  3. Virtuoso Library size limit
  • Subscribers 132
  • Views 16112
ARYAMVALLI
ARYAMVALLI over 13 years ago
 I am working on a memory compiler project and is now trying to stream in around 2000 cuts to
a particular library,but after streaming in around 500 cuts into my particular library the tool is automatically creating
individual libraries for each cuts.Is there any size limit for a single LIBRARY in cadence virtuoso (I am using the version IC6.1.5.500.9).Is there any available methods to increase the size of library?
Regards
Vipin
  • AndreasLenz
    AndreasLenz over 13 years ago
    Hello Vipin,
    The number of objects handled in one single directory is limited.
    If you would like to increase the number of objects in a directory try  strmin -help and you find a variable named maxCellsInTargetLib.You could increase this variable up to the limit defined by the LINK_MAX of your system. The default setting as implemented in Virtuoso is 20.000.
        Andreas
