  3. Abstract Generator : ERROR (ABS-216) [SOLVED], ERROR (ABS...
  • Views 20297
Abstract Generator : ERROR (ABS-216) [SOLVED], ERROR (ABS-218) [SOLVED], ERROR (ABS-263)
samung
samung over 12 years ago
I would like to generate the LEF view from a layout.oa (which contains layers up to M1) view for a simple cell (inverter) in 40LP Technology.
First step is to generate the abstract view, then the LEF view.
I am using the tool : Abstract Generator.
I have an issue, for the abstract view generation,  when I load the library/tech file (cf. below).
INFO      (ABS-127): Attaching the cmos045_tech_abstract technology library to the library_test_place_route_lef library.
LOG       (ABS-212): Verifying Technology Data...
ERROR     (ABS-216): There are insufficient metal layers defined in the current design. You must define at least two metal layers in the validLayers subsection of LEFDefaultRouteSpec  constraint group of the technology file. These layers must have the layer function "metal" in the functions section. Update the technology file and attach it again.
INFO      (ABS-253): Created the required DNW , pin layer-purpose pair in the technology file.
INFO      (ABS-253): Created the required DNW , boundary layer-purpose pair in the technology file.
INFO      (ABS-232): Layer summary: 0 metal layer(s), 9 via layer(s), 3 poly layer(s), and 8 diff layer(s) found
INFO      (ABS-234): Via summary: 40 valid via(s) found
Tool used :
.../uniopus_oa/cadence_amsams2010.2c_mmsim/lnx/tools/dfII/bin/abstract
I have seen some messages in the forum regarding this topic, but no answer to them :
www.cadence.com/.../1312866.aspx
www.cadence.com/.../1313188.aspx
  • I had previoulsy : ERROR     (ABS-218): There are no vias specified in the technology file. Which I solved adding the following lines in the tech file (see the 2 forum messages above) :
; CONSTRAINT GROUPS
constraintGroups(
 ;( group [override] )
  ( "LEFDefaultRouteSpec" nil    "LEFDefaultRouteSpec"
    interconnect(
     ( validLayers  ( ( AP  drawing) ( AP  tile) ( AP  net) ( AP  pin) ( CB  drawing) ( CB  pin) ( CB  net) ( M7Z  drawing) ( M7Z  tile) ( M7Z  pin) ( M7Z  net) ( VIA6Z  drawing) ( VIA6Z  net) ( VIA6Z  pin) ( M6Z  drawing) ( M6Z  tile) ( M6Z  pin) ( M6Z  net) ( VIA5Z  drawing) ( VIA5Z  pin) ( VIA5Z  net) ( M5X  drawing) ( M5X  tile) ( M5X  tile_O) ( M5X  pin) ( M5X  net) ( VIA4X  drawing) ( VIA4X  pin) ( VIA4X  net) ( M4X  drawing) ( M4X  tile) ( M4X  tile_O) ( M4X  pin) ( M4X  net) ( VIA3X  drawing) ( VIA3X  pin) ( VIA3X  net) ( M3X  drawing) ( M3X  tile) ( M3X  tile_O) ( M3X  pin) ( M3X  net) ( VIA2X  drawing) ( VIA2X  pin) ( VIA2X  net) ( M2X  drawing) ( M2X  tile) ( M2X  tile_O) ( M2X  pin) ( M2X  net) ( VIA1X  drawing) ( VIA1X  pin) ( VIA1X  net) ( M1  drawing) ( M1  tile) ( M1  tile_O) ( M1  pin) ( M1  net) ( CO  drawing) ( CO  net) ( CO  pin) ( PO  drawing) ( PO  tile) ( PO  tile_O) ( PO  filltr) ( PO  net) ( PO  pin) ( OD  drawing) ( OD  tile) ( OD  tile_O) ( OD  filltr) ( OD  net) ( OD  pin) PP  NP  ( NW  drawing) ( NW  net) ( NW  pin) CutOxideWithPoly  CutSubWithNwell  d_pwell  ) )
     ( validVias     (M1_NW  M1__NW  M2X_M1_via  M2X_M1_V_via  M3X_M2X_via  M3X_M2X_H_via  M4X_M3X_via  M4X_M3X_V_via  M5X_M4X_via  M5X_M4X_H_via  M6Z_M5X_via  M6Z_M5X_V_via  M7Z_M6Z_via  M7Z_M6Z_H_via  AP_M7Z_via  M1_POLYP  M1_POLYN  PTAP  NTAP  M1_POD  M1_NOD  M1__PO  M1__PO_H  M1_OD  M1_PO  M1_PO_H  M2X_M1  M2X_M1_V  M3X_M2X  M3X_M2X_H  M4X_M3X  M4X_M3X_V  M5X_M4X  M5X_M4X_H  M6Z_M5X  M6Z_M5X_V  M7Z_M6Z  M7Z_M6Z_H  AP_M7Z  FI_AP  ) )
    ) ;interconnect
  ) ;LEFDefaultRouteSpec
Some more extract of the tech file :
; LAYER RULES
layerRules(
 equivalentLayers(
 ;( list of layers )
  ( ("PO" "drawing") ("PO" "tile") ("PO" "tile_O") ("PO" "filltr") ("PO" "mask") )
  ( ("M1" "drawing") ("M1" "tile") ("M1" "tile_O") )
  ( ("M2X" "drawing") ("M2X" "tile") ("M2X" "tile_O") ("M2X" "connector") )
  ( ("M3X" "drawing") ("M3X" "tile") ("M3X" "tile_O") ("M3X" "connector") )
  ( ("M4X" "drawing") ("M4X" "tile") ("M4X" "tile_O") ("M4X" "connector") )
  ( ("M5X" "drawing") ("M5X" "tile") ("M5X" "tile_O") ("M5X" "connector") )
  ( ("M6Z" "drawing") ("M6Z" "tile") ("M6Z" "connector") )
  ( ("M7Z" "drawing") ("M7Z" "tile") ("M7Z" "connector") )
  ( ("AP" "drawing") ("AP" "tile") ("AP" "connector") )
 ) ;equivalentLayers
 functions(
 ;( layer                       function        [maskNumber])
  ( DNW                       "nwell"     0            )
  ( NW                       "nwell"     1            )
  ( OD                       "diff"       2            )
  ( DCO                       "nplus"     3            )
  ( PO                       "poly"       4            )
  ( VTH_N                     "nplus"     5            )
  ( VTL_N                     "nplus"     6            )
  ( NP                       "nplus"     7            )
  ( VTH_P                     "pplus"     8            )
  ( VTL_P                     "pplus"     9            )
  ( PP                       "pplus"     10           )
  ( CO                       "cut"       11           )
  ( M1                       "metal"     12           )
  ( VIA1X                     "cut"       13           )
  ( M2X                       "metal"     14           )
I cannot have access to : $CDSHOME/tools/dfII/samples/tutorials/abstract
I would be very grateful for any help.
P.
  • samung
    OK, I found this one :
    http://lost-contact.mit.edu/afs/rose-hulman.edu/cadence-0910/IC610/doc/abstract/appD.html I solved ABS-218 thanks to it :
    ; CONSTRAINT GROUPS
    constraintGroups(
        interconnect(
         ( validLayers   (AP  CB  M7Z  VIA6Z  M6Z  VIA5Z  M5X  VIA4X  M4X  VIA3X  M3X  VIA2X  M2X  VIA1X  M1  CO  PO  ) )
        ) ;interconnect
  • samung
    Ah !!
    I have the unsolved error (i mean not present in the cadence doc I have just put above) :
     *U2DK-MSG* Loading USER-LEVEL CDF to library STlib...
    ERROR     (ABS-263): The routing direction for layer M1 is specified but no pitch value is present in the technology file.
    INFO      (ABS-232): Layer summary: 8 metal layer(s), 9 via layer(s), 3 poly layer(s), and 8 diff layer(s) found
    How can i modify the tech file to solve this one ?
    thanks !
    P.
  • bjbit
    bjbit over 12 years ago
    Hi samung,
    This is the issue I solved over 1 year ago, so I cannot exactly remember how I did. But here is something in my memory that may be helpful.
    The trubleshooting of the ABS-216 in the AG user guide is as below:
    Troubleshooting: Use the Technology File Manager to define these layers in the
    constraint group of the technology file. In addition, ensure that
    these layers are assigned the function metal in the functions
    subsection of the layerRules section.
    Use the Technology File Manager to ensure that the layer has
    been defined in all the sections listed below.
    ■ layerRules
    layerRules(
    functions(
    ( metal1 "metal" 1 )
    ( metal2 "metal" 2 )
    ) ;functions
    ) ;layerRules
    ■ LEFDefaultRouteSpec
    constraintGroups(
    ; layer constraints
    interconnect(
    ( validLayers ( METAL1 METAL2 METAL3 ) )
    ) ;interconnect
    ) ;constraintGroups
     You may try the above format. For example, in my .tf file, I wrote:
    constraintGroups(
    ; layer constraints
    interconnect(
         ( validLayers   (ML  FT  MT  V4  M4  V3  M3  V2  M2  V1  M1  CA  PC  RX  ) )
         ( validVias     (MT_ML  DMT_ML  M4_MT  DM4_MT  M3_M4  DM3_M4  M2_M3  DM2_M3  M1_M2  DM1_M2  PC_M1  DPC_M1  RX_M1  DRX_M1  ) )
    ) ;interconnect
    ) ;constraintGroups
  • samung
    Hi bjbit,
    thanks for your reply, as written above, I managed to solved the ABS-216 issue. Now, I have ABS-263 issue.
    I don't have any indication regarding this error.
    In my technology file, I have :
      ( "virtuosoDefaultSetup" nil
        interconnect(
         ( validLayers   (M1  M2X  M3X  M4X  M5X  M6Z  M7Z  AP  ) )
         ( validVias     (M1_POLYP  M1_POLYN  PTAP  NTAP  M1_POD  M1_NOD  M1__PO  M1__PO_H  M1_OD  M1_PO  M1_PO_H  M2X_M1  M2X_M1_V  M3X_M2X  M3X_M2X_H  M4X_M3X  M4X_M3X_V  M5X_M4X  M5X_M4X_H  M6Z_M5X  M6Z_M5X_V  M7Z_M6Z  M7Z_M6Z_H  AP_M7Z  FI_AP  ) )
        ) ;interconnect
        routingGrids(
         ( verticalPitch              "M1"   0.14 )
         ( horizontalPitch            "M1"   0.14 )
         ( verticalOffset             "M1"   0.0 )
         ( verticalPitch              "M2X"   0.14 )
         ( horizontalPitch            "M2X"   0.14 )
         ( horizontalOffset           "M2X"   0.0 )
         ( verticalPitch              "M3X"   0.14 )
    Does someone would have the appropriate lines in the tech file ?
    thanks !!
    P.
  • ColinSutlieff
    ColinSutlieff over 12 years ago
    Hi Samung,
    A few suggestions:
    1. Normally your "LEFDefaultConstraintGroup" should only contain metal routing layers:
        interconnect(
         ( validLayers  (  M7Z   M6Z  M5X  M4X   M3X  ....etc
    Also, it is not normally necessary to explicitly define the layer purposes.
    2. Make sure that the technology graph is set up coprrectly:
    Yours should look something like:
    library_test_place_route_lef-----> cmos045_tech_abstract-------> <your technology librar(y/ies)
    You can check this with:
    Tools--->technology file manager--->graph
    3. Somewhere, in one of your libraries, you should have  routing grids defined:
       routingGrids(
         ( verticalPitch              "M1"   0.61 )
         ( horizontalPitch            "M1"   0.61 )
         ( horizontalOffset           "M1"   0.0 )
         ( verticalPitch              "M2X"   0.63 )
         ( horizontalPitch            "M2X"   0.63 )
         ( horizontalOffset           "M2X"   0.315 )
         ( verticalOffset             "M2X"   0.315 )
        ) ;routingGrids
    This is probably in your main technology library. But you can also define it in your "LEFDefaultConstraintGroup".
    Hope this helps
    Colin
  • samung
    Hi Colin,
    thanks for the answer, but I still have the issue.
    I have just created a new message : http://www.cadence.com/Community/forums/p/29220/1333646.aspx#1333646
    P.
