  3. Skill Script for selcting a portion of area in schematic...
  • Views 15458
Skill Script for selcting a portion of area in schematic editor in IC5141
RFStuff
RFStuff over 12 years ago
 Dear All,
I like to have a skill script that can enable me to select a portion of area in Schematic composer.
For example:- I clicked a point ( left mouse click) and a rectangle is created and when I clicked the mouse at the opposite diagonal of the rectangle then the area inside the rectangle should be selected (highlighted).
Also polygon would be more preferable. This will enable to select exact area.
Could anybody please share / help in getting the SKILL script that can achieve the above.
Kind Regards,
  • Marc Heise
    Marc Heise over 12 years ago
    while it's not that hard to use  the "geSelectArea() " function to achieve what you are looking for I wonder
    why you would need such and not just use the  build in area selection by holding the left mouse button
    and dragging it over the area? Using Shift and Ctrl to add and remove objects from the selection can be
    done this way as well.
    Marc
  • aflex
    aflex over 12 years ago
    Extend the area by:
    ■ Several wire segments
    ■ A wire name and its associated wire segments
    ■ A pin and its associated wire segments
    ■ An instance and its associated wire segments
    smt pcb assembly in Santa Ana, CA
    This is a standard feature in IC615/IC616 - hit F3 after calling geSelectArea() and you can select using a polygon.
    In IC5141 you could use this solution. It was really intended for layout, but it should work with schematics too.
  • RFStuff
     Dear Andrew,
    Thnaks a lot for the reply.
    Kind Regards,
