  3. PCELL: Specifying instance name in design
  • Views 18835
KarthikJaiho
KarthikJaiho over 12 years ago
 Hi friends,
          I have created a pcell for a Mosfet using PCELL menu in virtuoso layout suite L. To specify the instance name in my design i have placed a label [@instanceName] at the middle of my pcell and also, for specifying Source and Drain terminal i have placed a label S and D at the middle of source and drain metal in my pcell. When i instancing my pcell in my design i cannot see my instance name(Ex:I0,I1). It looks only as [@instanceName]. And also S and D label is not at the middle of my design. Here I have attached screenshots of  my pcell and my design using that pcell. Please help me on this. And also help me how to place Mosfet name in my design and its length/width.(Ex:pch 0.4/0.14)
Note:
          I am using  Pcell menu in virtuoso layout suite L not using skills.
          version:IC6.1.5
Karthik
    For the instanceName label, create the label, select it, and then in the CIW type:
    car(geGetSelSet())~>labelType="NLPLabel"
    As to how to make the S/D labels centred - that's hard - I'm not sure how to do this with the graphical pcell editor (which is pretty old and has not been developed in some time as we would strongly encourage you to write the pcell in SKILL; this will result in a more powerful and better performing pcell).
    To place an instance, you can use dbCreateParamInstByMasterName(). Or from the UI just use create instance - not really sure why you're asking this?
  • Frank Wiedmann
    Frank Wiedmann over 12 years ago
    Andrew,
    What about the Cadence PCell Designer that will be featured in session CUS06 of this year's CDNLive EMEA? Is this a different tool or the same as the one that you don't recommend?
    Best regards,
    Frank
    Frank,
    No, the tool I'm not recommending is the very old "graphical pcell environment" launched with Launch->Pcell (or now in IC616 Launch->Plugins->Pcell).
    The Cadence PCell Designer is a different approach - it's a graphical environment closely integrated with the layout tools which allows you to build an pcell implemented in SKILL++.  This is definitely a recommended flow (it's actually developed by my team) - if anyone is interested, please contact your account team within Cadence - we'd be happy to talk to you about it.
    The paper (CUS04, not CUS06, I think) is here.
  • Frank Wiedmann
    Andrew,
    Thanks for the info. The paper you mentioned was CUS04 of last year's CDNLive EMEA, I was referring to CUS06 of this year's CDNLive EMEA (announced at http://www.cadence.com/cdnlive/eu/2014/pages/Wednesday.aspx).
    Best regards,
    Frank
    Frank,
    Yes, I misread the word "this" as "last" from your previous post ;-) . There is indeed another presentation on slightly different aspects of PCell Designer at the EMEA CDNLive! this year.
    Kind Regards,
  • KarthikJaiho
              Thanks a lot for your guidance.I tried this one and worked fine.
    Karthik
