  3. Error in verilogA
  • Subscribers 132
  • Views 17974
Error in verilogA
sreeni
sreeni over 12 years ago
Hi to all
Am designing one model in verilog-A.
In that i have defined one function (Charge_low) and while using it in the main design it showing some error.
Am not able to understand the error.
 hsp-vacomp: Error: syntax error
 hsp-vacomp:     ['SBCNTFET.va',399]
 hsp-vacomp:     Qs_low1 = Charge_low(  2.32  ,H1,b1_1,b0_1)-Charge_low(`alpha_1,L1,b1_1,b0_1);
 hsp-vacomp:                                                         ^
 Error was showing @ the "," after H1.
All variables in the function are declared as real and defined.
Please let me know what may be the error.
SRINI
    Two problems:
    1. The error is coming from the HSPICE veriloga compiler. Given that HSPICE is a Synopsys product, asking about it on a Cadence forum is probably not the best place to ask. We can try, but you're likely to get more accurate answers on a Synopsys forum
    2. You didn't show the code - it's impossible to debug from just a single line...
  • sreeni
    I got habituated to post in cadence forum.
    My code is of some 600 lines i can't post it.
    Am adding few more lines of that function declaration and where am getting error.
    analog function real eeta;
            input x,y;
            real x,y;
            begin
                eeta  = hspsqrt(x*y*y+y);
            end
        endfunction
        analog function charge_low;
        input x,y,b1,bo;
        real x,y,b1,bo;
          begin
             charge_low = eeta(x,y)*((b1*(y-(1/2*x)))+(2*b0))+((b1)/(4*hsppow(x,1.5)))* hspln(((0.5+(x*y))/(hspsqrt(x)))+(eeta(x,y)));
           end
        endfunction
     I posted 'eeta' function also, as a refence.
     And here is those lines where it showing error.
    Qs_low1 = Charge_low(`alpha_1,H1,b1_1,b0_1)-Charge_low(`alpha_1,L1,b1_1,b0_1);
    Please clarify this.
    SRINI
    Srini,
    Again, you didn't really give enough to be sure, but I corrected two mistakes in what you sent me:
    1. The function charge_low had an input called "bo" but in the expression, it's called "b0".
    2. The function is defined as "charge_low" but called as "Charge_low". Verilog-A is case sensitive.
    I then assembled a simple example module using both these, with some definitions for `alpha_1 and the other arguments:
     `include "disciplines.vams"
    module forum (x);
    input x;
    electrical x;
    analog function real hspsqrt;
      input a;
      real a;
      hspsqrt=sqrt(a);
    endfunction
    analog function real hsppow;
      input a,b;
      real a,b;
      hsppow=pow(a,b);
    endfunction
    analog function real hspln;
      input a;
      real a;
      hspln=ln(a);
    endfunction
            input x,y;
            real x,y;
            begin
            end
        endfunction
    //input x,y,b1,bo;
    //real x,y,b1,bo;
    input x,y,b1,b0;
    real x,y,b1,b0;
      begin
       end
    endfunction
    `define alpha_1 2.32
    real H1,b1_1,b0_1,L1,Qs_low1;
    analog begin
        @(initial_step) begin
            H1=1.0;
            b1_1=1.0;
            b0_1=1.0;
            L1=1.0;
            //Qs_low1 = Charge_low(`alpha_1,H1,b1_1,b0_1)-Charge_low(`alpha_1,L1,b1_1,b0_1);
            Qs_low1 = charge_low(`alpha_1,H1,b1_1,b0_1)-charge_low(`alpha_1,L1,b1_1,b0_1);
        end
        V(x) <+ 1.0;
    end
    endmodule
    With spectre, I created this netlist:
    thing (n1) forum
    r1 (n1 0) resistor r=1k
    ahdl_include "forum.va"
    dc dc
    And spectre was quite happy when I ran this. So you need to take this up with Synopsys - assuming that you've corrected the typos I mentioned earlier and that doesn't fix it. Note I had to define all those hspsqrt, hspln, hsppow functions because they don't exist in the standard language. So probably Synopsys customer support is your best bet.
    Kind Regards,
  • sreeni
    What ever you mentioned 1 and 2 were the errors. And now its bug free.
    Thank you so much
     When it showing error in one line i was thinking of same line not the actual function.
    Once again thanks
     Regards
    SRINI
