  3. Virtuoso layout (Connectivity-> Mark Net highlights some...
  • Subscribers 132
  • Views 3958
Virtuoso layout (Connectivity-> Mark Net highlights some faraway wires)
vivkr
vivkr over 12 years ago
I like to use the mark net feature to trace my wiring and make life simpler while routing things in the layout.
Now, I am seeing something pretty weird. When I try to mark a net, then nothing seems to happen in many many cases. If I now zoom out completely, then I see that some completely different wire in a totally different part of the layout has been highlighted. There is no mutual connection between the net I am trying to mark and the one that actually got marked, neither is there any wire hidden below the one I am attempting to mark.
People tell me that they have had this problem fairly often in older versions of Cadence. I am using:
Virtuoso IC6.1.5-64b.500.8
I was also told that this might happen when doing "edit in place" but I am not doing that.
I tried closing all open data and restarting my cadence icfb session but to no avail.
Could someone tell me what the source of the problem might be, and a solution to it?
Vivek
    Vivek,
    I've not seen this, and not searched to see if it has been reported before, but I would suggest that you contact customer support.
  • vivkr
     Andrew,
    Thanks for that quick response. I will try to get in touch with customer support as you say. I think I have to go through our local CAD rep as the above link doesn't work for me (Access Denied). Anyway, I guess that I have to wait a while for a solution.
    Vivek
