  3. re-using schematic based device current measurement in a...
  • Subscribers 130
  • Views 14035
re-using schematic based device current measurement in a extracted view.
Newmedia
Newmedia over 12 years ago
Hello all,
 I have a current measurement like this in my ade-xl measurement.
OP("/Ibias/MP_ka_ref_cas" "table_ids")
 The problem is that this does not work anymore in extracted view based simulations, since the transistor is splited into multiple devices.
Is there a way to handle this problem.
Thank you,
JW
  • Newmedia
    currently. I have to do something like this.
    OP("/Ibias/MP_ka_ref_cas" "table_ids") +OP(/Ibias/MP_ka_ref_cas@1 "table_ids")+....
     This means I have to change all of my testbench.
    Thank you,
    JW
    Not sure I have an easy answer for this, but what extraction tool are you using?
    Also, which version of the IC tools are you using?
  • Newmedia
    "First time caller, Long time listner!"
    Thank you Andrew!!
    The version is IC6.15. and I'm using Calibre pex for my extraction.
    Thank you,
    JW
  • berndfi
    berndfi over 12 years ago
    Probably there is an option for the extraction to keep the MOS as a multifinger device and not extract each finger as a single  MOS.
    Unfortunately I don't know Calibre PEX good enough.
    I was going to suggest the same as Bernd. There is some support for out-of-context access of operating point data, but that's only with QRC (the Cadence extraction tool), not with third-party extraction tools.
    In general it's non-trivial because it would need to know what kind of quantity the operating point parameter was to know how to recombine it - should it sum them (e.g. for currents), treat them as impedances in parallel, give one of the values (e.g. for voltages), etc etc.
    So best if you can let your LVS/extraction combination combine parallel devices if it can.
