  3. QRC extraction & BUS
  • Subscribers 136
  • Views 3869
Zdeno
Zdeno over 13 years ago
Hi guys,
I have problem with simulation of BUSes in extraction view. I use IC615, Assura QRC. First I simulate gate-level verilog netlist with AMS. In verilog I have bus cnf_reg_analog<15:3> and I can plot results from this bus. Then I create abstract with Encounter, then layout. Run Assura LVS -> Clean. Run Assura QRC -> create extracted view.
The problem is that in layout the bus net name looks like cnf_reg_analog<15> and in the extracted view looks like cnf_reg_analog(15). Note the brackets. And ADEXL (AMS simulator) complains:
ERROR (WIA-1006): Unable to plot expression <VT("/cnf_reg_analog<15>" "/home/cadence/simulation/TEST_BENCHES_PHpix1/PHpix1_channel_digi_tb/adexl/results/data/Interactive.12/psf/tran")>
because it does not evaluate to an object that can be plotted, like a waveform or
parametric wave. See the Visualization & Analysis Tool documentation for information
about the types of objects that can be plotted in Visualization & Analysis Tool. Only
the expressions that evaluate to those objects can be plotted.
*Warning* Wave2 is not a waveform object that can be displayed and
will be DELETED automatically.
So I assume that the problem is in bus extraction and brackets, but I do not know how to correct it.
I attached the properties of the net in layout and in extracted view for better understanding.
Do you have any idea how to simulate the BUS in extracted view?
Thank you, Zdeno
 layout
  • Quek
    Quek over 13 years ago
    Hi Zdeno
    You can convert the round brackets to angled brackets during extracted view generation using the skillscript in solution 11290520.
    Best regards
    Quek
  • Zdeno
     Hi Quek,
     Thank you very much for the solution! That's works perfectly.
     Best regards,
     Zdeno
  • mbchang
    mbchang over 9 years ago
    Quek,
    I found this old article. The solution provided is no longer available. Do you still have the SKILL code?
    Jerry
    Jerry,
    I fixed the link. I personally don't think this should be necessary - internal nets inside an extracted view should have () rather than <> because they are in the CDBAflat namespace, but it does seem a rather popular thing to want to do. I have had other cases where doing this breaks things - so I'm a bit skeptical of the need to do this!
  • mbchang
    Andrew,
    Thanks. I will check the link. We have designer using irun and "()" gives irun error saying the program encountered errors while processing the input SPICE files. change "()" back to "<>" fixed the error.
    -Jerry
    That shouldn't happen - there should be some mapping in the netlist to ensure the netlist is always legal. Anyway, perhaps you can follow this up with customer support because maybe it's a bug in the specific subversion of the tools you're using, and maybe it's already been fixed.
    Regard,
