  3. Glitch(Spike) in the output..
  • Subscribers 132
  • Views 4562
Raki87
Raki87 over 13 years ago
Hello..I am new to cadence, I was trying to simulate the simple 'd' latch using cadence, but i noticed that there is a spike in the output going above my supply voltage and below the ground level( i have rise and fall time of clock and D input as 5 ns). When i increase the rise time and fall time of my clock(D) the glitch is reduced, but my fellow students who use the same version of the cadence, are getting the correct output even for rise , fall time of 5n sec. i get this glitch only when i simulate the schematic and not in layout simulation.. Is there anythin i missed in my transient analysis? because of this glitch my desired attributes are not met, please suggest me a way out..Thanks!
  • grasshopper
    grasshopper over 13 years ago
     Hi Raki87,
     can you please clarify what tools are you using? As far as RTL synthesis is concerned, most if not all synthesis tools in the market place do not perform any glitch mitigation so it is left to user to design circuity that is glitch tolerant. In fact, this is one of the reasons, why most synthesis tools are meant to be used for synchronous design and not asynchronous design. Glitches in such cases would lead to hazards, etc.
     gh-
  • Raki87
    I am using Cadence spectre/Virtuoso for my simulation. I have a "D" latch driven by clock adn whenever the clock is transiting from high to low or low to high, there is a glitch in the output. If i increase the rise time of my clock the glitch will reduce, but my friend using the same tool, same version, same inputs works completely fine for him( even at low rise time of clock, (without any glitch). I wonder what might be wrong in my circuit.
    If i perform the post layout simulation of the same circuit it works fine, i have problem if i simulate my pre layout schematic. Please let me know if you need further info reg this.
    Thanks!
    Rakesh
