  3. LVS unable to check the NMOS source connectivity to the...
  • Subscribers 133
  • Views 15679
LVS unable to check the NMOS source connectivity to the ground
sutej
sutej over 12 years ago
Hi all,
I am using Cadence IC 6.15  and using Assura for DRC, LVS and extraction.My LVS check shows no errors and says all the cells are matched. However, after running the post layout simulation I found that the results are abnormal. After spending more time on rechecking the layout...I found that at one place I did not connect the NMOS source to the ground although it is connected to the substrate and in schematic both the substrate and source were connected together to the ground. After fixing this error post layout simulation results are okay. I presume that the LVS tool is considering the NMOS ground connection through the substrate which is connected to the ground at some other place in the circuit. Could any one please let me know how to fix such an exceptions. I have a very big design and it is becoming increasingly difficult to manually keep tab of this exception. Any Immediate reply is very much appreciable as my tape out date is nearing by.
Sutej
  • Quek
    Quek over 12 years ago
    Hi Sutej
    It is possible to do such checks using Assura ERC by adding the following cmd to the extract.rul file. E.g.
    ercCheckFloatingDevices(mosSourceOrDrain)
    Please refer to $ASSURAHOME/doc/assuracommandref/assuracommandref.pdf for more details on the command.
    I think  LVS should be able to capture the error and is not sure why this is not so. Would you please examine the layout ldb and lnn netlists for that particular nmos instance?
    terminal>vldbToCdl design.ldb > design.ldb.ascii
    terminal>vldbToCdl design.lnn > design.lnn.ascii
    The above cmds convert the binary netlist files to ascii formats.
    Best regards
    Quek
  • sutej
    Hi quek,
    Thank you very much for the info. I will check that and get back.
