  3. Add pins and pin names quickly to symbol
  • Views 23712
Tobben24
Tobben24 over 13 years ago
 I really like the "Wire stubs and names" feature/function in the "Create" dropdown menu in Schematic Editor, but is there a similar way to add pins with pin names?
    Not quite - there is a Create->Mapping Schematic which (sort of) does this - it's primarily intended to create a schematic which maps from one cell to another.
  • SteveRFIC
    SteveRFIC over 9 years ago
    Andew,
    are you aware of any skill code that does this function? I have been searching but no luck yet.
    Which? The create wire stubs or create mapping schematic? There aren't any built-in procedural versions of either (only the functions that bring up the form). I did write this some time ago for creating wire stubs, but it's not terribly smart about the placement of the stub:
    /* abCreateWireStubs.il
    Author     Andrew Beckett
    Language   SKILL
    Date       Jul 07, 2000
    Modified
    By
    Create wire stubs for any instance pin which has a net
    name, but no existing wire.
    SCCS Info: @(#) abCreateWireStubs.il 07/07/00.17:01:10 1.1
    (procedure (abCreateWireStubs @key (cellView (geGetEditCellView)) (stub 0.03125)
                                  (labelJustify "lowerLeft") (labelOrient "R0")
                                  (labelFont "stick") (labelHeight 0.03125) (debug nil))
      (let (transform pinCentre wireEnd netName lineList)
           /* loop over all the instances which are not pins */
           (foreach inst (dbGetq cellView instances)
                    (when (equal (dbGetq inst purpose) "cell")
                          (setq transform (dbGetq inst transform))
                          /* Now go over each terminal, and each pin for that terminal */
                          (foreach instTerm (dbGetq inst instTerms)
                                   (foreach pin (dbGetq (dbGetq instTerm term) pins)
                                            /* If there isn't a piece of wire over the pin anyway
                                               add the stub */
                                            (unless
                                             (dbGetTrueOverlaps
                                              cellView
                                              (dbTransformBBox
                                               (dbGetq (dbGetq pin fig) bBox)
                                               transform
                                              '("wire" "drawing")
                                              0
                                             /* calculate the coordinates for the stub */
                                             (setq pinCentre
                                                   (centerBox
                                             (setq wireEnd
                                                   (list
                                                    (plus
                                                     (xCoord pinCentre)
                                                     (if (equal (dbGetq instTerm direction) "input")
                                                         (minus stub)
                                                         stub)
                                                    (yCoord pinCentre)
                                             /* transform them accordingly */
                                             (setq pinCentre (dbTransformPoint pinCentre transform))
                                             (setq wireEnd (dbTransformPoint wireEnd transform))
                                             (setq netName (dbGetq (dbGetq instTerm net) name))
                                             /* create the stub wire */
                                             (setq lineList
                                                   (schCreateWire
                                                    cellView "draw" "" (list pinCentre wireEnd) 0.0 0.0 0.0)
                                             /* label it */
                                             (when (car lineList)
                                                   (schCreateWireLabel
                                                    cellView (car lineList) wireEnd netName
                                                    labelJustify labelOrient labelFont labelHeight nil
                                             (when debug
                                                   (printf "Added stub to %L for pin %L of %L\n"
                                                           (dbGetq instTerm name)
                                                           (dbGetq inst name)
    I've written other code to determine the side that a pin is on which could be combined with this to make it smarter about which direction it draws the wire -
    Andrew Beckett
    Replied to: How to determine the direction of a wire out of a symbol pin in schematic
    Hi Michele, Here's a snippet of some code I've used to determine which edge the pin is on (it doesn't have a prefix, because it was a local function in a SKILL++ source file, so adjust it to suit your…
    By Andrew Beckett over 10 years ago in Cadence Technology Forums > Custom IC SKILL
    but I've never joined the two together.
  • SteveRFIC
    Thanks a lot Andrew!
    I tried your script and it works pretty well. Probably someone took your code and integrated it in cadence, so now we have this function from the cadence menu :)
    What I was looking for was to add pins, with proper names. For instance, if I have a instance symbol in my schematic, I want to create a pin for each terminal of that symbol with the same name.
    I found a solution from the following page:
    https://groups.google.com/forum/#!topic/comp.cad.cadence/tQTCQot61Hk
    Thanks to all the people who share their knowledges.
    Gang
