  3. Layout netlist extraction
  • Replies 7
  • Views 20086
PietroUser
PietroUser over 12 years ago
is there a simple way to extract the netlist from a layout without parasitics without doing the full LVS with Assura?
I am writing the extract.rul file and searching for a way to debug it.
Pietro
  • Quek
    Quek over 12 years ago
    Hi Pietro
    Using an LVS/ERC tool to extract a layout netlist is already the most simple method. There is no need to do a full LVS. Just you only require the layout netlist, you can just use an empty cdl netlist or a dummy schematic for the LVS. Layout netlist can then be obtained as follows:
    terminal>vldbToCdl design.ldb > design_layout.cdl
    Best regards
    Quek
  • KarthikJaiho
    KarthikJaiho over 11 years ago
    Hi Quek,
    I tried the command vldbToCdl design.ldb to extract the cdl for the gds. But it gives only the following output in the terminal,
    *.LDD
    Please help me on this.
    Karthik.
  • Quek
    Quek over 11 years ago
    Hi Karthik
    [In future, please kindly create a new thread for your own question. This is to allow us to concentrate on only your issue and not be confused by past issues which are not related to you]
    Would you please let us know the following?
    a. Version of Assura
    terminal>assura -W
    b. How about this?
    terminal>vldbToCdl design.sdb
    terminal>vldbToCdl design.snn
    terminal>vldbToCdl design.lnn
    terminal>vldbToSpice design.ldb
    Please note that you have to replace "design.abc" with the actual filename.
    Best regards
    Quek
  • KarthikJaiho
    Hi Quek,
    Thanks for your immediate response. I do create new thread hereafter, sorry for that. These are the results I got in my terminal.
    For,
    1)vldbToCdl design.sdb
                       There is some device information like widh length multiplier
    2)vldbToCdl design.snn
    Same as in previous command.
    3)vldbToCdl design.lnn
    *.LDD
    4)vldbToSpice design.ldb
    *.LDD
    Karthik
  • Quek
    Hi Karthik
  • Quek
    Hi Karthik
    I think either your layout is empty or something went wrong during the layout extraction. Would you please check the Assura log file for errors during layout extraction?
    Best regards
    Quek
  • KarthikJaiho
    Hi Quek,
    Thanks. I will check for assura log file.
    Karthik.
