  3. LVS on a layout imported from Encounter versus the Physical...
  • Replies 14
  • Subscribers 132
  • Views 28291
LVS on a layout imported from Encounter versus the Physical Verilog netlist
Kabal
Kabal over 12 years ago
I have successfully imported the layout from Encounter, and solved out the residual DRC errors, however; I am not sure now how to do LVS.
Before I had some problems with import which were covered in another subforums here and topics but I solved them all, right now I want to concentrate just on a specific LVS on Encounter Imported Layout issue.
Here are my actions:
1) get the verilog design synthesized properly and routed without geometry/connectivity violations in Encounter [DONE]
2) Properly export it to GDS file [DONE]
3) do saveNetlist -phys -includePowerGround from the Encounter, it basically produces a Physical Verilog netlist, which includes cell description + Power pins. [DONE]
4) Go to Cadence Virtuoso, do CIW->Import->Verilog, there I point to the physical verilog netlist produced by  Encounter and also point to the newly created library based on technology kit with imported proper metal layers.
5) then i start the process of importing scehmatics for CDL, I see that the cells are created one after another, and the main big schematics is created, where each module of the schematic is the standard library cell. However, when I click and get inside that cell I see only ports, and no transistors.
It might look OK, since afterall it has imported physical VERILOG netlist, not a transistor schematic.
But problem starts when I try to produce CDL netlist using the IBM provided Perl script for the LVS. The final output of that script is MY_INSTANCE_NAME.netlist.lvs
However, when I start now doing LVS on the corrected/DRCed Layout, I get errors like:
a) nMOS on layout is unbound to any schematic device
b) pMOS on Layout is unbound to any schematic device
c) subC on Layout unbound to schematic device
Error (c) is OK, I can fix it simbly by adding the substrate contact in the imported schematics.
(reason for that  is that DRC does not pass without proper amount of substrate contacts on a layout, so in an imported layout I added them.. but then again, I added it also in the schematic, so error (c) was gone)
However, what really weird is: why do errors (a) and (b) exist?
From one side, I understand, it does not SEE the transistors because the cells imported from physical verilog dont have one (because verilog describes hardware flow not transistor interconnect)
But from another side, why would it even try to find transistors?
Why does not it treat my imported layout cells as a standalone modules with just ports, because that is what they are.
I even tried creating CDL netlist in "Digital" format from the imported schematics view, same thing.
Am I missing something trivial here?
Any ideas?
  • Kabal
    By the way, same error occurs if I want to LVS versus the Stream of GDSII. Ok, anyqay, I again decided to go from scratch from the point of clean DRC after Layout import.
    I have my main module called refleks_switcher routed with added fills in Encounter, and I imported its GDSII into library called r_test2. The DRC was clean (after fixing port pin layers), i.e. *NO* substrate contact related DRC errors which would require me to add substrate contacts in schematic. And again.. that is because after final routing in Encounter I added: FILL1, FILL2, NWSX.
    So, I am attaching now the log file of Assura fail run. Do you notice that at some point it actually TELLS that specific cells which I want to be ignored *ARE* ignored? But then later, it says:
    *ERROR* cell 'FILL1' is not defined.
    *ERROR* cell 'NWSX' is not defined.
    *ERROR* cell 'FILL2' is not defined.
     Also, the FILL1,FILL2,NWSX cells are imported into r_test2 library as well. I can see their proper layout view.
    Why is it doing it? If the LVS ignored those cells, why again it says that they are not defined? Have any idea what exactly is going wrong here?
    • lvs_error.txt
  • Kabal
    To be even more precise, I am attaching LVS settings window with avParameters and avCompare rules with preview, does it look right? My LVS tool is Assura LVS.
    What exactly am I doing wrong when telling LVS to ignore FILL1,FILL2 and NWSX cells?
  • Alex Soyer
    Alex Soyer over 12 years ago
    Hi Kabal,
    My knowledge on the Assura setup is very limited but I have asked on of my colleague to help here.
    Alex
    This question was split off by Kabal to a separate thread.
