e-03 (250 m%)
    dc: vin = 666e-03 (81.5 %), step = -9e-03 (250 m%)
    dc: vin = 657e-03 (81.8 %), step = -9e-03 (250 m%)
    dc: vin = 648e-03 (82 %), step = -9e-03 (250 m%)
    dc: vin = 639e-03 (82.2 %), step = -9e-03 (250 m%)
    dc: vin = 630e-03 (82.5 %), step = -9e-03 (250 m%)
    dc: vin = 621e-03 (82.8 %), step = -9e-03 (250 m%)
    dc: vin = 612e-03 (83 %), step = -9e-03 (250 m%)
    dc: vin = 603e-03 (83.2 %), step = -9e-03 (250 m%)
    dc: vin = 594e-03 (83.5 %), step = -9e-03 (250 m%)
    dc: vin = 585e-03 (83.8 %), step = -9e-03 (250 m%)
    dc: vin = 576e-03 (84 %), step = -9e-03 (250 m%)
    dc: vin = 567e-03 (84.2 %), step = -9e-03 (250 m%)
    dc: vin = 558e-03 (84.5 %), step = -9e-03 (250 m%)
    dc: vin = 549e-03 (84.8 %), step = -9e-03 (250 m%)
    dc: vin = 540e-03 (85 %), step = -9e-03 (250 m%)
    dc: vin = 531e-03 (85.2 %), step = -9e-03 (250 m%)
    dc: vin = 522e-03 (85.5 %), step = -9e-03 (250 m%)
    dc: vin = 513e-03 (85.8 %), step = -9e-03 (250 m%)
    dc: vin = 504e-03 (86 %), step = -9e-03 (250 m%)
    dc: vin = 495e-03 (86.2 %), step = -9e-03 (250 m%)
    dc: vin = 486e-03 (86.5 %), step = -9e-03 (250 m%)
    dc: vin = 477e-03 (86.8 %), step = -9e-03 (250 m%)
    dc: vin = 468e-03 (87 %), step = -9e-03 (250 m%)
    dc: vin = 459e-03 (87.2 %), step = -9e-03 (250 m%)
    dc: vin = 450e-03 (87.5 %), step = -9e-03 (250 m%)
    dc: vin = 441e-03 (87.8 %), step = -9e-03 (250 m%)
    dc: vin = 432e-03 (88 %), step = -9e-03 (250 m%)
    dc: vin = 423e-03 (88.2 %), step = -9e-03 (250 m%)
    dc: vin = 414e-03 (88.5 %), step = -9e-03 (250 m%)
    dc: vin = 405e-03 (88.8 %), step = -9e-03 (250 m%)
    dc: vin = 396e-03 (89 %), step = -9e-03 (250 m%)
    dc: vin = 387e-03 (89.2 %), step = -9e-03 (250 m%)
    dc: vin = 378e-03 (89.5 %), step = -9e-03 (250 m%)
    dc: vin = 369e-03 (89.8 %), step = -9e-03 (250 m%)
    dc: vin = 360e-03 (90 %), step = -9e-03 (250 m%)
    dc: vin = 351e-03 (90.2 %), step = -9e-03 (250 m%)
    dc: vin = 342e-03 (90.5 %), step = -9e-03 (250 m%)
    dc: vin = 333e-03 (90.8 %), step = -9e-03 (250 m%)
    dc: vin = 324e-03 (91 %), step = -9e-03 (250 m%)
    dc: vin = 315e-03 (91.2 %), step = -9e-03 (250 m%)
    dc: vin = 306e-03 (91.5 %), step = -9e-03 (250 m%)
    dc: vin = 297e-03 (91.8 %), step = -9e-03 (250 m%)
    dc: vin = 288e-03 (92 %), step = -9e-03 (250 m%)
    dc: vin = 279e-03 (92.2 %), step = -9e-03 (250 m%)
    dc: vin = 270e-03 (92.5 %), step = -9e-03 (250 m%)
    dc: vin = 261e-03 (92.8 %), step = -9e-03 (250 m%)
    dc: vin = 252e-03 (93 %), step = -9e-03 (250 m%)
    dc: vin = 243e-03 (93.2 %), step = -9e-03 (250 m%)
    dc: vin = 234e-03 (93.5 %), step = -9e-03 (250 m%)
    dc: vin = 225e-03 (93.8 %), step = -9e-03 (250 m%)
    dc: vin = 216e-03 (94 %), step = -9e-03 (250 m%)
    dc: vin = 207e-03 (94.2 %), step = -9e-03 (250 m%)
    dc: vin = 198e-03 (94.5 %), step = -9e-03 (250 m%)
    dc: vin = 189e-03 (94.8 %), step = -9e-03 (250 m%)
    dc: vin = 180e-03 (95 %), step = -9e-03 (250 m%)
    dc: vin = 171e-03 (95.2 %), step = -9e-03 (250 m%)
    dc: vin = 162e-03 (95.5 %), step = -9e-03 (250 m%)
    dc: vin = 153e-03 (95.8 %), step = -9e-03 (250 m%)
    dc: vin = 144e-03 (96 %), step = -9e-03 (250 m%)
    dc: vin = 135e-03 (96.2 %), step = -9e-03 (250 m%)
    dc: vin = 126e-03 (96.5 %), step = -9e-03 (250 m%)
    dc: vin = 117e-03 (96.8 %), step = -9e-03 (250 m%)
    dc: vin = 108e-03 (97 %), step = -9e-03 (250 m%)
    dc: vin = 99e-03 (97.2 %), step = -9e-03 (250 m%)
    dc: vin = 90e-03 (97.5 %), step = -9e-03 (250 m%)
    dc: vin = 81e-03 (97.8 %), step = -9e-03 (250 m%)
    dc: vin = 72e-03 (98 %), step = -9e-03 (250 m%)
    dc: vin = 63e-03 (98.2 %), step = -9e-03 (250 m%)
    dc: vin = 54e-03 (98.5 %), step = -9e-03 (250 m%)
    dc: vin = 45e-03 (98.8 %), step = -9e-03 (250 m%)
    dc: vin = 36e-03 (99 %), step = -9e-03 (250 m%)
    dc: vin = 27e-03 (99.2 %), step = -9e-03 (250 m%)
    dc: vin = 18e-03 (99.5 %), step = -9e-03 (250 m%)
    dc: vin = 9e-03 (99.8 %), step = -9e-03 (250 m%)
    dc: vin = 0 (100 %), step = -9e-03 (250 m%)
    Total time required for dc analysis `dc': CPU = 432.934 ms, elapsed = 446.037 ms.
    Time accumulated: CPU = 1.09483 s, elapsed = 2.61271 s.
    Peak resident memory used = 61 Mbytes.
    158 notices suppressed.
    modelParameter: writing model parameter values to rawfile.
    element: writing instance parameter values to rawfile.
    outputParameter: writing output parameter values to rawfile.
    designParamVals: writing netlist parameters to rawfile.
    primitives: writing primitives to rawfile.
    subckts: writing subcircuits to rawfile.
  • Pyroblast
    Pyroblast over 9 years ago
    Did you tried without using the Hysteresis option, in the dc analysis?
  • BaaB
    I already tried that but the result is exactly the same.
    I tried various MMSIM13.1 subversions (you didn't say which you were using) and it works OK for me:
    I've (hopefully) attached a gzipped tar file (use "tar xvfz hysteresis.tgz" to unpack it) where you can use "./runAndPlot" to run the simulation and plot the results - this is using a simple behavioural model of a comparator so that it's portable across different technologies. See if this works for you?
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/38/hysteresis.tgz
