  3. Parameterizing a Parameterized symbol
  • Subscribers 132
  • Views 15496
RFStuff
RFStuff over 12 years ago
 Dear All,
I have a symbol in which the component ''vcvs" is parameterized to 'gm'.
Please see the attached image.
When I want to put a parameter in the symbol 'gm' as Gm, it is showing circular dependency error.
How this can be fixed.
Kind Regards,
    It's not clear what you're doing from those pictures. Having a instance inside a cell which has pPar("gm") is fine - and then setting the value of gm on the level above to a design variable "Gm" should also be fine. When is this "circular dependency" error being given and what is the precise (and complete) error message?
    I've attached a small database with a cellView mylib/testbench/schematic - and a corresponding ADE state - which shows this all working - based on my interpretation of the information you gave.
    gmExample.tar.gz
