  3. automatically run a routine when a menu item is invoked...
  • Views 16661
automatically run a routine when a menu item is invoked from CIW or schematic window
vtyagi
vtyagi over 13 years ago
Is it possible to use triggers to automatically run a skill function when a user invokes another skill function from a custom drop down menu.
I can do it hard way by modifying each custom function and adding the piece of code but was wandering if there is any auto trigger I can use to do this whenever someone use those functions. I looked into deRegUserTrigger but it works with 'viewType' (schematic, maskLayout etc) I want something similar for drop down menu items (which are also skill functions developed in house).
Thanks !
    There's no trigger as such, but you could easily modify the menu callbacks. For example:
    procedure(CCFdoMyThing()
      printf("Doing my thing...\n")
    pulldownMenu=ciwOptionsMenu
    let((callback)
     foreach(menuItem hiGetMenuItems(pulldownMenu)
      callback=get(pulldownMenu menuItem)->_itemCallback
      when(stringp(callback)
        hiSetMenuItemCallback(pulldownMenu menuItem strcat("CCFdoMyThing() " callback))
  • vtyagi
    Thanks Andrew !
    I was able to make it work with 'Options' menu but had issues :
    1. It worked fine on item directly under main menu but does not trigger callback when used with for submenu item (for example does not work for Tools->AMS->Options but works fine for Tools->Library Manager)
    2. Got error when I try using it on my 'Test' dropdown menu from CIW window (*Error* eval: unbound variable - ciwTestMenu).
    Vikash
    Hi Vikash,
    For the first item the code needs to traverse slider menus, so I altered the code to recursively all itself. See the example in the comments.
    For the second, your menu is presumably not stored in a variable called ciwTestMenu - I'm guessing that you just guessed the name? Try typing hiGetBannerMenus(hiGetCIWindow()) to find out the menus in the CIW.
    /* CCFaddMenuTriggers.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Apr 19, 2013
    Modified
    By
    Example code to add triggers on menu items. For example:
    procedure(CCFdoThis() printf("going to do this\n"))
    procedure(CCFdidThat() printf("have done that\n"))
    CCFaddMenuTriggers(?menu ciwToolsMenu ?preTrigger "CCFdoThis()" ?postTrigger "CCFdidThat()")
    Can specify either preTrigger or postTrigger or both.
    SCCS Info: @(#) CCFaddMenuTriggers.il 04/19/13.09:45:51 1.1
    * CCFaddMenuTriggers(?menu menuVar [?preTrigger ""] [?postTrigger ""]) *
    *   Modify the callbacks in a pulldown menu passed in to either call   *
    *      a pre trigger function, a post trigger function, or both.       *
    *   Slider menus are dealt with by this function recursively calling   *
    *                               itself.                                *
    procedure(CCFaddMenuTriggers(@key menu (preTrigger "") (postTrigger ""))
      let((callback)
        foreach(menuItem hiGetMenuItems(menu)
          if(get(menu menuItem)->hiSubMenu then
            CCFaddMenuTriggers(
              ?menu get(menu menuItem)->hiSubMenu
              ?preTrigger preTrigger
              ?postTrigger postTrigger
          else
            callback=get(menu menuItem)->_itemCallback
              hiSetMenuItemCallback(menu menuItem
                strcat(preTrigger " " callback " " postTrigger)
        t
  • vtyagi
    Thanks Andrew,
    Your solution works perfect !!
    I am trying 'getCallingFunction' to get the name of invoked function(from drop down menu) in my PreTrigger function but getting only PreTrigger function name (CCFdothis) on all levels of stack. Pre and Post trigger functions are exectued as expected but I am not able to recover the name of the function from drop down menu.
    Goal is to find out which function was invoked (from drop dwon menu) and then run a piece of code. Is there any other function I can use to acheieve this ?
    Best Regards
    getCallingFunction() won't help you, because it hasn't called the real menu function yet. Instead you could use this adapted version of the code:
    procedure(CCFaddMenuTriggers(@key menu (trigger ""))
      let((callback)
            CCFaddMenuTriggers(
              ?trigger trigger
          else
            when(stringp(callback) && !blankstrp(trigger)
                sprintf(nil "%s(%L)" trigger callback)
        t
    And then:
    procedure(CCFdoSomething(realCallback)
      printf("Calling %L\n" realCallback)
      errsetstring(realCallback t)
    CCFaddMenuTriggers(?menu ciwToolsMenu ?trigger "CCFdoSomething")
    You're then responsible for calling the real callback (which gets passed into your trigger function) yourself.
