  3. (Virtuoso) how to move/stretch an object by a deltaX (or...
  • Views 10611
(Virtuoso) how to move/stretch an object by a deltaX (or Y) distance?
SUEE
SUEE over 13 years ago
I want to move/stretch an object by a relative distance, say 5um.
I can do it by observing the the dx value shown at the top of the layout window, but in another way, how could I drectly key in the 5um so that the object is moved to the desired coordination directly.
I key in 5 in the delta X column inside the dialogue box and press enyer, it does not work.
I press the "applyXY" buttom but it shows "You should change the snap mode for DeltXY to work". What does it mean? What should I do?
Please help !!  I have hundres of line to move/stretch !!
  • berndfi
    berndfi over 13 years ago
    For the snap you have to go to the "Display Options".
    Probably the move is not allowed because your violationg something.
    Or your moving the objects offgrid.
    But the probably most simplest way to do a relative move/strech is
    if when you get prompted for a reference point for your move/stretch
    you enter the origin coordinates (0.0:0.0) in the input pane of the CIW.
    And if you get prompted for the new point or location you enter
    the coordinates for the relative move/stretch in the CIW.
  • dmay
    dmay over 13 years ago
    On the options form for Move or Stretch, toggle the Snap Mode cyclic field to Any Angle and then the Apply XY will work.
    Derek
