  3. How to change calculator default settings?
  • Subscribers 132
  • Views 16026
Steve Mikes
Steve Mikes over 13 years ago
Not a huge issue, but I'm annoyed how the stack always comes up by default in the calculator and compresses the function list. I don't normally need to see the stack, so I uncheck View->Show Stack. Is there a way to set this as the default option so I don't have to do it every time I bring up the calculator window? Thanks.
    Assuming you're talking about IC615 (or even IC614, I think), it should remember this from one invocation of virtuoso to the next (automatically)...
  • Steve Mikes
     I'm using IC615. It doesn't remember from one instance of the calculator window to another, let alone the virtuoso session. Is there maybe a .cdsenv variable for this?
     Steve
    Steve,
    Hmm, looks like a bug to me. The other View-> items are remembered, and View->Show Stack used to be remembered in IC614. There isn't a cdsenv that controls this as far as I know.
    Please log this with customer support so that we can get this fixed.
