  3. Corner Simulation Error
  • Replies 10
  • Subscribers 136
  • Views 26886
wgtkan
wgtkan over 13 years ago
I am trying to do corner simulation. I have set up the corner simulation by clicking   import PCF button and from my pdk install directory by selecting the pcf file. After successfully loading the corner for analysis, in the run mode pane, I selected Single Run, Sweeps and Corners and it showed 3 corner plus the nominal corner are checked to be available for simulation.  Then I clicked the green button in ADE XL.
My version is Virtuoso Analog Design Environment Version IC6.1.5 -64b.500.15
Then after simulation is completed, I get the following error messages. What could be the problem?
Here is what I get.
Simulating `input.scs' on tcad1.tec.ufl.edu at 7:39:44 AM, Mon Mar 25, 2013 (process id: 23180).
Command line:
    /apps/cds/mmsim101/tools.lnx86/spectre/bin/64bit/spectre input.scs  \
        +escchars +log ../psf/spectre.out -format psfxl -raw ../psf  \
        +lqtimeout 900 -maxw 5 -maxn 5
Loading /apps/cds/mmsim101/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
Loading /apps/cds/mmsim101/tools.lnx86/cmi/lib/64bit/5.0/libphilips_sh.so ...
Loading /apps/cds/mmsim101/tools.lnx86/cmi/lib/64bit/5.0/libsparam_sh.so ...
Loading /apps/cds/mmsim101/tools.lnx86/cmi/lib/64bit/5.0/libstmodels_sh.so ...
Error found by spectre during circuit read-in.
    ERROR (SFE-868): "input.scs" 8: Unable to open input file `cor_rfmos.scs'.
        No such file or directory.
    ERROR (SFE-868): "input.scs" 9: Unable to open input file `cor_rfmos33.scs'.
    ERROR (SFE-868): "input.scs" 10: Unable to open input file `cor_rfmvar.scs'.
    ERROR (SFE-868): "input.scs" 11: Unable to open input file `cor_rfmvar_33.scs'.
    ERROR (SFE-868): "input.scs" 12: Unable to open input file `cor_rfjvar.scs'.
    ERROR (SFE-868): "input.scs" 13: Unable to open input file `cor_rfres_sa.scs'.
    ERROR (SFE-868): "input.scs" 14: Unable to open input file `cor_rfres_rpo.scs'.
    ERROR (SFE-868): "input.scs" 15: Unable to open input file `cor_rfres_hri.scs'.
    ERROR (SFE-868): "input.scs" 16: Unable to open input file `cor_rfesd.scs'.
    ERROR (SFE-868): "input.scs" 17: Unable to open input file `cor_rfsbd.scs'.
    ERROR (SFE-868): "input.scs" 18: Unable to open input file `cor_rffmom.scs'.
    ERROR (SFE-868): "input.scs" 19: Unable to open input file `cor_rfmim.scs'.
    ERROR (SFE-868): "input.scs" 20: Unable to open input file `cor_rfind.scs'.
    ERROR (SFE-868): "input.scs" 21: Unable to open input file `cor_std_mos.scs'.
    ERROR (SFE-868): "input.scs" 22: Unable to open input file `cor_3v.scs'.
    ERROR (SFE-868): "input.scs" 23: Unable to open input file `cor_m.scs'.
    ERROR (SFE-868): "input.scs" 24: Unable to open input file `cor_3m.scs'.
    ERROR (SFE-868): "input.scs" 25: Unable to open input file `cor_na.scs'.
    ERROR (SFE-868): "input.scs" 26: Unable to open input file `cor_3vna.scs'.
    ERROR (SFE-868): "input.scs" 27: Unable to open input file `cor_bip.scs'.
    ERROR (SFE-868): "input.scs" 28: Unable to open input file `cor_bip3.scs'.
    ERROR (SFE-868): "input.scs" 29: Unable to open input file `cor_dio.scs'.
    ERROR (SFE-868): "input.scs" 30: Unable to open input file `cor_dio3.scs'.
    ERROR (SFE-868): "input.scs" 31: Unable to open input file `cor_dio_m.scs'.
    ERROR (SFE-868): "input.scs" 32: Unable to open input file `cor_dio_3m.scs'.
    ERROR (SFE-868): "input.scs" 33: Unable to open input file `cor_dio_dnw.scs'.
    ERROR (SFE-868): "input.scs" 34: Unable to open input file `cor_res.scs'.
    ERROR (SFE-868): "input.scs" 35: Unable to open input file `cor_disres.scs'.
    ERROR (SFE-868): "input.scs" 36: Unable to open input file `cor_bbmvar.scs'.
    ERROR (SFE-868): "input.scs" 37: Unable to open input file `cor_mim.scs'.
    ERROR (SFE-868): "input.scs" 38: Unable to open input file `cor_rtmom.scs'.
    ERROR (SFE-868): "input.scs" 39: Unable to open input file `cor_fmom.scs'.
Time for NDB Parsing: CPU = 82.986 ms, elapsed = 106.877 ms.
Time accumulated: CPU = 82.986 ms, elapsed = 106.877 ms.
Peak resident memory used = 33.9 Mbytes.
Time for parsing: CPU = 0 s, elapsed = 9.05991 us.
Time accumulated: CPU = 83.986 ms, elapsed = 107.051 ms.
Aggregate audit (7:39:44 AM, Mon Mar 25, 2013):
Time used: CPU = 85 ms, elapsed = 109 ms, util. = 78.3%.
Time spent in licensing: elapsed = 55.9 ms, percentage of total = 51.5%.
Peak memory used = 33.9 Mbytes.
Simulation started at: 7:39:44 AM, Mon Mar 25, 2013, ended at: 7:39:44 AM, Mon Mar 25, 2013, with elapsed time (wall clock): 109 ms.
spectre completes with 32 errors, 0 warnings, and 0 notices.
spectre terminated prematurely due to fatal error.
    Presumably your pcf file doesn't have the full path to the files, so maybe you need to do Setup->Simulation files in each test and specify an "include path" to be the directory where the spectre models live?
  • wgtkan
    Thank you Andrew. Under set up > simulation Files I included a path where the model librarie lives. Now I am getting the following error. I opened  up the cro18gpii_V1do.scs and it is defined under section ff. I changed the section to ff and I do not know what to do.
    Here is the error:
    imulating `input.scs' on tcad1.tec.ufl.edu at 9:22:44 AM, Mon Mar 25, 2013 (process id: 1343).
    Command line:
            -I/home/grps/ef-test/TSMC180nm-Mixed-Sign_T/PDK/TSMC180nm/models/spectre  \
    Time for NDB Parsing: CPU = 722.889 ms, elapsed = 810.31 ms.
    Time accumulated: CPU = 722.889 ms, elapsed = 810.31 ms.
    Peak resident memory used = 57.8 Mbytes.
    Error found by spectre during hierarchy flattening.
        ERROR (SFE-1996): "/home/grps/ef-test/TSMC180nm-Mixed-Sign_T/PDK/TSMC180nm/models/spectre//cr018gpii_v1d0.scs" 23862: parameter `noicn': Unknown parameter name `par1fn_mc' found in expression.
        ERROR (SFE-1996): "/home/grps/ef-test/TSMC180nm-Mixed-Sign_T/PDK/TSMC180nm/models/spectre//cr018gpii_v1d0.scs" 23860: parameter `noian': Unknown parameter name `par1fn_mc' found in expression.
        ERROR (SFE-1996): "/home/grps/ef-test/TSMC180nm-Mixed-Sign_T/PDK/TSMC180nm/models/spectre//cr018gpii_v1d0.scs" 23861: parameter `noibn': Unknown parameter name `par1fn_mc' found in expression.
        ERROR (SFE-1996): "/home/grps/ef-test/TSMC180nm-Mixed-Sign_T/PDK/TSMC180nm/models/spectre//cr018gpii_v1d0.scs" 23866: parameter `noicp': Unknown parameter name `par1fn_mc' found in expression.
        ERROR (SFE-1996): "/home/grps/ef-test/TSMC180nm-Mixed-Sign_T/PDK/TSMC180nm/models/spectre//cr018gpii_v1d0.scs" 23864: parameter `noiap': Unknown parameter name `par1fn_mc' found in expression.
        ERROR (SFE-1996): "/home/grps/ef-test/TSMC180nm-Mixed-Sign_T/PDK/TSMC180nm/models/spectre//cr018gpii_v1d0.scs" 23865: parameter `noibp': Unknown parameter name `par1fn_mc' found in expression.
    Time for Elaboration: CPU = 23.996 ms, elapsed = 25.0032 ms.
    Time accumulated: CPU = 747.885 ms, elapsed = 835.617 ms.
    Peak resident memory used = 62.6 Mbytes.
    Probably best to ask TSMC - I don't have access to that particular PDK (given the names of teh model files) - presumably you need to include a section containing par1fn_mc  - maybe you can do a "grep" through the model files to see where it is defined?
    Hopefully this is covered in the documentation with the PDK too.
  • wgtkan
    Thank you Andrew:
    I opened up the cro18gpii_V1do.scs and the par1fn_mc is contained under:
    Section ff
    include "cr018gpii_v1d0.scs" section=noiseflag
    include "cr018gpii_v1d0.scs" section=cco_pre_simu
    Currently the section is set on stat_noise. I tried changing the section to noiseflag and I keep getting the error it is previously defined. Is it possible to add two sections for one model file?
    I looked in there PDK documentations but I couldn’t find anything.
    Thank you.
    Yes, you can include multiple sections from the same model file (you have to have multiple includes, of course) - numerous PDKs work this way.
    Asking the PDK provider is the safest bet, because even though I might be able to guess, it's important to know what is "right".
    Note that if a model file is controlled via the corners UI, the   Setup->Model Libraries in the ADE XL test editor is not used - all inclusions of that file need to be done from the Corners Setup UI.
  • berndfi
    berndfi over 13 years ago
     As discussed I believe you miss a required model section in your model setup which is assigning the model parameters which you get the errors for.
    Usually the model setting or corners are describe in the model file header, have a look there.
  • wgtkan
     Thank you very much. I contacted the PDK provider and updated to the latest PDK. Issues are resolved.
  • mmar
    mmar over 12 years ago
    I know the post is a little old but i was facing the same problem.
    It can be fixed it by adding the model library cr018gpii_v1d0.scs section statistical noise.
  • paulthehuman
    paulthehuman over 9 years ago
    Hi sir. Im new to Hspice and i was tryin to simulate but i got this error message:
    **error** no definition for         0:par1fn_mc
    It was called by          0:noian
    Im using the 65nm tech. I want to try your suggestion above. How do i add this lib ur talkin about to stat noise?
    Sorry for my ignorance
    Thank you!
    A few problems with your post:
    1. You've appended on the end of an old thread (which is actually about spectre - so a different simulator). The Forum Guidelines ask you not to do this - please read them. That also asks you not to write in "text message" language (like "ur talking about") as this decreases the chance of your question being answered.
    2. Your question is about HSPICE, which is a simulator from Synopsys (not Cadence), so this is probably not the best place to ask this question.
    3. "the 65nm tech" is not very specific - which technology are you talking about (which foundry)?
    4. The most likely problem is that you've not included one of the required model files, but that might be best answered by somebody with specific knowledge of the particular models you're trying to use (this is almost certainly covered in the documentation from the foundry).
