  3. Reading a data file in Veriloga code
  • Subscribers 132
  • Views 19467
Sali
Sali over 12 years ago
Dear all,
I'm a new user with Veriloga in Cadence I wrote the following model and created a symbol to simulated it with other components but I got the following error:
FATAL (VLOGA-5096):  16: I50:  Cannot open file 'scanftest' for reading. Check this file to verify that it exists and that you have permission to open it for reading and try again. The idea is reading the numbers from the file then store each colomn in a separete array to use it after in the claculations. where I must svae the data file, it is two colomns of 9 decimal numbers and thsi is the code:
`include "constants.vams"
`include "disciplines.vams"
module VxijwithFile(x);
inout x;
electrical x;
real parameter c=1e-9,r=1e3,I=0,Vx0=1,t=5e-6;
integer A[1:9], Vxij[1:9],mcd,retval,count,f;
real Vykl[1:9],a,vx;
genvar i;
analog begin
 @(initial_step) begin
      mcd=$fopen("/home/VxijwithFile/veriloga/scanftest","r");
      retval=2;
      count=0;
      while(retval==2) begin
         retval=$fscanf(mcd,"%f %f",a,vx);
         A[count]=a;
         Vxij[count]=vx;
         Vykl[count]=0.5*(abs(Vxij[count]+1)-abs(Vxij[count]-1));
count=count+1;
      end
$fclose(mcd);
       f=0;
       for (i=1;i<8;i=i+1) begin
       f=f+A[f]*Vykl[f];
       end
end
V(x) <+ exp(-t/(r*c))+idt(exp((t-c*r)/(r*c))*(f/c));
end
endmodule
thank you
    I tried your module and did not have the problem with reading the file, so I can only assume the issue you have is because either the path you've given is incorrect or that the permissions are such that you can't read the file.
    I did however have a problem due to the fact that your arrays are [1:9] whereas the code tries to write (and read) from index 0, and so they should be defined as [0:9] (maybe [0:8] would be OK). But after fixing that, it ran (not sure whether it was correct, because I'm not sure what it's supposed to be doing).
    So do as the error suggested, and check the path exists and that you have sufficient permissions to read it.
  • Sali
     Thank you so much I corrected the code but it gives me this error, I'm wondering about the "idt" could be used for an expression like this or just with voltage/current signal?
    RROR (VACOMP-2154):
            "/home/VxijwithFile/veriloga/veriloga.va",
            line 34: Encountered the `idt' analog operator embedded in a
            conditionally-executed statement or in an expression. The software does
            not support this use. Do not use the `idt' analog operator in a
     -----------The code-------------
    module VxijwithFile(x,n);
    inout x,n;
    electrical x,n;
    integer mcd,retval,count,f;
    real Vykl[1:9],a,vx,A[1:9],Vxij[1:9];
    genvar i;
    analog begin
     mcd=$fopen("/home/Documents/scanftest.dat","r");
          retval=2;
          count=1;
             retval=$fscanf(mcd,"%f, %f",a,vx);
             A[count]=a;
             Vxij[count]=vx;
             count=count+1;
          end
    $fclose(mcd);
           f=0;
           for (i=1;i<10;i=i+1) begin
           f=f+A[f]*Vykl[f];
    end
    V(x,n) <+ exp(-t/(r*c))+idt(exp((t-c*r)/(r*c))*(f/c));
    end
    end
    endmodule
    Thank you,
    Your contribution statement appears to be inside the begin/end block for @(initial_step), whereas it should be outside (it was earlier). So you have two end statements below the contribution statement (the V(x,n) <+ ... line), and one above - there should be two end statements above and one below.
  • Sali
    Thank you so much for your help. This error dissappeared I have another dc convergance error i'm trying to change the design.
    Thanks again
