  3. Accessing models file "section" in verilog code.
  • Subscribers 132
  • Views 1084
HsFetterman
HsFetterman over 13 years ago
Does anyone know how to access the models file "section" from within a verilog model?  I'd like to make a model that is aware of the process corner being simulated to adjust circuit parameters.
    Do you mean verilog, or Verilog-A? Either way, this is not that straightforward - you would probably have to have a parameter which varied over the corners, and then pass that into an instance of your Verilog-A/Verilog-AMS model.
