  3. Long term jitter from SpectreRF's Phase noise?
  • Subscribers 133
  • Views 5383
archive over 19 years ago
It is true that we can get Jitter from Phase noise simulated from the Spectre by integrating over a noise band of interest. It evident that from the tool that we can get Jcc(cycle to Cycle Jitter) and Jee(Edge to Edge) and Jc.
But I want to know wether we can get "long term jitter" from the SpectreRF's Phase noise simulation.  kindly tell me wether we have any other ways to measure the long term jitter from the spectre.
I beleive the eyediagram technique with transient analysis will not include random noise and other noises.
Also in the Direct plot menu after Pnoise analysis. we have the term "K"( no of cycles). Can you pls tell me what is it.
Can we set k=3000 or (like that number ) to het the longterm jitter?
kindly reply.
Thanks & regards
SavithRu
Originally posted in cdnusers.org by savithru
    Long term jitter is normally determined for a specified number of cycles - so yes, entering the number of cycles is the way to do it.
    Of course, you need to make sure you simulate the noise low enough in frequency to include noise over the total number of cycles you want to capture the long term jitter.
    The calculations will ensure that the integration is done properly over the number of cycles you want.
    You can do transient with an eye-diagram, and turn on transient noise, but this is a much less effective way of measuring jitter (it's less efficient, and less accurate, unless your circuit is non-periodic in nature or has a large signal response to the noise) than pnoise.
    Originally posted in cdnusers.org by adbeckett
    Dear Andrew,
    Thank you very much for your kind reply. Thanks for clarifying me.
    ""you need to make sure you simulate the noise low enough in frequency to include noise over the total number of cycles you want to capture the long term jitter"' .... here noise, in low enough in frequency, meanse what? I have taken it as 10KHz (up to 100M) . Is that value is fine enough to my clock synthesizer driving CPU.
    While simulation, there is no option for giving the time for simulation or simulation of no. of cycles. I beleive the tool will do simulations only for few cycles, And later it only extrapolates for other k=higher values. If this is the case, I doubt that wether this Jitter for k= say 3000 is not realistc.
    Also can you please tell how I can measure the PFD+CP phase noise from Spectre. I want to compare the phase noise of CP+PFd+Divider+LPF with that of VCO.
    Kindly guide me.
    Thanks & Regards
    SavithRu
    I can't tell whether 10kHz is low enough in frequency from the information you've given. If you want 3000 cycles, you need to go down as low as Fcycle/3000 - so if your clock is above 30MHz, you'll be OK.
    Since the jitter is coming from the noise analysis that is done, there is no need to simulate more cycles in the time domain. A single cycle of the output clock will be enough to capture the non-linearities so that pnoise can include all the noise folding that occurs in the circuit. It can then compute the noise response over frequency, and the k-cycle jitter will be dependent on integrating over that number of cycles (but in the frequency domain). So provided you have simulated the pnoise low enough in frequency to capture the noise at that fraction of your clock frequency, you'll be OK. The integration itself is far from trivial, but the pnoise form takes care of that - you just need to ensure that the frequency range is wide enough, and that it you've asked for the number of cycles you want.
    The result should be realistic (in terms of the the random jitter). You won't of course be capturing any deterministic jitter this way.
