  3. Ocean script plot function
  • Views 19630
ahmed osama
ahmed osama over 12 years ago
 Hi All
I am facing  a problem in plotting a bus , I am using ocean script to run simulation . when i use function plot CIW gives me error it cann't plot the whole object
I am using cadence 6.1.5
    Unless you show what you're actually calling and what the precise error message is, it's going to be rather hard for anyone to help!
    Kind Regards,
  • ahmed osama
    this the error
     spectre completes with 1 error, 0 warnings, and 0 notices.
    Cannot start up spectre.
    WARNING (OCN-6040): The specified directory does not exist, or the directory does not contain valid PSF results.
            Ensure that the path to the directory is correct and the directory has a logFile and PSF result files.
    WARNING (OCN-6034): You need to specify what results you want to look at before using this command.
            You can do this with the openResults() command. For more information type,
            ocnHelp('openResults) in the Command Interface Window (CIW).
    Loading viva.cxt
    WARNING (OCN-6041): You must do openResults() and selectResults() before using this command.
            Make sure your openResults() and selectResults() commands worked. Use ocnHelp('openResults)
            and ocnHelp('selectResults) for more information.
    ERROR (WIA-1006): Unable to plot expression <getData("/Equal")>
               because it does not evaluate to an object that can be plotted, like a waveform or
               parametric wave. See the Visualization & Analysis Tool documentation for information
               about the types of objects that can be plotted in Visualization & Analysis Tool. Only
               the expressions that evaluate to those objects can be plotted.
    *Warning* Wave1 is not a waveform object that can be displayed and
              will be DELETED automatically.
    ERROR (WIA-1006): Unable to plot expression <getData("/B_larger")>
    ERROR (WIA-1006): Unable to plot expression <getData("/A_larger")>
    ERROR (WIA-1006): Unable to plot expression <getData("/B<1>")>
    ERROR (WIA-1006): Unable to plot expression <getData("/B<0>")>
    ERROR (WIA-1006): Unable to plot expression <getData("/A<1>")>
    ERROR (WIA-1006): Unable to plot expression <getData("/A<0>")>
     This is the script i use
    simulator( 'spectre )
    design(     "/home/ososanny/simulation/compartor_n_test_bit/spectre/schematic/netlist/netlist")
    resultsDir( "/home/ososanny/simulation/compartor_n_test_bit/spectre/schematic" )
    modelFile(
        '("/home/ososanny/Desktop/cadence_work/gpdk090_v3.9/libs.oa22/gpdk090/../../models/spectre/gpdk090.scs" "NN")
    stimulusFile( ?xlate nil
        "/home/ososanny/Desktop/cadence_work/compartor.scs")
    analysis('tran ?stop "30n"  ?start "0"  ?outputstart "0"
            ?step "10p"  ?maxstep "10p"  )
    envOption(
        'analysisOrder  list("tran")
    temp( 27 )
    run()
    openResults( "/home/ososanny/simulation/compartor_n_test_bit/spectre/schematic/psf" )
    selectResult( 'tran )
    plot(getData("/Equal") getData("/B_larger") getData("/A_larger") getData("/B<1>") getData("/B<0>") getData("/A<1>") getData("/A<0>") )
    The first two lines you posted are the clue:
    It looks as if the simulation failed. Because of that, it's hardly surprising that you can't plot anything. You need to look earlier to see why the simulation failed.
