  3. Abstract Generator : abstract view with just "M1 net layer...
  • Views 2488
Abstract Generator : abstract view with just "M1 net layer" => instead of "M1 drawing" and "M1 pin layers"
samung
samung over 12 years ago
Hi !!
I managed to get an Abstract view of my simple inverter cell, from a layout.oa view (up to M1 layer). See attachment.
However, in this Abstract view, i just have one layer : M1 net. Actually I would like to have "M1 drawing" and "M1 pin" layers + the contact "CO layer" to see the pins (vdd/vss/A/Y) in the viewer and the contacts.
In my layout.oa input file, my strategy for the pin definition is:
one layer or M1 drawing with connectivity vdd
+ layer pin M1 on this layer (Terminal Name : vdd)
+ layer text drawing "vdd" (no connectivity)
I think, I have to do something "Step Extract" at Signal & Power panels but I cannot do what I want. I tried different combination with no sucess.
Thanks for any help !!
P.
StdCell_Abstract_Layers_layout_to_LEF.pdf
  • ColinSutlieff
    ColinSutlieff over 12 years ago
     If you want a different purpose, click file->general options-> pin purpose name
    Any geometry that is not connected to the pin will be converted to "blockage" objects. No actual mask layers will be generated with purpose "drawing"
    Add CO to the layers in your  LefDefaultRouteSpec
    Having existing geometry with connectivity attached ( I think this is what you mean with " one layer (shape?) on? M1 drawing with connectivity vdd")  may cause problems (unless you want pins generated for all shapes with connectivity attached)
    Try removing the connectivity on the shapes that you don't want to convert to a pin. Then turn off the extractor completely in the "extract" step
    Hope this helps
    Colin
  • samung
    Hi Colin,
    thanks for the quick reply (again) :)
    With the current setting (Pin purpose name : net and no COnstraint group defined in the File -> General options panel), it happens that I can have a correct enough (visual check) LEF view of my simple inverter cell to be able to generate a  correct enough (visual check) FRAM view (layer M1 terminal for the blockage, and the ports : vdd/vss/A/Y) (with Synopsys milkyway). I have to to the Verify Step with the Abstract Generator tool.
    • Without the typo :
    My strategy for the pin definition in this layout.oa :
    one layer on M1 drawing with connectivity vdd
    • I have already the CO layer as valid layer :
    Extract of the tech file :
    ; CONSTRAINT GROUPS
    constraintGroups(
     ;( group [override] )
      ( "LEFDefaultRouteSpec" nil    "LEFDefaultRouteSpec"
        interconnect(
         ( validLayers   (AP  CB  M7Z  VIA6Z  M6Z  VIA5Z  M5X  VIA4X  M4X  VIA3X  M3X  VIA2X  M2X  VIA1X  M1  CO  PO  ) )
         ( validVias     (M1_NW  M1__NW  M2X_M1_via  M2X_M1_V_via  M3X_M2X_via  M3X_M2X_H_via  M4X_M3X_via  M4X_M3X_V_via  M5X_M4X_via  M5X_M4X_H_via  M6Z_M5X_via  M6Z_M5X_V_via  M7Z_M6Z_via  M7Z_M6Z_H_via  AP_M7Z_via  M1_POLYP  M1_POLYN  PTAP  NTAP  M1_POD  M1_NOD  M1__PO  M1__PO_H  M1_OD  M1_PO  M1_PO_H  M2X_M1  M2X_M1_V  M3X_M2X  M3X_M2X_H  M4X_M3X  M4X_M3X_V  M5X_M4X  M5X_M4X_H  M6Z_M5X  M6Z_M5X_V  M7Z_M6Z  M7Z_M6Z_H  AP_M7Z  FI_AP  ) )
        ) ;interconnect
        routingGrids(
         ( verticalPitch              "M1"   0.14 )
         ( horizontalPitch            "M1"   0.14 )
         ( horizontalOffset           "M1"   0.0 )
         ( verticalOffset             "M1"   0.0 )
         ( verticalPitch              "M2X"   0.18 )
         ( horizontalPitch            "M2X"   0.18 )
         ( horizontalOffset           "M2X"   0.0 )
         ( verticalOffset             "M2X"   0.0 )
         ( verticalPitch              "M3X"   0.14 )
         ( horizontalPitch            "M3X"   0.14 )
         ( horizontalOffset           "M3X"   0.0 )
         ( verticalOffset             "M3X"   0.0 )
         ( verticalPitch              "M4X"   0.14 )
         ( horizontalPitch            "M4X"   0.14 )
         ( horizontalOffset           "M4X"   0.0 )
         ( verticalOffset             "M4X"   0.0 )
         ( verticalPitch              "M5X"   0.14 )
         ( horizontalPitch            "M5X"   0.14 )
         ( horizontalOffset           "M5X"   0.0 )
         ( verticalOffset             "M5X"   0.0 )
         ( verticalPitch              "M6Z"   0.84 )
         ( horizontalPitch            "M6Z"   0.84 )
         ( horizontalOffset           "M6Z"   0.0 )
         ( verticalOffset             "M6Z"   0.0 )
         ( verticalPitch              "M7Z"   0.84 )
         ( horizontalPitch            "M7Z"   0.84 )
         ( horizontalOffset           "M7Z"   0.0 )
         ( verticalOffset             "M7Z"   0.0 )
         ( verticalPitch              "AP"   5.0 )
         ( horizontalPitch            "AP"   5.0 )
         ( horizontalOffset           "AP"   0.0 )
         ( verticalOffset             "AP"   0.0 )
        ) ;routingGrids
      ) ;LEFDefaultRouteSpec
    P.
