  3. Mismatch and Process Spread data in Monte Carlo simulat...
  • Views 17661
Mismatch and Process Spread data in Monte Carlo simulations
Flyyn Rider
Flyyn Rider over 12 years ago
Dear readers,
I run montecarlo simulations and I need to know:
1) Is there a way to know whcih process parameters are varied and how much their spread is for every run in montecarlo simulation?
2) Is there a way to know which of the devices in my circuit experienced maximum spread/mismatch? (so that i can redesign those devices)
Thank you so much.
    Eugene,
    Which tool version are you using?
  • Flyyn Rider
    I am using:
    "virtuoso version 6.1.5" and "subversion IC6.1.5.500.9". Plus, I am working in GlobalFoundries 65nm LPE process node. Thanks
  • shubham3011
    shubham3011 over 12 years ago
    hi Flyyn ,
      have u got any answer for that ..please post it as I  also need to know the same.. Thanx
    Regards
    Shubham
  • Flyyn Rider
    Hi Shubham,
    There are so many process parametes that MC changes in submicron technologies. It also depends on which region your device is operating. For example if your device is operating in weak inversion, the doping profile of 'halos' (these are high doped regions encompassing p+ and n+ regions for devices operating in subthrehold region). For long, short, wide and narrow transistors operating in different regions of operations the process parameter significantly changing the behavior of device could be different and there is no way to know which of the parameters cause maximum variations. But still 1/sqrt(W.L) holds in most situations especially when the device is operating in linear region with low Vds (roughly at the edge of saturation). You can look at the articles/book published by Willy Sansen's group from KU Leuven Catholic University in Belgium.
    For the second point, you can specify in MC which devices should be considered for variations. This way you can work out which of the devices cause maximum variations and can work on their redesign.
